01-11-2012, 08:32 PM
#261
1982 31' Airstream 310
Longview
You think you have bad luck looking for parts. I have been looking for 90 days or so for a generator door
01-15-2012, 12:18 PM
#262
_
, _
Heading north to MH next week for a weeks worth of work on the MH and wouldn't you know, northern Calif is finally going to get rain...that will put a damper on all the outside projects!
Things are never easy! I really wanted to put a corian countertop and round sink in kitchen, but I think the costs are a bit high. I really need to slow down on my money spending on the Motorhome. I love the round sinks, but also thinking it might not be so practical. So the only think cheaper then Corian is Formica. I'm not opposed to Formica...some of it these days looks really good. It would probably be better and easier to install a top mount sink with Formica, but almost all stainless top mount sinks have faucet holes...I want one with no faucet holes. see, just isn't easy! It is possible to do an undermount sink with Formica and a ring made for such.
Corian and the sink I want will run over $1000. I would like to be $500 or less.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
01-15-2012, 07:09 PM
#263
1989 34.5' Airstream 345
Silverton
Do they make formica that looks like Corian?...
We have Corian counter tops and dinette, but the counters have holes for the plumbing...our sinks are under counter mounted...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
01-15-2012, 09:42 PM
#264
_
, _
No, but they do make it look like granite! LOL
01-16-2012, 05:21 PM
#265
Silverton
I hate it when someone takes me for granite...
Michael & Tracy
1989 345 Motorhome
01-16-2012, 08:01 PM
#266
_
, _
Originally Posted by scrapirony-2
i hate it when someone takes me for granite...
That's good, I like that
01-16-2012, 09:07 PM
#267
Longview
I'm with you on that.
01-17-2012, 07:52 PM
#268
_
, _
Cleaned out and prepped the rear bin for painting and re-installation of the air compressor. Replaced fuel tank filler hose and prepped area for installation of the new air tank. Also added new task to the never ending list...front hydraulic jack is leaking.
01-18-2012, 07:27 PM
#269
_
, _
Got the air tank mounted today. That was about it for the day due to the rain...might snow tonight!
01-18-2012, 07:48 PM
#270
Foothill Ranch
Do you stay in it up there?
Whats the plan for the leaking leveler?
01-18-2012, 08:40 PM
#271
_
, _
Yes, I do stay in it here. It is an ownership ranch, 14,000 acres, most of it back country. Been an owner here for 25 yrs now. We have 200 full hookup spaces...first come, first serve. Can put RV on a space for 90 days then must move off the property for 7 days, then can come back on and find an open space. Of course rv's and ATVing are much more popular today then 25 yrs ago, so we are having a real issue with not enough spaces. That's really due to the owners that figured out how to get around the rules by buying two shares and just swapping spaces with their buddies every 90 days...space squatters!
We have bunk houses (cabins) and a small motel as well, but sure is nice to have your own RV. We were going to get a large fifth wheel last yr, but decided to keep the AS280 and fix it up instead...couldn't part with Dad's Toy! Could still get a fifth wheel just for here, but sooner or later there is going to be a issue with our storage lot.
We have shower houses about as well which is good in winter since I have the MH prepped for winter. Might just shut drain valves and hook up water tomorrow though. Electric is covered in the annual assessment payment, so I have electric heaters going in the winter and ac going all summer. Elect must be disconnected when not here though.
I do use the furnace as well and ran out of propane night before last. We sell propane here on property, so I disconnected and drove MH about 500 ft up the hill and got propane today. RV spaces are not level here, but did a better job of leveling MH with large blocks under tires this time so I don't have to raise the jacks as much...had problem with closing the door over the last few days...all better now.
I think the front jack leaks when I extend it all the way...extending it very little now. I have the Power Gear jacks and I believe rebuild kits are still available for the jacks that I have. So may try to rebuild it next summer. Until then I'll just keep cleaning up the mess and topping off the tank with ATF. I did overfill the tank once because I checked and filled with jacks somewhat deployed...not a good thing of course!
01-18-2012, 08:54 PM
#272
Foothill Ranch
Sounds great!
What is the cost of filling the propane tank... I have no idea as mine was full when i bought it!
01-18-2012, 09:30 PM
#273
_
, _
Sounds great!
My AS manual says there is a 82 pound and a 125 pound tank which is interesting since everyone fills by the gallon and not by weight. I'm assuming I have the 82 lb tank. I was completely empty and it took 24 gallons at $3.25/gallon, so $78.
01-19-2012, 08:48 AM
#274
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
Looks like you have the larger tank as it would be filled to 80% ??????
"How much propane is required to fill a propane tank?
80% of the actual capacity."
Dave
"100 pound propane tank will hold 23.58 gallon. 100 pounds / 4.24 pounds per gallon = 23.58 gallons"
01-19-2012, 11:39 AM
#275
_
, _
Dave
Hi Dave. That makes more sense! I wasn't calculating the 80% fill. I agree, it's got to be the 125 lb tank. Thanks.
01-19-2012, 02:20 PM
#276
Longview
My Old Gertrude holds 45 gal of Diesel at $4.05
01-19-2012, 03:27 PM
#277
Foothill Ranch
Sad news is, I bet her 45g of diesel takes you further than our 80g of gas!
01-19-2012, 06:04 PM
#278
_
, _
Our first storm of the season in the north state of Calif and it is a snow storm!
My windshield is leaking in the middle, drivers side and passenger side. Yikes!
01-19-2012, 06:39 PM
#279
1984 31' Airstream310
Ajo
If it helps anyone, both our fuel and propane were down to below 1/4 and we tanked in Phoenix on the way south. Took $160.00 diesel @ $3.92 (Safeway) and $80.00 propane @ $3.15. Getting rather pricey down here.
01-19-2012, 07:03 PM
#280
Foothill Ranch
Thanks Guys on the propane prices and amounts... I had no idea, as the PO filled the Propane before I took her back to CA!
Still have 3/4 full!
