Old 01-16-2012, 09:07 PM   #267
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I'm with you on that.
alfalsetto is offline   Reply With Quote
Old 01-17-2012, 07:52 PM   #268
1982 28' Airstream 280
Redwood City , California
Cleaned out and prepped the rear bin for painting and re-installation of the air compressor. Replaced fuel tank filler hose and prepped area for installation of the new air tank. Also added new task to the never ending list...front hydraulic jack is leaking.
ID:	149111   Click image for larger version
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 01-18-2012, 07:27 PM   #269
Got the air tank mounted today. That was about it for the day due to the rain...might snow tonight!
Old 01-18-2012, 07:48 PM   #270
Do you stay in it up there?
Whats the plan for the leaking leveler?
Old 01-18-2012, 08:40 PM   #271
Yes, I do stay in it here. It is an ownership ranch, 14,000 acres, most of it back country. Been an owner here for 25 yrs now. We have 200 full hookup spaces...first come, first serve. Can put RV on a space for 90 days then must move off the property for 7 days, then can come back on and find an open space. Of course rv's and ATVing are much more popular today then 25 yrs ago, so we are having a real issue with not enough spaces. That's really due to the owners that figured out how to get around the rules by buying two shares and just swapping spaces with their buddies every 90 days...space squatters!
We have bunk houses (cabins) and a small motel as well, but sure is nice to have your own RV. We were going to get a large fifth wheel last yr, but decided to keep the AS280 and fix it up instead...couldn't part with Dad's Toy! Could still get a fifth wheel just for here, but sooner or later there is going to be a issue with our storage lot.
We have shower houses about as well which is good in winter since I have the MH prepped for winter. Might just shut drain valves and hook up water tomorrow though. Electric is covered in the annual assessment payment, so I have electric heaters going in the winter and ac going all summer. Elect must be disconnected when not here though.
I do use the furnace as well and ran out of propane night before last. We sell propane here on property, so I disconnected and drove MH about 500 ft up the hill and got propane today. RV spaces are not level here, but did a better job of leveling MH with large blocks under tires this time so I don't have to raise the jacks as much...had problem with closing the door over the last few days...all better now.
I think the front jack leaks when I extend it all the way...extending it very little now. I have the Power Gear jacks and I believe rebuild kits are still available for the jacks that I have. So may try to rebuild it next summer. Until then I'll just keep cleaning up the mess and topping off the tank with ATF. I did overfill the tank once because I checked and filled with jacks somewhat deployed...not a good thing of course!
Old 01-18-2012, 08:54 PM   #272
Sounds great!
What is the cost of filling the propane tank... I have no idea as mine was full when i bought it!
Old 01-18-2012, 09:30 PM   #273
Sounds great!
My AS manual says there is a 82 pound and a 125 pound tank which is interesting since everyone fills by the gallon and not by weight. I'm assuming I have the 82 lb tank. I was completely empty and it took 24 gallons at $3.25/gallon, so $78.
Old 01-19-2012, 08:48 AM   #274
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Looks like you have the larger tank as it would be filled to 80% ??????
"How much propane is required to fill a propane tank?
80% of the actual capacity."
Dave
"100 pound propane tank will hold 23.58 gallon. 100 pounds / 4.24 pounds per gallon = 23.58 gallons"
Old 01-19-2012, 11:39 AM   #275
Dave
Hi Dave. That makes more sense! I wasn't calculating the 80% fill. I agree, it's got to be the 125 lb tank. Thanks.
Old 01-19-2012, 02:20 PM   #276
alfalsetto's Avatar
My Old Gertrude holds 45 gal of Diesel at $4.05
Old 01-19-2012, 03:27 PM   #277
Sad news is, I bet her 45g of diesel takes you further than our 80g of gas!
Old 01-19-2012, 06:04 PM   #278
Our first storm of the season in the north state of Calif and it is a snow storm!
My windshield is leaking in the middle, drivers side and passenger side. Yikes!
Old 01-19-2012, 06:39 PM   #279
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
If it helps anyone, both our fuel and propane were down to below 1/4 and we tanked in Phoenix on the way south. Took $160.00 diesel @ $3.92 (Safeway) and $80.00 propane @ $3.15. Getting rather pricey down here.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 01-19-2012, 07:03 PM   #280
Thanks Guys on the propane prices and amounts... I had no idea, as the PO filled the Propane before I took her back to CA!
Still have 3/4 full!
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
