Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-07-2018, 10:40 AM   #341
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Here are a couple more pics of the Q-jet rebuild The yellow arrow shows the fuel pick up still in place, the red arrow shows the fuel pickup that is missing. When this happens you loose the 4 barrel function. I glued it back in place with JB weld.
Name:	q-jet w arrows.jpg
ID:	324616   Click image for larger version
Gregsch is offline   Reply With Quote
Old 10-07-2018, 10:55 AM   #342
Gregsch's Avatar
Tipp City , Ohio
Here is the set up i have in mind for installing the new Carter fuel pump. I was getting ready to install it when I noticed that the fuel pump installation instructions said do not use thread sealant. I don't see how that would seal the tapered threads. The brass fittings I bought are just standard pipe fittings. Any recommendations on how to proceed?Click image for larger version
Old 10-07-2018, 11:15 AM   #343
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Your location of you relay or junction block worries me......as far as thread sealant I use tephlon tape wound the correct way, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 10-07-2018, 11:42 AM   #344
Magnet18's Avatar
Churubusco , Indiana
A little bit of oil might let you get it tight enough to seal. The tapered thread seal is actually metal on metal, the tape just helps lubricate so you get it tight enough to deform the metal into a good contact
There is also gasoline safe thread sealant. I thought the regular Teflon tape dissolved in gasoline and risked gumming things up
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-08-2018, 09:57 AM   #345
Gregsch's Avatar
Tipp City , Ohio
I was thinking that this might not be the best location for the fuel pump relay. I was trying to avoid compounding the wiring mess behind the dash but, when a guy with your credentials thinks it's a bad idea I will take notice. I will find a place the is better protected from the elements.
Old 10-24-2018, 06:09 PM   #346
Gregsch's Avatar
Tipp City , Ohio
I bought the Mr Gasket fuel pump relay. I had second thoughts about installing it without an oil pressure sensor. So I bought the Holley oil pressure sender but , now I am unsure about how to wire it up. It would appear that the Holley sending unit has a relay built in. If that's the case I think I should wire it per the Holley diagram. Can someone who has done this project make a recommendation Click image for larger version
ID:	326208Click image for larger version
ID:	326209Click image for larger version
WDCU Kick off Rally at Compton Basset Park airstreamhobo WBCCI Rallies & Events 8 05-04-2014 03:15 PM
475 transmission kick down switch montreal Classic Motorhomes 1 06-07-2012 05:38 PM
Great Backyard Bird Count Barbara Peerenboom Off Topic Forum 8 03-04-2005 09:10 PM
Why do I love my AS? Let me count the ways... Stefrobrts On The Road... 8 07-28-2003 05:36 PM
