Old 08-24-2014, 08:20 AM   #1219
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
When everyone sees my Airstream they all comment on how HUGE it is, that's until I show them a photo from my 1st camping trip parked in between to 40' SOB 5th wheels. Then the Airstream looks like a Matchbox!
Have fun at the 'Burn'!
Derek
Old 08-26-2014, 01:27 AM   #1220
1982 28' Airstream 280
Redwood City , California
Derek, you should be here at Burning Man with us! We are on the playa at BM. Woke up this morning to lightning, thunder and hail. Neighbor is kind enough to be providing wifi...imagine that way out here in the desert! MH is working flawlessly.
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 08-26-2014, 11:03 AM   #1221
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Sounds like the dust and heat should be down.
Air Dog is offline   Reply With Quote
Old 08-26-2014, 05:22 PM   #1222
Yes, so far temps are perfect and no wind nor dust!
Old 09-01-2014, 10:47 PM   #1223
Name:	ImageUploadedByAirstream Forums1409629275.498721.jpg
ID:	220558Click image for larger version
Name:	ImageUploadedByAirstream Forums1409629385.700373.jpg
Burning Man 2014, another successful trip! Only issue on the trip this year was a rotted fuel return hose from the mechanical pump to the hard line. I replaced those lines only a year ago so didn't have any extra fuel line with me...mistake of course. I cut out a section from the genset fuel feed. Got home with no other problems!
Old 09-05-2014, 10:29 PM   #1224
Burning Man 2014
A few images...
ID:	220934   Click image for larger version
ID:	220936   Click image for larger version
ID:	220940   Click image for larger version
ID:	220942   Click image for larger version
Old 09-07-2014, 05:40 PM   #1225
Can't wait to get the MH out there again...soon!
Old 09-07-2014, 06:37 PM   #1226
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
I am guessing the clear plastic drop behind you is so the Dash A/C is functional instead of blowing cold air a few inches.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 09-07-2014, 06:45 PM   #1227
Yes! Someone on the forum had mentioned that they do this...thanks to that person! This really did help out. I bought a $5 clear shower curtain and some Velcro. I didn't want to do anything permanent nor spend a lot of money before I tried this out. The Velcro tape didn't stick well, but it was good enough for the trip to Nevada and back. I will try to figure something out to be able to do this again.
Old 09-10-2014, 09:03 PM   #1228
crazeevw's Avatar
Maybe I haven't been reading enough about your Burning Man preparations, but am I seeing a solar panel set-up on trailer behind your Airstream? Was it able to keep your batteries topped off without having to use genset? At least until roof air was needed?
Thanks, Derek
Old 09-11-2014, 09:55 AM   #1229
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Glad you made it home ok.
We did too.
It was nice to meet you.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-12-2014, 03:41 PM   #1230
We did too.
Regards,
JD
Hello JD,
Alex and I both want to say hi to you and your wife! Thank you so much for stopping by and introducing yourselves. We really enjoyed meeting you. Glad you got home safe and sound. Other then the fuel hose, it was smooth sailing for us. I'm glad I have as part of my checklist to do a under chassis inspection with engine running. I was leaking so much fuel that it would have caught fire and we would have had to declare it as a burning art piece! Hope to see you folks again some day!
Dean
Old 09-12-2014, 04:14 PM   #1231
Thanks, Derek
I've been using the solar panels for a couple years now when we go to BM and Yosemite. A couple years ago, Costco was selling this unit from Coleman. It is a 65 watt system.
If I had the money, I would have myself a 300 watt system and if I had just a little bit of money, I would have as a minimum system 150 watts. But this was inexpensive and it is still working!
This 65 watt system provides about 3 amps when panels are clean and in direct sun light. My MH with basically nothing running but the refrigerator electronics, propane leak detector and well I don't think anything else, requires about 1.5 amps. In that situation, the system will then only be charging the coach batts at 1.5 amps per hour. Not enough to charge batts from much of any a discharged state.
I'm guessing that throughout a day/night, I use about 30+ amps and that is with very little usage of MH lights, water pump and the fans ( up to three of them). If the panels got a good ten hours of sun light, that would only give me about 15 amps of charging over the basic amp requirements.
I bring with me a Yamaha 2000 portable generator and when I'm at Yosemite, I probably run it about three hours a day total to keep the coach batts charged. At BM, I'm running the Yamaha a lot! Everyone does, so no need for me to fret. I have 110v led string lights and a "small" boom box that I use a lot as well as run the interior fans when there is no dust clouds visible. I have another batt and an inverter on my flat trailer. I charge this batt with the generator too. But, I discovered this trip that that batt will no long charge, so I used the generator a bit more this year.
I used about 5 gallons of gas for the Yamaha 2000 over the week. No problem since I brought an extra 25 gallons of gas with me. I think the Yamaha burns about a gallon every 8 hours, where the Onan genset I believe burns about a gallon an hour.
I did use the Onan genset twice so that we could run the rood A/C to cool down the MH on two late afternoons. Hell why not, the super rich millionaires at BM have electricity 24 hours a day and run their A/Cs 24 hours a day! At the higher altitude, the genset runs pretty rough until it's warmed up and I finally adjusted the mixture screw so it wasn't pumping out so much black smoke!
Speaking of batteries, my iPad I'd about to die so I'll post this and maybe add more later.
Old 09-12-2014, 06:43 PM   #1232
My solar panel mount...
Nothing fancy nor expensive here. I manually turn the panels toward the sun throughout the day. I use my tie downs to secure it against the wind.
ID:	221606   Click image for larger version
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 10:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 09:32 AM
