Old 02-11-2013, 09:16 PM   #953
1982 28' Airstream 280
Redwood City , California
I have the floor all prepped and the new plywood cut and ready to go in. Two of the seat belt bolts were rusted. I ended up cutting them part way through with my multi-tool and then using an impact wrench to break the bolts. Its a really fun job when it requires two people and there is just me!
ID:	178810   Click image for larger version
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 02-11-2013, 09:37 PM   #954
Originally Posted by crazeevw View Post
Dean,
This makes me want to start checking my fresh water filler as well. Figuring after 24 years maybe it's time???
Thanks, Derek
I would bet it is cracked and leaking. This is what did all the floor damage under my couch and water tank.
Old 02-12-2013, 07:12 AM   #955
Dean,
Thanks, Derek
Derek,
Your water fill door is a different model than Dean's. Doesn't mean you won't have problems but don't expect to see the same configuration as Dean's.
Old 02-12-2013, 07:17 AM   #956
Dean,
I was able to use vice-grips on the top side of the seat bolts with a wrench or socket on the lower side.
I didn't realize the multi-tool could cut steel bolts. I'll have to try cutting one sometime.
Old 02-12-2013, 11:22 AM   #957
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
The exact replacement fresh water tank (same as original from original supplier) from Inca Plastics is $295 delivered. I was expecting a lot more. I'm seriously considering replacing that original 30 year old tank.
My 66 Tradewind tank was made from plastic (poly something). I tried repairing it with epoxy and then it leaked again and I had to clean up another mess (wet carpeting). I ended up replacing it and now I carry the spare tank in the bed of my truck for camping while boondocking.
Bite the bullet and buy a new tank (my recommendation based on experiance).
I have followed and admire all the work you are doing on your dad's toy.
Dan
Old 02-12-2013, 05:12 PM   #958
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Dan
I gotta agree, better to do it right the first time. Plus, you are spending all this time and $$ why not do it right and make it last another 25 years.
That is the mentality that I am doing mine with. Granted I probably will just have a motorized tent when I am done since it will have been so long I won't have any idea where things went!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 02-12-2013, 07:12 PM   #959
Originally Posted by bkahler View Post
Derek,
Post a pic of the water hatch for the 345. I'd like to see what it looks like. Thanks.
Old 02-12-2013, 07:14 PM   #960
Dan
Dan, thank you so much for the nice comment.
I have decided to order a new fresh water tank!
Old 02-12-2013, 07:17 PM   #961
I agree too! But, lets change the two $ signs to three $ signs! LOL
Old 02-12-2013, 07:25 PM   #962
Oh the smell of fresh plywood is much better then the smell of 30 year old rotted plywood!
I got the new floor under the couch/water tank installed today. My best friend for the day was a sledge hammer and a large block of wood. I also reinstalled the couch frame. I replaced the plywood skirt on the bottom front of the frame. The frame rested on this skirt and after 30 years, it was not holding up any longer. I added two aluminum legs on the inside front of the frame to take the weight.
I also epoxied the heck out of the fresh water filler today and will do more tomorrow.
ID:	178862   Click image for larger version
Old 02-12-2013, 07:34 PM   #963
Here are a couple other things I recently have done.
I lined the back walls of both bedroom closets with cedar and put wire loom around the TV cables. I also put new carpet in the closets.
I also made a small pan for the water pump to sit in under the kitchen cabinet. One thing I seem to always be dealing with are leaks in the water pump fittings.
ID:	178864   Click image for larger version
Old 02-12-2013, 07:46 PM   #964
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Dean,
No way to get inside view this late. This is what I have.
Derek
ID:	178867   Click image for larger version
Old 02-12-2013, 07:49 PM   #965
Here ya go, only picture I can find.
Old 02-13-2013, 05:43 PM   #966
We have Burning Man tickets! Yay!
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
