Old 09-16-2006, 11:26 AM   #1
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
clunk when brakes applied
At low speed when you initially apply the brakes there is a clunk or jolt (like you hit a freeway bump) the brakes seem to work fine and you can't feel it at high speed any ideas?
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-16-2006, 11:29 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Clunk
You may want to adjust the settings on your brake controller. A clunk can be a normal sound and is just the noise made when the brakes are applying
centennialman is offline   Reply With Quote
Old 09-16-2006, 11:35 AM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Do you "feel" anything in the steering or have a rough idea of where the noise is coming from?
Could be a loose caliper, broken pad, etc. Could also be your tag brakes, a lot depends on where the sound (bump) is coming from.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-16-2006, 11:52 AM   #4
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
What size of locking pin do you have securing your hitch to your receiver? The reason I asked is I originally purchased a pair of locking pins to secure both my hitch and receiver tube. The hitch pin was a proper fit, but the receiver tube pin was loose and did not properly fit the hole. This caused a "clunk" noise both when accelerating and decelerating at low speeds. At higher speeds I couldn't hear it, probably because of other road noises interfering.
I purchased a larger receiver locking pin and problem solved! Check yours out for proper fit.
(PS.....this applies to trailers only........I see that you have a MoHo.......so may not apply in your case)
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 09-16-2006, 12:30 PM   #5
str8strm's Avatar
sounds like the rear end
tag brakes seem to be working ok
AIR 7992
Old 09-23-2006, 02:54 PM   #6
RivetAddict
swebster's Avatar
Check the calipers in the rear? I found both sides on mine had broken pads and one side had a loose caliber bolt. I replaced everything, turned the rotors and about three nagging noises went away (not to mention my brakes worked again).
Also, something could be loose in your tags. They work like trailer brakes and have an electro magnet in them...seems like if one worked loose it would make a lot of noise.
If you think it's definately braking (not hitch, suspension, etc) then it's time to pull each wheel an inspect everything, check bolts,, shoes, ads, discs and drums.
Steven Webster
AIR 1760
Old 09-24-2006, 07:12 AM   #7
str8strm's Avatar
we serviced the tag brakes and ended up finding a broken shock mount. we had replaced all the shocks about 5 months ago and don't know when it happened.
AIR 7992
Old 10-02-2006, 01:57 PM   #8
RivetAddict
swebster's Avatar
Good catch. I had a broken shock mount in the passenger side drive wheel when I bought the motorhome. I've heard from a few other Classic (with tag axle) owners about these failures as well. It certainly could be related to running under low air pressure in the rear.
Steven Webster
AIR 1760
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
