Old 07-24-2014, 07:27 PM   #29
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
wxbouy is correct... dielectric grease is what you want to use, not silicone grease.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 08-17-2014, 06:35 PM   #30
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Coleman Mach 8 arrived this week. Man that fan is loud! Maybe not so loud as in deciples, but a very intense sound. Sounds like it is spinning 9000 rpm. Anxious to see how it sounds when installed.
Repaired the battery box with a little ABS plumbing pipe and some MEK. Thanks for the tips Keyair!!!
Making a waterproof box to contain the new fuse panel out of some scrap Coosa 26. Not sure how it is going to work out. Just using fiberglass resin to adhere it.
My son called this week to tell me he was moved from the 3rd squad to the 2nd squad! Great news, he was a red shirt last year. Are you coming to my first game? he asks. Uh, Uh sure son I'll be there. I've got less than 2 weeks, its coming together but not nearly fast enough.
ID:	219254   Click image for larger version
ID:	219256   Click image for larger version
Gregsch is offline   Reply With Quote
Old 08-20-2014, 12:41 PM   #31
Vycan's Avatar
Manhattan , Kansas
really enjoy seeing the progress, good work.
Old 08-28-2014, 08:12 PM   #32
Gregsch's Avatar
Tipp City , Ohio
Well, It's official I am not ready for the first game. The project got too involved and a very busy work schedule consumed most of my time. Fortunately Tom Bodet left the light on for us and we will get to see the game.
I picked up the condensate pump for the Mach 8 this week. There were no instructions. I think I see how the pump mounts but I need some help with the wiring and connecting the hose.
ID:	220130   Click image for larger version
Old 08-29-2014, 06:42 AM   #33
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Tom's a great guy and has saved my butt during our extended rehab project!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 04-22-2015, 07:40 PM   #34
Gregsch's Avatar
Tipp City , Ohio
This project has been on the back burner for a while now. Spent all last season tailgating from Wisconsin to Alabama out of the trunk of the car. Time to get this project completed and do some serious tailgating.
Finished up the Coosa Board riser with the new fuse panel. Not sure just how strong it would be just gluing it together, so I wrapped the back side with a layer of fiberglass cloth and resin. Bought a crimper to crimp the end of the 4ga wire, it makes quick work of it.
Have the solar charge controller, Boondocker, and new batteries sitting on the floor in the shop. Lets Rock!
ID:	236860   Click image for larger version
ID:	236862   Click image for larger version
Old 05-02-2015, 12:19 PM   #35
Gregsch's Avatar
Tipp City , Ohio
In order to make space for larger batteries I am switching the location of the coach and engine start batteries. I am using two marine deep cycle batteries for now. I can just squeeze them in the lower compartment but, there was no room to make the connections. I made these copper adapters so that I can make the connections without arcing the top of the box. If that does not prove to be enough capacity I can cut the bottom of the compartment out and fabricate a drawer like the ones used in newer motorhomes.
Just about finished with the wiring. Need to mount the Boondoker and the SC 2030 solar controller.
Looks like I need to pull the trigger on some solar panels next. I am open to suggestions. I like the appearance of the flat panels that glue right on the skin but, they don't really have a proven track record.
Old 05-03-2015, 06:11 AM   #36
Gregsch's Avatar
Tipp City , Ohio
Whoops, pics did not load. Lets try again.
ID:	237633   Click image for larger version
Old 05-03-2015, 01:11 PM   #37
wxbuoy's Avatar
Very nice work! Is that a trimetric shunt on the right side?
Dave and Felicia
Old 05-04-2015, 02:32 PM   #38
Gregsch's Avatar
Tipp City , Ohio
Yes, I bought it all from Best Converter.. Fuse box , 2030 Moniter, 2030 Solar controller, 75 amp Boondocker. I need a couple solar panels now. What will work best? Hmmmm
Old 05-05-2015, 02:26 PM   #39
wxbuoy's Avatar
You are looking the same way We are. We want to go with flexible panels for look but reviews are not great
Dave and Felicia
Old 05-10-2015, 11:54 AM   #40
Gregsch's Avatar
Tipp City , Ohio
Looked at every hardware store in town for suitable grommets to run wires through the aluminum framing. Could not find anything I liked. I came up with this idea. I used 1/2" pvc water pipe and couplings. Cut the pipe an inch longer than the framing member and glue a coupling on both sides.
Got the wiring done on the drivers side, fabricated a piece of aluminum to seal the end to the sidewall, Counterflashed that with a larger piece, finally I will install the inner fender. Lets hope that keeps it dry.
ID:	238124   Click image for larger version
Old 05-10-2015, 12:05 PM   #41
1982 28' Airstream 280
Redwood City , California
What an awesome idea!
dadstoy is offline   Reply With Quote
Old 05-18-2015, 07:42 PM   #42
Gregsch's Avatar
Tipp City , Ohio
Finally got the wiring to the point where I can install the floor boards at the drivers and passengers seats. Installed the battery box on the driver side, the engine battery now resides here. Since the Boondocker is much smaller than the Univolt I was able to mount the solar controller in the same space.
Ever since I replaced the exhaust system the tail pipe on the drivers side has sagged. Since it is directly below the storage box there is no room for a hanger above it. Got an idea from looking at the hanger on my Bonneville. Cut a hanger out of a FWD Oldsmobile and reworked it. That should solve the problem.
ID:	238741   Click image for larger version
ID:	238743   Click image for larger version
WDCU Kick off Rally at Compton Basset Park airstreamhobo WBCCI Rallies & Events 8 05-04-2014 03:15 PM
475 transmission kick down switch montreal Classic Motorhomes 1 06-07-2012 05:38 PM
Great Backyard Bird Count Barbara Peerenboom Off Topic Forum 8 03-04-2005 09:10 PM
Why do I love my AS? Let me count the ways... Stefrobrts On The Road... 8 07-28-2003 05:36 PM
