Old 05-04-2014, 06:24 PM   #1
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Count down to kick-off
So, I am making plans to do some tailgating this fall. The first game is scheduled for August 29th. I have had this MH for two years and the progress of the restoration has been very slow. It's time to get serious. I have the chassis pretty well squared away and it drives great! Next step; replace the univolt. The manual says remove the box that covers the univolt and remove the univolt. Well, I can't access the screws to the box without removing the vinyl wall panel. Hmmm, can't remove the wall panel without removing the credenza. Oh my! look whats under the credenza! Is that the remains of plywood? I was hoping to speed this project up, not slow it down.
ID:	211248   Click image for larger version
Gregsch is offline   Reply With Quote
Old 05-05-2014, 09:24 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Don't feel bad Gregsch, we've all grown accustomed to the same exact thing. Went to work on plumbing of shower, ended up having to purchase all new shower water controls, then pulled front panel off at base of shower, only to 'discover' the particle board is disentegrating under shower pan.
It's almost as if what I used to tell my ex-wife...."If it's not one thing, it's your Mother!"
Good Luck, Derek
Old 05-06-2014, 05:41 PM   #3
Gregsch's Avatar
Tipp City , Ohio
Okay, it seems that I am going to have to address the roof leaks. I removed the inner end cap to see if I can find out where it is leaking. Wow! it looks like they smeared caulk on this thing with a putty knife! Looks like this caulk is failing all over the place. Looks like I need to remove the old caulk and replace it with new. What kind of caulk would be best for this application? Also, I have a couple cracks in the end cap. What material is it made of and what would be the best technique to repair the cracks before they get worse? One more thing, looks like the antennae is leaking as well. Do
I really need this old antennae? Should I remove it and cover the opening with a piece of new skin? Should I upgrade to a modern digital antennae?
ID:	211360   Click image for larger version
ID:	211362   Click image for larger version
Old 05-06-2014, 09:04 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Welcome to my nightmare….
http://www.airforums.com/forums/f311...me-106269.html
While fixing your leaks with Trempro 635, SikiFlex 221 or Parbond remember to remove the marker lights and reseal as I found a lot of extra holes drilled into the end cap and never sealed. Also the spot lamp and horns.
The end caps are ABS plastic and the only thing that sticks to ABS is ABS Mek slurry (see Keyair Airstream 345 newbie thread for instructions on how to make and use) or PL Premium. The end caps are very fragile so be careful.
As for the antennae I wouldn't remove if you don't have to as patching unnecessary holes are a pain but by all means go digital. Heck, all the tunes I had in mine are driven by my tablet into a Bose dock stereo system. I don't even listen to the radio anymore.
Cheers
Tony
Old 05-07-2014, 09:14 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Airstream motorhomes are actually trailers after all..They need the same resealing of every seam and vent surround..annually if possible.
I used Vulkem in a large syringe to do mine.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 05-07-2014, 07:19 PM   #6
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
http://www.airforums.com/forums/f311...er-117997.html
Post number four is how I fixed my endcap. Check it out and see if you like it. Material used is "automotive goop." Works like a charm!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-07-2014, 08:10 PM   #7
crazeevw's Avatar
I've actually purchased Eteranabond tape for the roof seams on my motorhome. One of the 4 previous owners had decided to 'seal' the roof with tar based roofing paint, which didn't work worth a damn....
Took forever to strip off roofing paint, Eternabond is installed, will follow with white reflective roofing paint soon.
For the seams on back roof area, I did same thing as ALANSD, syringe of Vulken (look for it at Fastenal stores) Tiny bead, along seam, follow with paint thinner soaked rag to be sure it's worked into the overlap of aluminum.
With both the Eternabond and the Vulkem at roof seams, so for, no more leaks at rear.
Now onto the clearance lights up front. If yours are anything like mine after 25 years, they were toast. Found some LED replacements on eBay for about $5 a piece, less heat, less power consumption.
Good Luck, Derek
Old 05-13-2014, 03:33 PM   #8
ASTailgate's Avatar
1981 28' Airstream 280
I started tailgating in my EXCELLA 280 5yrs ago. Go to my FB page at SILVERBULLET TAILGATE to see my pics.
ASTailgate is offline   Reply With Quote
Old 05-14-2014, 07:56 PM   #9
Gregsch's Avatar
Tipp City , Ohio
Nice write-up Isuzusweet! That will be a big help. Why would
I need a cuss jar? I never cussed before. Can you explain the advantage of the Coosa marine plywood product? There was nothing special about the plywood originally installed at the factory.
Crazeevw, what is the Vulkem like after it sets up? The caulk that the factory used did not get hard when it cured. They used it around the screws for the clearance lights and I was able to remove them and reinstall them with ease. I am afraid if I use a caulk that gets hard when it cures I will not be able to remove and replace the screws if needed (like when I strip the skin to polish)
Old 05-14-2014, 08:58 PM   #10
reinergirl's Avatar
Hollis , New Hampshire
That looks more like butyl tape, kinda grainy, won't get hard.
Vulkem ( trempro 635) gets rubbery but I don't think it would reseal after putting a fastener thru it..... If that's what you want I'd suggest Eternabond doublestick tape, roll it up in a ball, rope whatever..... I'm going to use it to seal up the hole in the skin from the clearance lights.
reinergirl is offline   Reply With Quote
Old 05-17-2014, 07:30 PM   #11
Gregsch's Avatar
Tipp City , Ohio
ASTailgate, I could not find your pics on FB. I would really like to see how you set yours up to tailgate.
Well, I think I have removed all the rotten plywood. Hopefully I can clean up the mess tomorrow and start putting things back together. I need to start a material list. This is getting more involved than I had hoped.
Looking at the last photo, this would be a good time to do a brake job
ID:	212125   Click image for larger version
ID:	212127   Click image for larger version
Old 05-17-2014, 08:34 PM   #12
ASTailgate's Avatar
Here's a few pics. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400379952.987213.jpg
ID:	212130Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380012.603338.jpg
ID:	212131Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380042.005113.jpg
ID:	212132Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380078.172121.jpg
ID:	212133Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380127.083870.jpg
ID:	212134Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380149.151916.jpg
ID:	212135Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380169.135019.jpg
ID:	212136Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380199.290371.jpg
ID:	212137Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380221.003419.jpg
ID:	212138Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380245.599917.jpg
ID:	212139Click image for larger version
Name:	ImageUploadedByAirstream Forums1400380266.180234.jpg
In FB go to search and type in Silver Bullet Tailgate to see actual tailgate pics.
Old 05-17-2014, 09:09 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Sorry that your sense of humour didn't apreciate the cuss jar.
There is still nothing special about the subfloor that Airstream uses today…..OSB board. Do you know what OSB board does when it gets wet? Coosa is completely synthetic fibre glass reinforced foam core, doesn't expand or contract, doesn't rot, mildew or promote the growth of fungus. I can stay wet and the water will simply stay on top of the board……..all for 40% lighter than the original plywood in some of our classics.
Trempro 635 or Sikiflex 221 dries to a rubbery state and will stay flexible far longer than even the original Vulcum.
As I said in my original post I only want to do this job once…….
Old 05-18-2014, 06:09 PM   #14
Gregsch's Avatar
Tipp City , Ohio
ASTailgate, I was entering my search as SILVERBULLET, It came up fine when I entered Silver Bullet. Nice looking rig you have, looks like you really enjoy the game day experience! I doubt we will ever play Texas but, if we do, we could park nose to nose
Isuzusweet, I looked at the Coosa on the web. I see what you mean about the durability. I will look for a local source. I am not impressed with the design from the factory. The plywood over the front wheels in particular is not well protected from the elements.
I will need to replace the radio antenna before I put it back together. Does anyone have a source for the antenna shown in this picture.
Also, would like to get a radio with a back-up camera. Does anyone have experience with an aftermarket radio? I would like to run the wire back to the back of the MH while I have it apart. What kind of wire should I use? I was thinking about using a light fixture like the one over the door to enclose and protect the camera. I would mount it over the bathroom window.
ID:	212258   Click image for larger version
WDCU Kick off Rally at Compton Basset Park airstreamhobo WBCCI Rallies & Events 8 05-04-2014 03:15 PM
475 transmission kick down switch montreal Classic Motorhomes 1 06-07-2012 05:38 PM
Great Backyard Bird Count Barbara Peerenboom Off Topic Forum 8 03-04-2005 09:10 PM
Why do I love my AS? Let me count the ways... Stefrobrts On The Road... 8 07-28-2003 05:36 PM
