06-02-2015, 06:56 PM
#1421
_
, _
Originally Posted by wxbuoy
awesome blog!!!
Thanks Dave and Felicia
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
06-05-2015, 09:17 PM
#1422
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by dadstoy
Hi All,
I've been working forever on building my Project Airstream blog. I finally got it far enough along to put it on line. I've shared many of the renovation projects and travels that I have done with "Dad's Toy".
Please feel free to visit and I hope you enjoy the experience! Come back often since I intend to periodically update the blog with new projects and travels!
project AIRSTREAM | My Airstream Experience
Dean,
you set the bar pretty high with your fine work!
AIR #13
06-05-2015, 09:55 PM
#1423
_
, _
Thanks Peter, you're too kind!
06-09-2015, 04:43 PM
#1424
Pinson
, Alabama
Dean, StarLord here, U may call me StarDude, or Rich - I just finished reading all the post, page 1 to 102 (walking pneumonia needed something to do), you are my new Hero !!! What was ur career before becoming a master electrician, master plumber, master designer, master fix it all !!! I am envious of ur talents as well as the friends with all the suggestions, answers, support!! I just purchased a 1979 Excella Motorhome. It is truly a 1979 inside. I'm the third owner. There are only 27,000 miles on it and 51hrs on the 4.0 Onan generator . I've learned alot and save alot of the info all have provided. You said looking for another project, he he he ! As soon as this sickness is gone I'm going to start working on the '79 !! In back of my mind is this voice saying, "What have you gotten ur self into, dummy"!
06-09-2015, 09:18 PM
#1425
_
, _
Dad's Toy
Thank you Star-Lord. Congrats on your new "project". Hopefully you don't regret it after a few years of work and money put into it! . Post lots of pics for us all to see.
It's a great group of people here on the forum with lots of experience and they have helped me out many times.
I am/was a software engineer in Silicon Valley until I woke up one day, looked at myself in the mirror and asked "really?". I've always enjoyed working on "real" world things, probably more then working in that virtual world. I'm actually at the ranch property right now with a list of things to do to the MH and my other toys. It was 106 degrees here today so I napped until it cooled down this evening, but I awoke to a lightning and thunder storm directly overhead! Now everything is wet and temp dropped to 75.
Get well and get out there and work on your new toy!
"I am Groot"
Dean
06-18-2015, 07:19 PM
#1426
_
, _
Driveshaft Carrier Bearing
I picked up two driveshaft carrier bearings...hopefully one of them is the correct one. Looks like the only difference is the shaft diameter.
My parts man and the machinist said that the bearing needs to be pressed off and on.
For those that have actually changed their carrier bearing(s), do you know if it does need to be pressed off and on?
I was going to pull the driveshafts and take it into the machinist to have it done but the 103 degree weather on the last day I was at the ranch just made me lazy instead!
06-18-2015, 07:49 PM
#1427
1982 28' Airstream 280
Port Angeles
Yes it is pressed on. Not a real hard press, sometimes if you can find a pipe or steel tube the right size you can drive it on with a good size hammer but if not available take it to a shop. A good time to check the u-joints while you are there.
Cheers, Dan
~ Margaret Thatcher ~
06-25-2015, 05:32 PM
#1428
_
, _
Summer Arrived with 106+ Temps
I just spent a hot ten days in the motor home at the ranch property. When summer hits in the north state, it hits big. Almost every day, we had temps over 100 degrees and many days with it topping out at about 106.
(I had this thermometer sitting outside, so 106 was the outside temp)
On the third day a weather front came in, dropped the temps to about 80 and brought with it lightning, thunder, rain and fires! The temperature went right back over 100 the next day. We had a lightning strike on the property about 3 miles out as the crow flies. The resulting fire grew to 10 acres before Cal Fire got it out.
I have posted more (and more pics) on my blog...
Summer Has Arrived! | project AIRSTREAM
07-01-2015, 01:10 PM
#1429
_
, _
Northern Minnesota
I came across this website and blog today on this couple that has been Airstreaming around the country. Last year they spent some time in Northern Minnesota. My family is from Minnesota and I was born there. My Airstreaming days began on the lakes of Northern Minnesota and this story brings back memories of a youthful, innocent time!
My mom and dad in their later years had spent many a summer with Dads Toy sitting on the shores of some of the best lakes in the land fishing for northern pike and walleye. My memories of my childhood there are fading and with my mom and dad now gone, the family stories of a time past are no longer told.
Someday, I will travel myself with Dads Toy to the land of my birth. The Resorts and Lodges of Northern Minnesota | The Democratic Travelers
07-01-2015, 01:40 PM
#1430
1995 36' Classic 36
Ludington
, Michigan
Dad's Toy
We will be heading home through the upper peninsula of Michigan and across northern Minnesota in a couple weeks. Hope to spend a couple weeks meandering back. Some of the neatest places we found have been when we were lost. Ann punched snake creek into the GPS to find a campground we stayed at a couple years ago. I knew the mileage and route didn't jive but I learned to keep my mouth shut. Ended up in the wrong Dakota but found a really nice place to camp outside Mobridge.
Any suggestions for our way back?
07-02-2015, 01:00 PM
#1431
_
, _
A Time Past
Yesterday, I was going through a very large box of old photos and I came across a few from a time past that I thought I would share. These are all probably from the late '80s. First one is probably taken in Minnesota with my mom and myself. Next is my niece who is now 31 yrs old. Next was the home of "Dad's Toy" in Eugene Oregon. I don't know where the last two were taken but of course on some trip my mom and dad took.
Also take a look at my Airstream blog if you feel so inclined...
http://projectupdraft.com/airstream/
07-09-2015, 12:03 PM
#1432
_
, _
If you travel through northern Minnesota and happen to be close to Sauk Centre, they have a beautiful city park with RV spaces...some with full hookups. Sauk Centre is off Hwy 94. I learned to fish on this lake. As a youngster, we spend a lot of time there. My dad was born there. The house he was born in is a few blocks from the park and it is still owned by family.
Campground - Sauk Centre, Minnesota *
I've also spent a lot of time in Brainerd and Walker. My mom's family used to be there.
07-27-2015, 10:17 PM
#1433
_
, _
Every 90 days I have to move my MH to another space at the ranch. This is a regulation of the CC&Rs so owners don't establish permanent residency. Oh how I could go on about this!!!
Well, Thursday is my 90 days and I'm heading to the ranch on Wednesday. I've already made arrangements with my neigbor whom I "swap" spaces with so no changing of the date.
So....
Checking the weather up in the North State for this week...
Holy @@@@!
07-28-2015, 04:11 AM
#1434
1982 31' Airstream 310
champaign
Whoa, and I thought it got hot here in central Illinois. Hopefully you dont have the same 80-90% humidity as we have. Are you able to get the rig in some shade on the ranch?
What is a CC&R?
07-28-2015, 06:01 AM
#1435
Richmond
, Kentucky
I certainly hope the 0% in the right column means humidity
1975 24' Argosy Motor Home
07-28-2015, 09:47 AM
#1436
_
, _
0% chance of rain
about 20% humidity
CC&R - Covenants, Conditions & Restrictions - The HOA (home owners association) governing documents.
100% chance the roof A/C will be useless in temps over 105 degrees
65% chance of a smokey weekend from a fire somewhere
07-28-2015, 04:24 PM
#1437
Richmond
, Kentucky
How's that old saying go?......"but it's a dry heat..." yeah right!
07-28-2015, 04:32 PM
#1438
_
, _
I still fear that the heat is going to kill me!
At least we have our own volunteer fire dept with trained paramedics!
07-28-2015, 06:10 PM
#1439
Richmond
, Kentucky
That is definitely a plus
07-28-2015, 08:37 PM
#1440
1999 34' Excella
Hillsboro
Yes, it is called an "oven".
Peace and Blessings..
Channing
WBCCI# 30676
