Old 11-16-2006, 04:17 PM   #1
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
cruise control 1989 345LE
I am sure that I'm not the only one with the problem as to how to replace an Airstream installed cruise control with a new unit. The factory was of no help. Looking for the easiest and hopefully less expensive method to replace the original ( installed by Airstream) after market cruise.
raveson is offline   Reply With Quote
Old 11-16-2006, 04:59 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
If you look at my posts in this thread you will get the information about how I had mine replaced and how much it cost me.
http://www.airforums.com/forum...ghlight=cruise
Good luck.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-17-2006, 01:55 PM   #3
1985 34.5' Airstream 345
Fishers , Indiana
I updated our 345 cruise control a few years ago with an after-market non-vacume unit for under $300 after spending a lot of time with no results trying to locate parts for the factory cruise control. It turned out to be much cheaper and easier to just completely replace the cruise with a new unit than to try and repair the existing unit. I selected one that replaced the old cruise arm and looks like it came with the 345. Check your local autoparts supplier or the web.
Wayne
Wayne Olson is offline   Reply With Quote
Old 11-20-2006, 02:54 PM   #4
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
On my last trip the cruise decided to stop working. Then about 20 miles into my trip this weekend, the speedo stopped working. I'm going to hope that the two are related, and it's something simple like a cable replacement.
I'm in the same boat, and I'll post my results!
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Control indicators smily Electrical - Systems, Generators, Batteries & Solar 10 01-16-2007 08:09 PM
Successful Shake-down Cruise winner On The Road... 8 08-12-2002 01:04 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 09:14 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
