Old 09-08-2015, 06:08 PM   #1513
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
If you have an Allison 540 your rear seal will look like this...buy two seals in case you screw up the first one installing it. You can use a piece 12" to 14" long and three inches in diameter to install...works perfect !Click image for larger version
Name:	ImageUploadedByAirstream Forums1441757223.617558.jpg
ID:	247665Click image for larger version
Name:	ImageUploadedByAirstream Forums1441757260.617714.jpg
bobmiller1 is offline   Reply With Quote
Old 09-11-2015, 07:00 PM   #1514
1982 28' Airstream 280
Redwood City , California
I'm sitting at home sort of bored and looking at photos. I know winter is around the corner, but it was 106 up north today. So, I added a gallery of winter photos at the ranch...
Wintering at the Ranch | project AIRSTREAM
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-21-2015, 10:13 PM   #1515
I'm prepping for our annual trek to Yosemite so some maintenance was in order...Click image for larger version
Name:	ImageUploadedByAirstream Forums1442894963.566937.jpg
ID:	248694Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895001.381140.jpg
ID:	248695Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895049.397987.jpg
ID:	248696Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895093.777820.jpg
ID:	248697Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895114.047882.jpg
ID:	248698Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895140.533074.jpg
ID:	248699Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895171.544493.jpg
Old 09-21-2015, 10:21 PM   #1516
Dad's Toy
I completed my list so I thought it was only appropriate to head out on a shake down run, so I headed down the mountain and south on I5 to the Rolling Hills Casino in Corning...Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895446.072537.jpg
ID:	248704Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895480.991986.jpg
ID:	248705Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895517.671329.jpg
ID:	248706Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895540.238321.jpg
ID:	248707Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895565.637813.jpg
ID:	248708Click image for larger version
Name:	ImageUploadedByAirstream Forums1442895592.788254.jpg
Old 09-22-2015, 06:51 AM   #1517
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Great work Dean.
I guess an open question to all the SMEs on the forum - what do you use/how do you lift your MH to get to work underneath? Jack (bottle/trolley?) and axle stands? Heavy duty ramps?
It maybe just an artifact of me being nearly as round as I am wide (and I am pretty wide) but working underneath is a nightmare!
martin300662 is offline   Reply With Quote
Old 09-22-2015, 07:49 AM   #1518
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
That's a very nice interior. There is a real feeling of spaciousness in that living area. I often think that Airstream did a better job of floorplan design with their smaller MHs than with the larger ones, and that's true of Excellas, Argosies and the Classics.
1989 345LE
Punch is offline   Reply With Quote
Old 09-22-2015, 08:42 AM   #1519
Originally Posted by martin300662 View Post
Great work Dean.
Martin,
On my old 310 I was generally able to crawl around underneath it without raising the coach. There are a few spots that were a bit tight such as under the propane tank, etc so I just did a lot of crawling to get from point A to point B.
I have at times used the leveling jacks to raise the coach but then I always placed jack stands to support the motorhome before crawling underneath.
My Argosy is a little lower but I haven't had to crawl under it a whole lot as yet. This winter after I move it into my shop I plan on using wood timbers to raise and block it with so I can work comfortably underneath.
Since your Argosy doesn't have a leveling system I would suggest having some solid wood ramps made that you can drive onto to gain any additional space needed to crawl underneath.
Old 09-22-2015, 09:31 AM   #1520
Rivet Loser
Punch's Avatar
There's nothing worse than squeezing underneath a vehicle.... I find myself suppressing the urge to scream and start fighting my way out!
I have a big (cheap, Chinese) trolley jack that shifts the 345 upwards in a hurry, and I spent more money on a pair of 12 ton axle stands, which I push under. I raise both sides and get it good and high, with the tires 6" off the ground, and then you can scoot around in comfort.
A few years ago we had a project that used a lot of puckboard, which is smooth and very tough and comes in 4x8 sheets. I have several large offcuts and I slide those on the ground under whatever vehicle I am working on and I slip around just fine on them. Whenever I have tried to use a creeper, sooner or later I find myself getting off it and rolling around in the dust because a creeper is just too inconvenient to use. It also wipes clean very easily.
1989 345LE
Old 09-22-2015, 11:08 AM   #1521
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
in 2001 I built these ramps, when I realized the radiator in the 79 models had to be removed from underneath.
Still using the same ramps now, but I added stops to keep me from driving of. Just shows you quality doesn't cost, it pays
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-22-2015, 02:15 PM   #1522
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks guys (and sorry for the distraction on your thread Dean).
At least I did get the response from you, that I got from DW.....which went along the lines that it was easier for me to get thinner than to raise Bella.
Old 09-27-2015, 04:41 PM   #1523
My ramps are for leveling the MH but they sure make it nice to work under the coach as well. I don't believe there is a single space at the ranch that is level. I have to level the MH as best as possible via the tires before I deploy the leveling hydraulic jacks. Too much leveling with the jacks alone will bend the frame just enough to cause the door not to close properly.
Old 09-27-2015, 04:43 PM   #1524
No worries!
Old 09-27-2015, 04:44 PM   #1525
Thanks Martin
Great work Dean.
Old 09-27-2015, 04:44 PM   #1526
Thanks Bob
1982 airstream 280, 28', motorhome
Airstream toy trailer, furnished, 2002 edition, 11" eBay Watch Airstreams on eBay 0 01-18-2011 09:00 AM
'68 Overlander to Toy Hauler maxtime General Repair Forum 5 01-01-2011 08:32 AM
