Old 08-28-2016, 11:07 AM   #99
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
On ours, if the selector switch is set to run the front a/c, there is no 110 power in the outlets. Not sure about the refrigerator, but my guess is that you won't be able to run front a/c and the refrigerator at the same time.
Waipio Rim is offline   Reply With Quote
Old 08-28-2016, 11:29 AM   #100
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by Ryker View Post
Thanks Peter. It was the breaker. I didn't see it on the side.
We made it to burning man but now the refrigerator went completely blank, all plugs stopped working (breaker is tripped), and check engine, light is on. Any ideas on refrigerator? It was working on AC but would not ignite. Now nothing at all.
check your privat msg...
to run the fridge on Gas you have to have 12V and gas . Often if it wasn't used on gas for a long time, the air needs to make its way through the lines. Sometimes it helps to turn the stove top burner on for a few seconds to purge some air.
1996 Airstream B190
1997 30' Excella Wide Body Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 08-28-2016, 12:37 PM   #101
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
What Peter said.....you need 12 volts all the time at the fridge.....even if on AC. Sounds like you have multiple problems, not related to each other. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-29-2016, 06:44 AM   #102
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by bobmiller1 View Post
.. Sounds like you have multiple problems, not related to each other. Regards, Bob
Yes, Bob, multiple problems that caused a chain reaction.
I communicated with Ryker via text whilst he enjoyed the burning man festival.
1. 30 amp breaker tripped at generator
2. after reset 110V outlet plug breaker tripped repeatedly
Since fridge was giving him trouble, i suggested to unplug fridge from outlet, suspecting a faulty heater element.
Bingo, plugs were working but fridge still not igniting on gas. Told him to find 12v Fuse/distribution panel and check for blown fuse.
That fixed his issues
1996 Airstream B190
AIR #13
Old 08-29-2016, 09:03 AM   #103
1999 35' Cutter Diesel Bus w/slide
Sacramento , California
Peter has been a huge help! We have most of what we need. The freezer works but refrigerator is room temp. Any tricks or can one go bad without the other going bad?
Ryker is offline   Reply With Quote
Old 08-29-2016, 09:31 AM   #104
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Wow Ryker, what an epic trip home/ delivery trip.
Loving that you stopped at burning man.
Does sound like you are learning your coach in the process. Lots to learn, no?
How about some pics of the scene there on the playa.
Good idea to turn off your chassis battery switch, to make sure you can get started after a few days of boondocking. Mine drains while sitting, if left on.
Have fun!
Cheers Richard
tevake is online now   Reply With Quote
Old 08-29-2016, 02:26 PM   #105
bobmiller1's Avatar
Freezer gets cold first.....make sure back if fridge is completely clear of debris all the way to the roof vent, this will help. Make sure water drain is also clear and draining.
Old 08-29-2016, 02:31 PM   #106
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Is there any way to clean the upper back of the fridge without pulling it out?
mayco is offline   Reply With Quote
Old 08-30-2016, 06:53 AM   #107
bobmiller1's Avatar
I call it a bread warmer Mike...the cabinet above the refrigerator has a tin cover that can be unscrewed....you wont believe the crap that you will find there...once that area is all cleaned out the performance of the refrigerator will really surprise you. Regards, Bob
Old 08-30-2016, 11:09 AM   #108
I noticed the refrigerator getting cooler but certainly not cold. I'll try removing the cabinet above the refrigerator.
Old 10-25-2016, 08:27 PM   #109
I finally made it to the California DMV to get my rig registered in California. They could only find 2 tags with the VIN. My problem is the tag on the dash is somehow destroyed. The tag in the front of the engine is very clear. My question here is did Chevrolet or Airstream place another tag anywhere else on the vehicle? Thanks for the help!
Old 10-26-2016, 12:32 AM   #110
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Those were the only two I could find on my 94 diesel. One is the vin from Spartan in my case who made the chassis, the other is from Airstream. I just told the CA DMV that the one that matched my title was the vin, and the went for that. My window sticker is also messed up...I would love to get a new one from Airstream!
SebasSF is offline   Reply With Quote
Old 10-26-2016, 10:35 AM   #111
Hey Sebas, that would be great if Airstream would make us a new tag! I have the tag on the original books but they would not accept that. The good news is that I passed SMOG without a problem, after I reinstalled the catalytic converter that the PO removed.
Old 11-01-2016, 11:58 PM   #112
I spoke to Airstream. They can not supply a new dash tag. Every vehicle has confidential VIN locations. I spoke to someone who has access to the database and he told me that the tag on a P37 chassis is on top of the chassis near the rear shock mount. Anybody ever see this tag? Hopefully Airstream did not move it. I climbed under my frame for 30 minutes with a flashlight and a mirror but I couldn't find it. There is very little space between the frame and the coach.
1995 Classic 360 questions RichardT Classic Motorhomes 0 03-23-2014 06:15 PM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 05:47 PM
