Old 09-30-2019, 07:33 PM   #1861
1982 28' Airstream 280
Redwood City , California
ID:	353279Click image for larger version
Speaking of leaks, time to tackle the shower leak...again.
Let me get out my sharpie and explain it to you!
dadstoy is offline   Reply With Quote
Old 09-30-2019, 09:33 PM   #1862
What would you suggest for a replacement of the valve if I decide to replace it?
Old 10-01-2019, 06:03 AM   #1863
Oh the joy of trying to find something that will match. The only thing I can suggest is start googling pictures of bath/shower valves and see if you can find something that looks similar or matches. I've had to do a lot of that over the years as I've rebuilt my Argosy.
It might be worth the effort to take the valve to a good plumbing house and see if they have any suggestions.
Good luck!
Old 10-05-2019, 06:19 PM   #1864
I joined the U.S. Space Force so I thought it appropriate to convert the MH!
(WARNING: Donít try this humor at home, some wonít get it. )
Old 10-05-2019, 06:38 PM   #1865
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Way to go Jetson!
Might want to seal off the weep hole covers before launch.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 10-06-2019, 09:18 AM   #1866
Originally Posted by dadstoy View Post
Attachment 353639
Awesome! Does it have FTL speed?
Old 10-18-2019, 08:07 PM   #1867
I have to laugh at myself. We had these scrapers on our internal sales site and I thought I could use a new set
to use on the MH, trailers, ATVs etc. Well that will teach me to not check out the specs for the size. I suppose I could find something to use the large scrapers on...maybe the bottom of the storage bins that have been rusting for 30 years! Ha ha!
Old 10-19-2019, 06:52 AM   #1868
Send them my way, I'm sure I can find a use for them.....
Old 10-20-2019, 06:04 PM   #1869
Dazed and Confused
Isuzusweet's Avatar
Useful for cleaning out your donkeys feet.
Cheers
Sidekick Tony
Old 11-04-2019, 09:45 PM   #1870
Occamís Razor and windshield leaks! I think it is clearly obvious to me now where the A pillar rain water leak is. What is it about human nature that we dismiss the simple and obvious?
It looks like the Grand Canyon under the driverís side windshield gasket. I donít think the small tube of sealant I have will go far but Iím going to give it a try. Iím sure it will begin raining before I get back up here in another month so I have to do something. Click image for larger version
ID:	355668Click image for larger version
ID:	355669Click image for larger version
Old 11-04-2019, 10:08 PM   #1871
I finished running the pex in the bathroom. I canít reinstall the shower valve since I ran out of crimp rings.
ID:	355673Click image for larger version
ID:	355674Click image for larger version
ID:	355675Click image for larger version
ID:	355676Click image for larger version
Old 11-06-2019, 10:55 AM   #1872
It looks like the Grand Canyon under the driverís side windshield gasket. I donít think the small tube of sealant I have will go far but Iím going to give it a try. Iím sure it will begin raining before I get back up here in another month so I have to do something. Attachment 355668Attachment 355669Attachment 355670
My Argosy had the same huge gaps. I used a special sealant designed for the task. Came in a tube used in a standard caulk gun. So far I've had no leaks from the windshield area.
Old 11-07-2019, 06:11 AM   #1873
1986 34.5' Airstream 345
Londonderry , New Hampshire
I had a similar gap where the windshield gasket has shrunk and pulled
away from the frame. I used Sikaflex all around the windshield.
To push the Sikaflex into the gaps I used a plastic shipping bag cut
into strips. I laid the strips over the wet glue and pressed in into
the gap. I left the plastic strips on the glue while it hardened.
After the glue is hard you can pull the plastic strip off
the glue with no trouble.
With the plastic strips you can smooth the glue and push it around
freely. You can form the glue into a nice round shape which is
difficult to get just using a glue gun.
Air345Fly is offline   Reply With Quote
Old 11-07-2019, 09:11 AM   #1874
Dean, here's a link to my Argosy thread where I did a major rework of the windshield gasket.
No leaks so far
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 10:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 09:32 AM
