Old 03-03-2013, 04:29 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Crankcase oil capacity dilemma
Let's talk crankcase oil capacity once again. Many years ago, I started a thread about this topic because my oil tube and dipstick were destroyed by the shop that installed the headers. The new fill line was not calibrated to the oil pan, and they never marked the stick at that current oil level. Eventually, it got marked at the 5 qt. level, and I've been running it like that for years. Recently, I had the oil changed and I was perusing the owner's manual which states that the 454 uses 7 qts. I believe this is minimum, as other features such as coolers, filters et cetera will require more oil. Does anyone use less than 7 qts. in their 454? Or should there be a minimum of 7 qts. in there at all times? Thanks.
Here is the original short thread.
http://www.airforums.com/forums/f159...ity-55697.html
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 03-03-2013, 06:20 PM   #2
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
I run 7 quarts in our 345. My dipstick has been remarked from original to show the 7 quart level. If I get the chance I will take a picture of it tomorrow and post.
Robfike is offline   Reply With Quote
Old 03-03-2013, 06:27 PM   #3
1982 28' Airstream 280
Redwood City , California
Every oil and filter change for me it is 7.5 quarts.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 03-03-2013, 07:37 PM   #4
Astrodokk's Avatar
Hopefully all the different years of builds used the same 454 and oil pan, Mine is a 1979 P30 chassis that Airstream used to build a 1981 coach onto. Anyone with an older 454 like in the late 70's? If the 345's used the same engine in the mid 80's, then 7 qts. seems to be the consensus.
Old 03-04-2013, 01:55 PM   #5
Robfike's Avatar
Speedway , Indiana
Here you go guys. This is a picture of our dip stick.
If you look close you can see where the two hash marks have been added to a stock GM stick. The new low line is over part of the original "full" word. The new full mark is just under the word "use". At the one end of the picture you can see the GM part number, 14050536W
Hope this helps, Rob
Name:	Airstream dip stick.jpg
Old 03-04-2013, 02:26 PM   #6
Astrodokk's Avatar
Did you have to get a different stick from stock, to where you had to re- mark it?
Old 03-04-2013, 05:06 PM   #7
Robfike's Avatar
Speedway , Indiana
The dip stick in the picture is the one in my 345 when we got it. I just assumed that it came that way from the factory.
