Old 08-20-2016, 06:39 AM   #57
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Ryker
Call me wak but doesn't the 360 have a problem with dust/oil and crap clogging up the A/C condenser/radiator. I think you need to give Kota a PM and he'll go throught it with you on how to flush out the CAC. I know I saw Kota discuss it on a thread somewhere.
FOUND IT!
http://www.airforums.com/forums/f159...ng-134758.html
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 08-20-2016, 07:26 AM   #58
1989 34.5' Airstream 345
Hanalei, /Chino Valley , Hawaii / Arizona
Good work, tony.
That was exactly what I thought should be brought up for consideration.
The question now is can the driver do anything about this lkely issue.
Can a hose run down thru the gap do any good at flushing enough clogage out to help.
Certainly worth a try I guess.
It will be interesting to hear Kota's take on it.
Cheers Richard
tevake is offline   Reply With Quote
Old 08-20-2016, 09:31 AM   #59
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I believe the unit being driven to California is a gas engine not diesel.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 08-20-2016, 09:46 AM   #60
1999 35' Cutter Diesel Bus w/slide
Sacramento , California
Yes, mine is gas
Ryker is offline   Reply With Quote
Old 08-20-2016, 10:14 AM   #61
Someone here mentioned using a product for the cooling system, called wet water. Or some such. The poster said that it helped drop his engine temps.
I don't know about it , but it may help for getting it home.
Cheers Richard
Old 08-20-2016, 10:34 AM   #62
The product is called Water Wetter and would definitely be worth a try.
I think you basically have to drain your cooling system and then refill with water and Water Wetter. We used in on our Triumph race car with reasonable success.
Old 08-20-2016, 10:56 AM   #63
Gunter
gunner's Avatar
Greenville , Ohio
It also helps to use distilled water to keep out the impurities.
Gunter
Old 08-20-2016, 10:33 PM   #64
My buddy has been driving half the day and the needle is right in the middle, so it was the fan clutch. I'm sure the new coolant and thermostat helps a bit as well. I am happy that I do not have to purchase a new or recored radiator.
Kudos to Open Roads Complete RV in Acworth, GA. I called them on Friday morning, and they got me in immediately. They put it on a lift, ordered the part and saved me money on it, and changed the fluids. Got my buddy back on the road by Saturday at noon.
Old 08-21-2016, 05:22 AM   #65
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Sweet
mayco is offline   Reply With Quote
Old 08-21-2016, 03:01 PM   #66
Just a couple of problems along the way. The generator will not be operational until El Paso. Because of that, he had to get a motel last night because it was too hot. When he got back to the rig, the key just spun in the lock and he could not get in. He tried to remove the passenger wing window (triangle window), and he broke it. How can I quickly get new glass for that window? I need to take this to Burning Man next Saturday.
Second issue is the AC was working and just quit, so I will have to troubleshoot that as well. Any good mechanics in the Los Angeles area, or maybe Temecula/Riverside area? He is willing to stop in El Paso to get the window fixed too, if anybody would have that in stock.
Old 08-21-2016, 03:07 PM   #67
In regards to the lock, is that an easy fix, or should I only use the deadbolt? This is what I told him to do for now on. I am not sure if the central locking caused this issue or not but he said it is working again.
Old 08-21-2016, 03:38 PM   #68
If it's the sliding wing window that is broken the only place I know of to find a replacement slider is at Inland RV. If it's the fixed window that is broken then you're pretty much out of luck finding a replacement. About your only option is to use a piece of Lexan or Plexiglass. The fixed panes have not been available for years. Inland RV is located in the Los Angles area.
Old 08-21-2016, 08:20 PM   #69
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Airstream Supply in Salt Lake shows both left and right side sliding panels available (used) for $475 each.
streamquest is offline   Reply With Quote
Old 08-21-2016, 10:24 PM   #70
Name:	ImageUploadedByAirstream Forums1471839846.434273.jpg
Looks like fixed window to me.
1995 Classic 360 questions RichardT Classic Motorhomes 0 03-23-2014 05:15 PM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
