01-21-2013, 10:19 AM
#901
_
, _
Originally Posted by bkahler
Dean, interesting idea on the shutoff valve. Did the system come that way or is that something that you or your dad installed? I really like the idea and just might do something similar.
The valve comes with a particular model of the Safe-T-Alert propane/CO detector. The detector controls the valve.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
01-21-2013, 02:16 PM
#902
_
, _
Good news on the furnace...
I emailed the vendor this morning and they replied within an hour. They have scheduled the pickup of the damaged unit and will ship a new one tomorrow. Not only do they have the best pricing but that is awesome customer service!
01-21-2013, 10:17 PM
#903
_
, _
I pulled up the carpet in the salon area today and found a small area of the floor behind the passenger seat rotted out. I had suspected that my windshield leak is coming from the front of the awning rail and i think this confirms it.
Any suggestions/advice on repairing this? Does the shell sit on top of the plywood?
01-22-2013, 05:20 AM
#904
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Dean, it may be time to pull the wall panels and sit there during the next big rain. I have used small funnels and drain tubes around the front seat areas before to manage small persistent leaks. I wouldn't worry too much about the small wood rot. If you fix it and seal it watertight further water intrusion may damage the new carpet/flooring
AIR #13
01-22-2013, 07:48 AM
#905
Richmond
, Kentucky
Dean,
See attached PDF that lays out the construction of the floor and walls.
Along with the sketch that I made you'll find that there are a lot of phillips head screws going from aluminum channel into the wood. The red bolt in the sketch is about 2 plus inches long and has a nut and lock washer on the bottom side. On the 345 that I dismantled the wood floor was also fastened to the 1" x 2" tubing grid throughout with 1/4" flathead self tapping screws AND spiral nails. The nails were a real bear to get out. I ended up having to torch the heads of the nails before I could get the wood floor off.
typical-airstream-mh-construction.pdf
The 1" x 2" steel grid is attached to the truck frame with steel rivets. The grid was laid down on top of the truck frame and riveted in place, then the aluminum/galvanized sheet was laid on top of the frame and then the entire shell with the wood floor was laid down on top of the grid and bolted in place along the edges and then screwed and nailed to the 1" x 2" grid. This is how the 345 was constructed so I'm guessing your coach is very similar. It appears that my Argosy is built along these same lines although I'm not sure if it was a single sheet of plywood or sections. I know the 345 is one long piece of wafer board.
I'll try and post some pictures this evening showing how the 345 was constructed.
Hope this helps.
1975 24' Argosy Motor Home
01-22-2013, 06:56 PM
#906
_
, _
Switches...
I'm replacing some 12v light switches while I have some things apart for the floor repair. Anyone find any new modern switches that they like?
01-23-2013, 07:51 AM
#907
Richmond
, Kentucky
Switches...
Heck, my Argosy just has cheap toggle switches all over the place so just about any switch would look better than that!
You might go to digikey.com and browse through their online catalog. They have a gazillion switches listed.
01-23-2013, 03:57 PM
#908
1979 24' Airstream Excella 24
Monterey
Very Disappointed - New Furnace is Smashed In...
I purchased a new Suburban NT34SP from an RV company in Texas. It was shipped from some warehouse in So Calif. I just went to open the box and prepare to install it. The entire left front side is smashed in.
I guess I'll cash in my 401k and head down the mountain tomorrow and buy one from CW. ;(
I had the same experience. Suburban 30SP thrown into box like a sack of potatoes. Had dents and probably dangerous. The Company send a replacement right away and a call tag to pick up the damaged unit too.
Perhaps the same Texas Co. (PPL Motorhomes)
01-24-2013, 03:24 PM
#909
Iowa City
, Iowa
Localized subfloor repair
On my '83 310 there was a hat-sized rotted place under the driver's side window. It looked a lot like your photo...
We poured a wood hardener (Ace Hardware) liquid onto it and then filled it with fiberglass. Most all the wood in the rest of the coach was quite solid, so we didn't want to do any tear-out.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
01-26-2013, 12:56 PM
#910
_
, _
Peter, you may be right about needing to pull the inside panels. We had a mild rain a few nights ago and I'm definitely still leaking in that up front corner. Its leaking too much to let it go.
01-26-2013, 12:57 PM
#911
_
, _
Dean,
Hope this helps.
Brad, thanks for the diagram!
01-26-2013, 01:07 PM
#912
_
, _
Huberto, yes that's the company. They did come through with no questions asked! They delivered another unit before I was even able to get the smashed one back home and shipped out. It just means another 500 mile round trip for me between home and the mh.
01-26-2013, 01:21 PM
#913
_
, _
I haven't pulled the carpet from the cab yet and I have my fingers crossed! I'm going to patch in a couple small pieces of plywood. I need to research the wood hardener and some sealer. Every time I ask about such at Home Depot, the look at me like I am completely nuts!
01-26-2013, 04:40 PM
#914
Richmond
, Kentucky
And your point is....
Sorry, couldn't resist
01-26-2013, 04:41 PM
#915
Richmond
, Kentucky
Sorry I didn't get any pictures posted. I'll see if I can track some down that show how things are put together and get them posted.
01-26-2013, 07:24 PM
#916
Pitt Meadows
, British Columbia
Regarding wood hardner hit up your local marine supply and ask for a product called Gitrot or something equivelant. It will draw moisture out of wood and harden to the point it is difficult to sand it down. I used it plenty on my old wooden trawler and it was amazing stuff.
1983 Airstream 240 Classic Motorhome
Pitt Meadows, BC Canada
01-27-2013, 10:35 AM
#917
_
, _
We have a West Marine down the road...I'll check them out.
01-27-2013, 10:45 AM
#918
_
, _
I pulled the plastic panel off to deal with the rain water leak and gave it is nice paint job. I'm also preparing for a new galley countertop.
02-03-2013, 08:55 PM
#919
_
, _
New Galley...
First, I can't believe SF didn't even show up for the game, sad!
I got my galley back together today. New furnace is installed, but still have duct work to do. Furnace is working well however which is nice since we are going from 70 degrees during the day to about 35 at night. Plumbing and wiring in galley are squared away. Countertop and new sink are in and working. I have my much needed soap dispenser!
02-04-2013, 03:28 AM
#920
Wildwood
That is one sweet looking galley!
Dave and Felicia
