Old 12-22-2011, 07:09 PM   #211
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I was at a flooring store today, looked at the cork flooring, thinking replace carpet and hardwood??? Sure looked nice! Your new panels looks great!
Thanks, Derek
Old 12-22-2011, 07:31 PM   #212
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Thinking about cork as well
Thanks, Derek
But wondering if the dog will go skating around when we are on the road.......we have cork in our 68 and love it but we aren't traveling down the road in the trailer with the dog......hmmmm.
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 12-22-2011, 07:55 PM   #213
1982 28' Airstream 280
Redwood City , California
Originally Posted by Mike Leary
Wish I knew what I was looking at, but, really, pink is the way to go these days?
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 12-22-2011, 08:01 PM   #214
I've gotten a lot of opinions on flooring from the "pros" and this forum has a million different suggestions too. The "rose" carpet has to go soon. i was told not to use cork, but can't really remember why...must be getting old...yah, that's it!
I was going to use vinyl planks with the two pre glued sides, but was told that would eventually peel up. I did find a vinyl plank that locks together.
Old 12-22-2011, 10:54 PM   #215
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
I'm not sure exactly what the problem was, but I recently read a post somewhere by a fellow that had installed cork and was removing it for some reason pertaining to poor performance??? .... it might have been a durability issue???
streamquest is offline   Reply With Quote
Old 12-23-2011, 08:11 AM   #216
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I think it was Dan @ Smartstream, maybe he'll chime in.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-23-2011, 08:29 AM   #217
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Cork is awesome
We used cork planks (click together) in one of our little fiberglass trailers. We have a 75 lb dog and a 12 lb dog. The cork performed very well. We travelled through one of the worst rain storms that Alberta ever saw, and the trailer leaked something fierce. Plus we hit bumpy roads, and the fridge opened and cans of beer went flying and burst open. The floor was fine. Cork never mildews. It is very warm underfoot. We notice a big difference in the warm floors of that uninsulated trailer compared to our Airstream. Anyway, we sold that trailer after we bought the Airstream. However, we kept our other fiberglass trailer and added cork floors to it. Now, we are renovating our basement, and you guessed it, cork all the way! When our Airstream floors start to tire, we plan to replace with cork.
We live in a very extreme climate: very hot summers and very cold winters, and cork stands up well. However, we have not used the glue-down cork tiles. I don't think the glue would hold in our climate.
Hope this helps with your decision. I'm enjoying watching your updates!
Best wishes,
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 12-23-2011, 08:58 AM   #218
If I remember right, the salesman said the cork would not hold up to rocks and dirt that one would get in their RV from camping
Old 12-23-2011, 09:08 AM   #219
Best wishes,
Lisa
Hi Lisa,
Sounds like the cork is working fine. I think buying flooring is like buying tires, the salesman tells you what ever they want in order to sell you what they have in the back room. Sounds like your cork has held up to some abuse. I like the thought of warmer floors. I'm afraid the vinyl will be cold on the feet in the winter.
I also have extreme climate changes up in northern calif where I keep the MH. 110 degrees in the summer and 20-30degrees in the winter with lots of rain (however no rain yet this yr). And the MH has to sit long periods of time closed up with no electricity.
I'm glad you enjoy seeing my updates to Dad's Toy!
Old 12-23-2011, 01:03 PM   #220
Smartstream's Avatar
Port Angeles , Washington
Yes I put the cork in and now it's got to come out. We did a four month, 16,300 mile trip http://www.airforums.com/forums/f42/...oad-79445.html and it did not hold up. Now we do travel with a small 150 lb. Great Dane and it also may be a problem with the brand of cork that I used.
When I installed it the vendor told me to put a coat of polyurethane on to better seal it, this was pre-finished flooring. I put on two coats. I have a couple of spots on front of the couch that have worn through. There are also a couple of areas where the flooring has delaminated and created bubbles. One joint opened up about 1/8" and I have no idea why. The molding around the entrance and battery cover was too light and broke early in the trip. This molding was about $30 for 8'. The bath area which I was most concerned about because of the moisture seemed to hold up better than the rest of the coach. I do like the look and feel of the cork but it just didn't make it in this application. Again maybe it was just the brand that I bought.
Cheers, Dan
Old 12-24-2011, 06:04 PM   #221
I dropped out the air tank today and I see it is actually a freon tank that explicitly states not to use as an air tank and max pressure of 50 lbs. I guess I will be buying an new air tank after all!
Old 12-24-2011, 08:54 PM   #222
Installed the new panel under window in bedroom. Also painted the wardrobe door pulls. I was going to buy new ones but they are overpriced. Painted, they look like new.
ID:	147578   Click image for larger version
ID:	147580   Click image for larger version
Old 12-24-2011, 09:02 PM   #223
reinergirl's Avatar
Hollis , New Hampshire
Cheers, Dan
What brand did you use? And was it a click floating or???? Thanks
reinergirl is offline   Reply With Quote
Old 12-25-2011, 07:50 AM   #224
mefly2's Avatar
2015 25' FB Eddie Bauer
lol ... oems up. I think that it is contageous with me, too!
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
