04-12-2015, 11:24 AM
1984 31' Airstream310
Surprise
Complete Front end Overhaul
I'm planning a trip with the family to Lake of the Ozarks for the 4th of July. I want to completely rebuild the front end on my 84' 310. I'm talking all steering components, rubber, shocks, HD springs, (eliminate the airbags) .
Does anyone know a one-stop shop for these components? Rock Auto, etc?
I'm also converting the rear twins into a queen or???
I can do all the work myself, I'm interested in advice on actual good experience with brands, complete kits, etc.
I'm also going to replace both roof-top AC units and convert the chassis AC system to R44.
But, I'll save that for another thread.
Danny Batsell
04-12-2015, 06:25 PM
Honokaa
, Hawaii
You might want to add a steering coupler, aka rag joint, to the list. When I took our 310 to a mechanic on the road for brake work he wouldn't even test drive it until ours was replaced.
04-12-2015, 10:14 PM
Surprise
Hmmmm, rag joint huh? I'll crawl under there tomorrow and locate that.
04-12-2015, 10:19 PM
Honokaa
, Hawaii
Haven't actually seen it, but I think it's at the bottom of the steering column.
04-13-2015, 10:46 PM
Surprise
Ok, now I know what you're referring to. The flexible joint between the steering wheel and steering box. It doesn't feel sloppy but they're cheap, so I might as well replace it too! I've located most everything from Rock Auto. They have AC Delco OEM and Heavy Duty parts available. I am having a problem with the grey water tank. I've had it patched up once already, but it's just shot! All dried up. I can't find a replacement anywhere. Im probably going to have one custom made.
04-14-2015, 07:19 PM
1994 36' Classic 36 Diesel
Colorado Springs
I would recommend new ball joints based off of Mayco's experience in the Classic get together thread.
1994 36' Classic Diesel Pusher
04-15-2015, 04:23 PM
Surprise
Yes Vycan, those too are on the chopping block. What I'm not sure about is on the other end of the control arm. It's a steel rod that connects the control arm to the frame. It has greasable joints. I might as well replace the whole control arm (x4) because they come cheaper all assembled from Rock Auto.
04-16-2015, 06:54 AM
Colorado Springs
You'd have to send me a picture for reference. Mine does not have what you describe.
04-16-2015, 07:01 AM
Curtis Wright
Eyren Haven
, South Jersey
Wise choice to replace the control arm bushings. When I worked BeeLine, that was the main part causing problems. All other shops were too lazy to replace. Rock Auto are very good suppliers.
05-15-2015, 06:31 PM
Surprise
Hmmm, Rock Auto doesn't seem to show the correct pitman arm and idler arm for this P30 chassis. Anyone recommend a parts store besides Napa? Maybe a heavy truck shop!
05-15-2015, 07:32 PM
Honokaa
, Hawaii
05-15-2015, 07:41 PM
Surprise
That's not for a motorhome. The MH idler and Pitman arms are "L" shaped. SuperSteer has them but, WOW! $$$
05-15-2015, 07:46 PM
1982 31' Airstream 310
champaign
You can try SuperSteer but thry are pricey.
05-21-2015, 05:24 AM
Richmond
, Kentucky
SuperSteer is the best way to go. I installed one (I call them bell cranks) on the drivers side of the 310 and it made a HUGE difference. Ball park price was $300 per side but well worth it as you'll likely never have to replace it again.
GM no longer stocks the OEM bell cranks. About eight years ago I had one of the Chevy dealers check national stock for them and I ended up getting the last two that they could locate from around the US. They were a lot cheaper than SuperSteer. Figured they would work ok for my little 20' Argosy.
1975 24' Argosy Motor Home
05-21-2015, 05:32 AM
champaign
I did install the supersteer on both sides. It did make quite a bit of difference but other components were in need of replacement also. I think I gave $275 a piece off of Amazon Prime. They are very accessible folks at their shop. I called with a question and actually talked with the guy thats on the youtube video about the install. Not sure about the gassers but the motor mounts for the diesel pose a real challenge when bolting up the bell crank on the passenger side.
Mike
10-19-2020, 02:47 PM
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
Thi9s tread kind-a fizzed. I'm getting to my 'list' of I need to's and my next idem is replacing the bellcrank bearings.
First: I've located the 'supersteer p3032' for $309.95. Is there a left and right or are they the same??
10-19-2020, 06:44 PM
1991 35' Airstream 350
Columbia
, Tennessee
Mel, they are the same.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
