Old 09-21-2016, 08:01 PM   #225
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by Gregsch View Post
I always seem to be lucky that way....
I was very lucky one time, when all the brakes on my 345 locked up while I was trying to pull out of the driveway. Yes, BAM, locked up solid going 5 miles an hour. The only way to get them unlocked, was to carefully loosen the master cylinder bolts. I think the term is called pre-loading of your brake system, due to mismatching parts and it took 200 miles to do so. (200 miles was when I put the new bad Master cylinder in).
But, for my protection, I had the Mexican Shaman on Board, who always claimed that the Airstream Motorhome was a Cuidad (city ) and not just a house....
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-22-2016, 04:49 PM   #226
I always seem to be lucky that way. When the bake line rusted through on my van it made itself apparent when I backed out of the garage. Brought my son's car home from college to replace the radiator and when I backed it up on the ramps the brake peal went to the floor. No sign of brake trouble up to that time, the brake hose at the caliper just let go.
That being said I just subscribed to Good Sam Roadside Protection.
I just keep thinking of TAP and his misfortunes.
So THAT's where all of my luck went
bkahler is online now   Reply With Quote
Old 10-05-2016, 07:08 PM   #227
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Adjusting the tension on the power steering pump belt
Thanks for the tip on adjusting the tension on the power steering pump Brad. I was not able to reach it from on top of the engine but, your description helped me locate the bolts and the square hole to tension it. I used a swivel and a couple long extensions on the 1/2" ratchet to put tension on it from behind. A couple 1/2" open end wrenches to loosen the pivot bolt and a 3/8" ratchet to loosen and tighten the top bolt. I did it all in the blind , mostly by feel, from the drivers wheel well.
Gregsch is offline   Reply With Quote
Old 10-06-2016, 02:08 PM   #228
So the next time you do this you're going to do it in the dark....right?
Old 10-06-2016, 03:57 PM   #229
Gregsch's Avatar
Tipp City , Ohio
I guess I have worked under worse conditions. On the trip to Memphis I replaced the thermostat in the O"Rielly's parking lot . Then a few hours later I installed a fuel pump in this deserted spot.
Old 10-06-2016, 05:38 PM   #230
Airstream Driver
1997 30' Excella
Images: 51
Attachment 272973
My kinda guy that carries all the tools to do these jobs on the road. Soon you will have to pull a trailer, so you have room for your clothes and food and stuff
1996 Airstream B190
AIR #13
Old 10-29-2016, 01:32 PM   #231
Gregsch's Avatar
Tipp City , Ohio
front end play
Last week on the way to the game she drove beautifully. The next morning as soon as I pulled out of the parking lot I noticed play in the steering. On the highway it was difficult to keep it going straight. Just loose and sloppy like there are several worn out parts. I jacked it up today and looked at it and it appears that the pitman arm is the culprit. The pitman arm pivots on a shaft that is mounted in a cast iron piece that bolts to the frame. It appears that there is a bearing or a bushing in the cast iron piece and it has failed. I will take it apart and see. Any advice on how to repair it and where to locate parts would be appreciated. Thanks
Old 10-29-2016, 02:17 PM   #232
Greg, that cast iron piece is called a bell crank. I think GM calls it an idler pivot.
GM discontinued the bell cranks a long time ago and Supersteer is the only option I know of for a replacement.
Fortunately they aren't that difficult to replace. You'll need to get your front end aligned once it's been replaced. From what I've read and experienced the drivers side takes the most abuse and wears the most.
Old 10-29-2016, 04:07 PM   #233
Gregsch's Avatar
Tipp City , Ohio
That's a great video! That's exactly what the play on my Bell crank looks like. $600 ouch!
Old 10-29-2016, 04:23 PM   #234
Yep, expensive but the odds are you won't have to replace them ever again
Old 10-29-2016, 06:25 PM   #235
Gregsch's Avatar
Tipp City , Ohio
Ok, got it apart. There is a little play in the shaft at the bronze bushings. Nothing that looks to me like it would cause the drastic change and all the sudden. I think my next move is to remove the steering stabilizer and see how it feels when not attached to anything.
Old 10-29-2016, 07:19 PM   #236
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Most suspension parts wear very slowly. If you have some sudden change I suspect something broke or is seriously compromised like the rag joint tearing. Most of the joints are pretty much metal to metal except for the rubber in the inner A frame bushings. Look very closely for cracks that open under load and close when the load is removed. Have somebody crank the steering wheel back and forth while you watch each joint for movement. Good luck.
Cheers, Dan
~ Margaret Thatcher ~
Old 10-29-2016, 07:19 PM   #237
Airstream Driver
1997 30' Excella
Images: 51
you did, of course, check your lower ball joints ?
1996 Airstream B190
AIR #13
Old 10-30-2016, 06:38 AM   #238
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I was told that you cant really tell how much play there is by hand. It has to be under load. I bit the bullet on the SuperSteer bell cranks. It hurt but glad I did it. The install isnt bad except on the diesels like mine, the passenger side motor mount makes it nearly impossible to get at one of the mounting bolts. Still not sure how I got that sucker started and tightened up. I sincerely think that any time and money spent on that steering and front suspension is money very well spent. The improvements Ive made have completely changed the driving experience. COMPLETELY! Little bit at a time and youll get it where you want it. MAN your coach is B E A U T I F U L!!!!!
Mike
mayco is offline   Reply With Quote
WDCU Kick off Rally at Compton Basset Park airstreamhobo WBCCI Rallies & Events 8 05-04-2014 03:15 PM
475 transmission kick down switch montreal Classic Motorhomes 1 06-07-2012 05:38 PM
Great Backyard Bird Count Barbara Peerenboom Off Topic Forum 8 03-04-2005 09:10 PM
Why do I love my AS? Let me count the ways... Stefrobrts On The Road... 8 07-28-2003 05:36 PM
