Old 10-16-2014, 10:47 PM   #1247
Sorry to hear you went thru that silliness Dean.
I think I can answer the smog cutoff issue in detail because I researched it...
Up until model year 1974, there were requirements for emissions, but no Catalytic Converter was required.
In 1975 for passenger vehicles and light trucks they were required to have them, as well as a raft of other emissions equipment .
As a result, the rolling 25 year exemption stopped for vehicles from 1975 onward. It kinda makes sense to me... even tho I don't like it.
It is my understanding, that in CA you could take, say the emissions equipment from a 1990 Suburban, TBI fuel injection system, electronics, fuel evaporation system, and exhaust system as far as the catalytic converter, and bolt it to the MH... it would be inspected and approved by a Smog Referee, and once approved, it will be tested as a 1990 model year.
I think you are correct on the Diesel cutoff year Dean, no smog required. If you put say a 2005 Cummins 24v Diesel in it the smog test would reflect the running gear smog test... if that makes sense..
There is a good reason why I have 5 smog exempt vehicles!
Two from 1973, two from 1974, and a 1984 diesel Mercedes!
Old 10-20-2014, 07:37 PM   #1248
1982 28' Airstream 280
Redwood City , California
I'm outfitting the MH for our 20 year anniversary which we will be spending in Yosemite...Click image for larger version
Name:	ImageUploadedByAirstream Forums1413855348.108521.jpg
ID:	224800Click image for larger version
Name:	ImageUploadedByAirstream Forums1413855373.068945.jpg
ID:	224801Click image for larger version
Name:	ImageUploadedByAirstream Forums1413855400.035757.jpg
ID:	224802Click image for larger version
Name:	ImageUploadedByAirstream Forums1413855419.122929.jpg
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-20-2014, 09:24 PM   #1249
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Pretty!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 10-20-2014, 09:26 PM   #1250
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Very Nyce.. I have been watching, admiring... well done... well done...
Oh.. and nice work on the AS too!
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-21-2014, 04:48 AM   #1251
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
As Red Green says....."If they don't find you handsome, at least they'll find you handy".
Very sweet job Dean. Congrats on 20 years. My 20th is next year and I'm hoping for a cross country tour.
Cheers
Tony
Old 10-21-2014, 02:26 PM   #1252
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Are your design service available for hire? Spectacular! The glass of shiraz makes it.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 10-21-2014, 08:16 PM   #1253
Originally Posted by Vycan View Post
Pretty!
Thanks Vycan!
Old 10-21-2014, 08:39 PM   #1254
Thanks for watching and admiring cwf!
Old 10-21-2014, 08:44 PM   #1255
Cheers
Tony
I guess I'm lucky...handsome and handy! LOL
Thanks Tony
Old 10-21-2014, 08:50 PM   #1256
Thanks. And thanks for not calling out my "cheap" bottle of Shiraz! LOL! The "two buck chuck" brands are all I can afford after owning an Airstream! I'm itching to do another Airstream motorhome project...I want to see if I'm more then just a one hit wonder!
Can't wait to see what you are going to do with your MH!
Old 10-21-2014, 09:04 PM   #1257
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I think I can do some of what you did... and realize there are things I just can't do anymore... Might as well go camping... =)
But, if the 'fever' ever bites, it will take lots of stitches and therapy..
Channing
WBCCI# 30676
Old 10-21-2014, 09:25 PM   #1258
Well, here is some of my progress today...
MH has a driveshaft vibration at about 65mph. Not to bothersome since I usually drive between 55-60. I dropped the rear driveshaft section this morning to check the U Joints and the center bearing. All the U Joints feel good. Center bearing also feels good. I couldn't actually pull the rear driveshaft however. I can pull the slip joint out only about an inch and it won't come any further. Anyone know what the deal is here?
The only thing is see or feel is about a 16th of an inch movement in the parking brake hub/trans yoke. I'm wondering if that is enough to cause the vibration at 65mph? I will have to remove the parking brake at some point since I have a leak at the rear tranny seal.
When I drove into town a couple weeks back for the smog check, I noticed a slight brake noise under about 5-10 mph, so I took a look at the brake rotors and pads. Both sides of all rotors look good. It is almost impossible to see the pads, but I can see the pads a bit on the front...they look new! Only a few thousand miles since brake job! Crossing this one off the list.
I took the little portable BBQ out of the outside bin, disassembled and cleaned it. Fired it up to test. I know we can know BBQ the ween's and steak dinners!
I built my third gen-turi today. First one was with leftover 4" pipe. After Burning Man last year, I tossed out a lot of crap..just no place to store it all. The 4" gen-turi went to the dump as well. For Burning Man this year, I made a 2" gen-turi, it worked but I really felt a 3" was the way to go. I'll test it tomorrow. I really do need a gen-turi. I can't run the Onan genset for more then 10 minutes without exhaust setting off the CO detectors. Oh, I lined the bottom six inches with a piece of sheet metal I had sitting around. My 2" deformed a bit from the exhaust heat!
I put together one of those cargo carriers for the rear hitch. I know but please don't judge me too harshly! LOL I think it is going to be a bit better to not carry my portable generator and gas inside the MH this trip!
I also put a new carpet on the outside step. It amazes me how quickly I go through those.
I still have a long list of to-do's, but they are mostly small items.
In stead of posting this, I should be watching my home town team kick ass at the World Series...that would be the Giants of course! But, I find watching baseball on TV just isn't my thing and besides its just so much more enjoyable sitting in the captain's chair of the MH with a cocktail in hand and listening to Carole King on the stereo!
Old 10-21-2014, 09:29 PM   #1259
Name:	ImageUploadedByAirstream Forums1413948529.152984.jpg
ID:	224884Click image for larger version
Name:	ImageUploadedByAirstream Forums1413948555.692882.jpg
ID:	224885Click image for larger version
Name:	ImageUploadedByAirstream Forums1413948581.276542.jpg
Old 10-21-2014, 10:14 PM   #1260
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The top photo.. is that a pillar block.??.. i wonder if that bearing is going..?
Channing
WBCCI# 30676
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
