Old 01-20-2013, 08:52 PM   #897
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by dadstoy View Post
Entertainment Center...
I really wasn't happy with my entertainment center I built awhile back and after adding the leveler control and an air pressure gage as an after thought, it was time to redo it. I always felt that it just didn't look right for some reason. It eventually dawned on my why...it had square corners. There is nothing square cornered about an Airstream! I recessed the speakers, mounted the equipment different and rounded all the corners. There will be some switches added shortly as well.
This is what I did for the console of my old 79 with room for more gauges on the right.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-20-2013, 09:00 PM   #898
1982 28' Airstream 280
Redwood City , California
That looks good. My '82 had the same console. I never understood the cup holders in the back though!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 01-21-2013, 06:59 AM   #899
There doesn't look like any internal damage, but I paid for a new one so I'm sending this one back!
Duh, that makes sense! I sometimes wonder where my mind is at when I post a response
I'm going to go outside and work now...
Old 01-21-2013, 07:04 AM   #900
Propane Regulator...
The old regulator was been leaking for about 3 years! Oops! I also think my appliances where not working properly due to low pressure. I had a new 12" hose to replace the old one as well, but I didn't have all the fittings I needed. It's at least a 2.5-3 hour trip into town and back and $30 in gas. So I used the old hose which is actually in good shape. The old hose is actually too long and it hung down underneath. I rerouted it a bit so now it should be out of the way of any flying debris from the front tire. The electric solenoid is a shutoff valve controlled by the propane/CO detector.
Dean, interesting idea on the shutoff valve. Did the system come that way or is that something that you or your dad installed? I really like the idea and just might do something similar.
Old 01-21-2013, 10:19 AM   #901
The valve comes with a particular model of the Safe-T-Alert propane/CO detector. The detector controls the valve.
Old 01-21-2013, 02:16 PM   #902
Good news on the furnace...
I emailed the vendor this morning and they replied within an hour. They have scheduled the pickup of the damaged unit and will ship a new one tomorrow. Not only do they have the best pricing but that is awesome customer service!
Old 01-21-2013, 10:17 PM   #903
I pulled up the carpet in the salon area today and found a small area of the floor behind the passenger seat rotted out. I had suspected that my windshield leak is coming from the front of the awning rail and i think this confirms it.
Any suggestions/advice on repairing this? Does the shell sit on top of the plywood?
ID:	177171   Click image for larger version
Old 01-22-2013, 05:20 AM   #904
Airstream Driver
1997 30' Excella
Images: 51
Dean, it may be time to pull the wall panels and sit there during the next big rain. I have used small funnels and drain tubes around the front seat areas before to manage small persistent leaks. I wouldn't worry too much about the small wood rot. If you fix it and seal it watertight further water intrusion may damage the new carpet/flooring
1996 Airstream B190
AIR #13
Old 01-22-2013, 07:48 AM   #905
Dean,
See attached PDF that lays out the construction of the floor and walls.
Along with the sketch that I made you'll find that there are a lot of phillips head screws going from aluminum channel into the wood. The red bolt in the sketch is about 2 plus inches long and has a nut and lock washer on the bottom side. On the 345 that I dismantled the wood floor was also fastened to the 1" x 2" tubing grid throughout with 1/4" flathead self tapping screws AND spiral nails. The nails were a real bear to get out. I ended up having to torch the heads of the nails before I could get the wood floor off.
typical-airstream-mh-construction.pdf
The 1" x 2" steel grid is attached to the truck frame with steel rivets. The grid was laid down on top of the truck frame and riveted in place, then the aluminum/galvanized sheet was laid on top of the frame and then the entire shell with the wood floor was laid down on top of the grid and bolted in place along the edges and then screwed and nailed to the 1" x 2" grid. This is how the 345 was constructed so I'm guessing your coach is very similar. It appears that my Argosy is built along these same lines although I'm not sure if it was a single sheet of plywood or sections. I know the 345 is one long piece of wafer board.
I'll try and post some pictures this evening showing how the 345 was constructed.
Hope this helps.
Old 01-22-2013, 06:56 PM   #906
Switches...
I'm replacing some 12v light switches while I have some things apart for the floor repair. Anyone find any new modern switches that they like?
Old 01-23-2013, 07:51 AM   #907
Switches...
Heck, my Argosy just has cheap toggle switches all over the place so just about any switch would look better than that!
You might go to digikey.com and browse through their online catalog. They have a gazillion switches listed.
Old 01-23-2013, 03:57 PM   #908
huberto's Avatar
1979 24' Airstream Excella 24
Monterey , California
Very Disappointed - New Furnace is Smashed In...
I purchased a new Suburban NT34SP from an RV company in Texas. It was shipped from some warehouse in So Calif. I just went to open the box and prepare to install it. The entire left front side is smashed in.
I guess I'll cash in my 401k and head down the mountain tomorrow and buy one from CW. ;(
I had the same experience. Suburban 30SP thrown into box like a sack of potatoes. Had dents and probably dangerous. The Company send a replacement right away and a call tag to pick up the damaged unit too.
Perhaps the same Texas Co. (PPL Motorhomes)
huberto is offline   Reply With Quote
Old 01-24-2013, 03:24 PM   #909
Auretrvr's Avatar
Iowa City , Iowa
Localized subfloor repair
On my '83 310 there was a hat-sized rotted place under the driver's side window. It looked a lot like your photo...
We poured a wood hardener (Ace Hardware) liquid onto it and then filled it with fiberglass. Most all the wood in the rest of the coach was quite solid, so we didn't want to do any tear-out.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 01-26-2013, 12:56 PM   #910
Peter, you may be right about needing to pull the inside panels. We had a mild rain a few nights ago and I'm definitely still leaking in that up front corner. Its leaking too much to let it go.
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
