Old 10-13-2012, 02:55 PM   #827
1982 28' Airstream 280
Redwood City , California
Hydraulic Leveling Jacks...
The jacks didn't work on the last trip, they wouldn't deploy. The pump worked but jacks did not come down. I looked though the manual and it said for this condition a fuse is probably blown on the wiring harness. I have the three jack system from Power Gear. It was not original to this MH...my dad had it installed at some point. The pump, reservoir and solenoids are installed right behind the front right tire. There is a custom made cover to protect the unit from dirt and water. I pulled the cover today and found the +12 volt wire between the 12 volt side of the pump solenoid and the fuse was broken. I'm sure it occasionally grounded itself again the body!
I spliced in a new fuse and wire, placing the fuse on the engine side so it can be changed in the future through the dog house. The jacks are now working. I've got to run into town on Monday for zip ties and 9 quarts of ATF Type A so I can straighten up the wiring harness and change the fluid in the pump reservoir.
ID:	170159   Click image for larger version
ID:	170161   Click image for larger version
ID:	170163   Click image for larger version
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-14-2012, 05:44 PM   #828
Power Steering Pump...
I got my leaky power steering pump out today. I will take it and the high pressure hose into town tomorrow and see if I can get myself a rebuild. It's not too bad of a job getting the pump out. The worst is dealing with the messy fluid!
To start, I removed the entertainment center and the access panel at the front of the dog house. I loosened the a/c pump and power steering pump in order to remove the belts. I also removed the alternator belt since I'm going to change the fan clutch for the third time. To loosen the a/c, I pulled the dog house back a bit and moved the air cleaner to the side. To remove the power steering pump, I removed he adjustment bolt on the top from the dog house side. Then removed the bolts from the block on the lower pump bracket. I also removed the oil pressure sender before this last step. I disconnected the high pressure hose at the back of the pump and cut the two return hoses. I let the fluid drain for awhile at this point. I disconnected the filler hose up top at the reservoir. I pulled the pump down a bit and then removed the lower bracket from the pump. I also had to disconnect the high pressure hose from the hydoboost unit since it is sort of wrapped around the hose clamp of the return hose at the pump. Then I pulled the pump and hoses out from the bottom and made myself a nice mess on the ground!
ID:	170303   Click image for larger version
ID:	170305   Click image for larger version
ID:	170310   Click image for larger version
Old 10-14-2012, 05:57 PM   #829
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I'm assuming you're replacing both lower steering hoses?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-14-2012, 06:07 PM   #830
Yup, I'll replace all the hoses. There is a high pressure hose from the back of the pump to the hydroboost unit, metal line from hydroboost to power steering gear box, hard line from power steering gearbox to half way to pump, then bulk hose from this hard line to return on pump. There is also a bulk hose from hydroboost to another return line on pump.
So there is only one high pressure line and two low pressure return lines (bulk hose with clamps).
Old 10-14-2012, 06:16 PM   #831
Mike Leary's Avatar
Images: 11
Excellent idea, while you're at it to replace all the hoses. I had one my lowers spring a leak, boiled the fluid and almost melted the electrical harness that was next to the filler canister.
Old 10-15-2012, 01:15 PM   #832
Nice write-up Dean!
I was under mine last week, and can see fluid dripping off the bottom of the pump body, so will be doing that when I get into the engine... and that will be soon!
Take a look at these for longer lasting solutions!
http://www.summitracing.com/parts/SUM-G3160/?rtype=10
BTW...
On the subject of the NLA radiator hoses....
I found these, and wondered if they could work...
Goodyear EPDM hose kit for C/K series.. and only small block, but worth looking at lengths and diameters...
http://www.summitracing.com/parts/GTR-5004/
Or these universal flexible SS pipes...
http://www.summitracing.com/parts/SU...n/?prefilter=0
Old 10-15-2012, 03:04 PM   #833
Originally Posted by Keyair
Nice write-up Dean!
BTW...
Thanks Steve. The power steering hose looks nice, but too pricy. I think the stock replacement will last the remainder of the MH's life or at least mine! I love the blue color of the radiator hose, but they aren't close to the originals. The lower hose might have the correct V bend but would have to be mixed with other end sections. It's possible that flexible hose may work, but the bend in the lower hose is a good bend. The upper also needs a hard bend to keep it off the a/c belt.
Well I took the power steering pump and hoses into town this morning for my parts guy to find the parts for me. I will make another trip into town tomorrow to pick up the parts. Let's see, two round trips to town and back...about 10 gallons of gas at $4.49....oh my!
Old 10-16-2012, 06:52 PM   #834
My parts run today yielded the following...
Rebuilt power steering pump
(I had the machine shop install the mounting bracket and the pulley)
High pressure power steering hose
Low pressure return hose and clamps
Power steering filter
Gallon of power steering fluid (so I can flush the system)
New AC Delco fan clutch (third time is the charm, right?)
Engine fuel filter
GenSet fuel filter
Electric choke for the Quadra-Jet
10 quarts ATF to drain and refill the hydraulic leveler reservoir
Believe it or not, that's $500 dollars worth...Yikes!
I see a busy day tomorrow!
ID:	170446   Click image for larger version
Old 10-16-2012, 06:57 PM   #835
I haven't heard of these before? Tell me more!
For some people...
Unfortunately I believe it
Have fun tomorrow. At least you're doing something productive, wish I was.
Old 10-16-2012, 07:31 PM   #836
For some people...
The stock system doesn't come with a power steering filter so this is an add on. It is highly suggested these days to add a filter. It is a filter specifically for transmissions and power steering...looks like a large fuel filter. It's put in the return line so it is under low pressure and easy to install in one of the return lines since these lines are bulk hose with hose clamps. Probably helps to keep junk out of fluid that might damage the pump vanes and seals.
We were hoping to hit the road again and head to Yosemite before the snow falls. Would have done that except for that damn PS pump...the rest I could have lived with.
Old 10-17-2012, 08:01 AM   #837
When you have a chance could you post the part number for the filter?
Do you know if the filter has an internal bypass valve? I'd hate to have it plug up over time and reduce flow, especially for a transmission.
Old 10-17-2012, 08:56 AM   #838
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Brad,
B&M makes a nice remote trans filter kit. I comes with a spin-on filter adapter.
While I was looking at Summit's trans filters, I found a WIX inline filter, too.
Vaughan
Old 10-17-2012, 09:05 AM   #839
Actually I already have a remote filter for the transmission made by Derale. I was more surprised by the filter for the power steering pump. I had not heard of those before. My concern with any filter inline is whether it has a bypass or not. If it doesn't then as it starts plugging you will get reduced flow.
The inline filter from Derale has a byass in the filter itself just like engine oil filters do.
I'd hate to be driving and have my power steering start acting weird because of reduced flow through the filter back to the pump.
Old 10-17-2012, 09:41 AM   #840
Here's the manufacturer's web site for the filter. It is basically the same as the WIX shown by vswingfield. It does have a safety by-pass. Part number is JX-160.
http://www.magnefine.com/html/filtration.html
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
