Old 04-18-2016, 02:32 PM   #1
1986 34.5' Airstream 345
La Quinta , California
Climate control modual for 1986 34.5
I have a broken fan switch and the temp cable has broken loose from the unit. Plastic. So am looking for a replacement as well as a cable. Frozen. Can anyone point me in a direction. I have scoured the internet. Found several that look close but not sure if compatable. Anyone with deep knowledge?
bbabich is offline   Reply With Quote
Old 04-18-2016, 03:03 PM   #2
Late 70s to early 90s Chrsyler & Dodge vehicles used the same temperature control assembly.
Check out this heater control thread for more info.
Try searching ebay for Chrysler and Dodge heater or AC parts. Eventually one will show up.
The units are very fragile in the way the are fastened to the dash. I found the biggest reason for them getting broken is when someone removes the screws from the instrument cluster panel and tries pulling it out. The heater valve cable doesn't have any give to it so when you pull on the panel hard enough it breaks the mounting tabs on the heater control.
I'm new! Questions about climate control systems - 1979 31' Sovereign Gasgano1979 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-24-2013 05:35 AM
Windshield wiper/washer control modual raveson Classic Motorhomes 9 02-11-2012 01:07 PM
Climate Control Fuses vegburner Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-15-2011 09:42 AM
Desert Climate Meehan Full-Timing 9 05-25-2009 03:05 AM
Are there warm climate Airstream Parks on the East coast who sell lots chazols Our Community 11 08-17-2004 06:04 PM
