Old 01-19-2012, 07:34 PM   #281
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I get around 14 mpg. on the road!!
alfalsetto is offline   Reply With Quote
Old 01-19-2012, 08:34 PM   #282
2006 30' Classic
st louis , Missouri
What is the model on post 254 with the back lift on the airstream?
2wired is offline   Reply With Quote
Old 01-19-2012, 11:56 PM   #283
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Thanks Guys on the propane prices and amounts... I had no idea, as the PO filled the Propane before I took her back to CA!
Still have 3/4 full!
It scares me to think that the only part of my moho that has appreciated in value since I bought it might have been the fuel that came with it. Unfortunately, I used that up before I got it home.
There must be a joke that starts out.... What do mohos and investments have in common? Answer: NOTHING.
streamquest is offline   Reply With Quote
Old 01-20-2012, 05:24 PM   #284
1982 28' Airstream 280
Redwood City , California
Installed the new drapery end caps and mounted the new valances. They look sharp with the new drapes. Now need new day/night shades.
ID:	149272   Click image for larger version
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 01-20-2012, 06:05 PM   #285
Got to hate those water leaks!
Along with the windshield, my bath carpet is soaked again. Just don't know where the water is coming from in the bathroom. I do think it is leaking from outside. Time to drink a couple of beers!
Old 01-20-2012, 06:31 PM   #286
Snow is the worst thing as it holds the wet in places it normally would not plus the weight will not help!
Your layout is different to mine, but have you checked your sewer vent seals?
Old 01-20-2012, 07:20 PM   #287
I replaced the sewer vent seal a couple months back and it is located on the left rear side. My leak is on the right rear. Left rear corner is dry. Bath closet is in the left corner and I can get to subfloor there...all is dry. Shower tub is on right rear where the leak is. I also sealed the bath roof fan a month back.
It could be the shower plumbing or an outside leak on that side. I'm heading down the mountain and into Redding tomorrow to visit Harbor Freight to pick up an inspection camera.
Old 01-20-2012, 07:27 PM   #288
Or that old classic, white spay foot powder....
I have a sewer vent on each side...
Old 01-22-2012, 03:18 PM   #289
Using my new inspection camera, I think I have pretty much ruled out the water pipes to the shower valve. Floor is wettest directly in the middle of the right rear corner. Maybe leaking at the taillight? I'm getting very frustrated with soaked bath carpet. Can't do anything outside...it's been raining/snowing since 7am this morning. Snow is just now beginning to stick.
ID:	149385   Click image for larger version
Old 01-22-2012, 03:51 PM   #290
Could be a seam, or also the upper marker lamps...
Old 01-22-2012, 04:16 PM   #291
I'm guessing there is a horizontal seam back there...under the belt line/molding?
Old 01-22-2012, 05:31 PM   #292
Yes, there is, under the upper moulding but its an overlap seam, so my money would be on tail lamp, Upper segment seam, or Marker lamp... or maybe even the reaview camera holes or Airstream letters...
The reason I say this is because I had a rear corner leak, and that is what I resealed, and so far... fingers crossed I have not seen any more drips...
The Tail Lamp assembly has a ABS bowl behind it that sits between the 2 skins... any water getting inside that area will run down the inside of the outer skin onto the floor. I sealed mine up good... let me go onto my laptop and see if I can show you what I mean with a pic...
Old 01-22-2012, 06:15 PM   #293
Here is a pic of the rear corner leak...
You can see the streaks where the water seemed to have been running down the inner wall... which puzzled me.
Here is the internals of the tail lamp... I had sealed min, but there was a gap between the ABS bucket, and the outer skin... so any water would drop straight down the gap between...
Old 01-22-2012, 06:49 PM   #294
Thanks Steve. I did pull the taillight and seal it a bit (the best I could do in the rain). Pulling the carpet up now...sooner then planned!
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
