Old 01-22-2012, 09:09 PM   #295
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
My water leak for the back window was around the aluminum term at the joint "corner" I sealed the joint and it stop the leak
alfalsetto is offline   Reply With Quote
Old 01-22-2012, 09:15 PM   #296
Yes, thats possible too, Al.
I just sealed the hell out of everything, and so far its been dry.
As I said, that snow stuff acts like a poltice, and if there is a weakspot, it will hold the moisture there until it wicks thru by capillary action!
Old 01-22-2012, 10:22 PM   #297
alfalsetto's Avatar
Your right on
Old 01-23-2012, 11:24 AM   #298
1982 28' Airstream 280
Redwood City , California
Had a little scare last night. I looked out the windshield about midnight and saw tree branches on the windshield. We had about 3 inches of wet snow and the weight pushed a couple of big tree limbs down on the MH. All looks ok this morning...limbs are 5 - 10 feet back up about the MH.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 01-23-2012, 11:33 AM   #299
Worrisome indeed!
Great Pic tho... were you warm??
Old 01-23-2012, 05:56 PM   #300
Originally Posted by Keyair
Worrisome indeed!
I have two portable electric heaters and the furnace going. I do turn them down a bit at night and keep it about 64 degrees.
Old 01-23-2012, 06:01 PM   #301
Well the rain and snow this last week was a disaster. Pulled up the carpet in bath and bedrooms. At least I can check out the hatch over the gas tank!
ID:	149444   Click image for larger version
Old 01-24-2012, 07:17 PM   #302
Its drying out a little bit here so back to the air compressor and air lines. I built a divider for compartment so elect cord and water hose won't be laying up against the compressor. Last week, I treated the compartment with a anti rust chemical. Its still too cold and damp to finish prepping and painting the compartment, so will pull out compressor at some time in near future and finish that. Hopefully I can install new air lines tomorrow. I had also stripped and repainted the old Square D pressure switch. I also built a new mount for the air compressor.
ID:	149520   Click image for larger version
ID:	149522   Click image for larger version
Old 01-24-2012, 08:56 PM   #303
alfalsetto's Avatar
To me it looks like your doing a great job
Old 01-24-2012, 09:34 PM   #304
thanks Al
Old 01-24-2012, 09:40 PM   #305
Pump looks similar to mine Dean, what did you do to it?
Old 01-24-2012, 10:11 PM   #306
the pump was working fine, so didnt have to do anything to it. I'm replacing all the air fittings and I wire wheeled the release valve to remove the rust on it. I put on a new check valve about 6 months ago. The pump is a great pump. It is a heavy duty continuous duty pump. The manufacture still makes basically the same pump. The solenoid works fine, but it was all rusted up, so took a wire wheel to that as well and am painting it now.
I put the new air tank in last week and i will run and hookup the new air hoses tomorrow.
Old 01-25-2012, 07:48 PM   #307
I installed the new air lines from the compressor to the air tank, air bags and air horn. Also installed an inflation valve so I can manually pressurize the system.
I pressurized the system to 100 pounds with my garage compressor. The air bags inflated. I will see how much pressure remains in the system in the morning.
I have some "new" old parts to install tomorrow.
Old 01-26-2012, 10:44 AM   #308
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
My air bags in the rear
I don't have an extra tank.....just air directly to the bags!!!!....Is that possible? That is what they are telling me at the repair place....replaced the air bags from Michigan.....paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
