Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 11-10-2008, 08:11 AM   #1
swinginping's Avatar
1989 34.5' Airstream 345
waynesboro , Virginia
Clearance Lights.
My clearance lights stopped working on me while i had the mh out last time, I was wondering if anyone else has had this problem?? I tested all the wires coming out of the switch and I had a white wire which had no power so I thought maybe that was it, so i jumped a power wire to it and still no lights... does anyone know where the wires for them run or what colors.... or anything else to look for. Its front and back top clearance lights and the light over the fenders.
1989 345LE
swinginping is offline   Reply With Quote
Old 11-10-2008, 09:01 AM   #2
Retired.
. , At Large
Have you checked the fuses?
Old 11-10-2008, 09:02 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Have you checked the fuses. The parking lights will have a separate fuse.
If you truck chassis is a GM product you may have to look at the head light switch. GM does not use wiring large enough for any additional lighting other than what is on their original chassis. Any additional load on the parking light circuit from additional lights on the truck or from a towed car will cause the wiring to melt usually right at the back of the head light switch. The problem can also be in the head light switch as the copper foil on the printed circuit boards sometime lift off the board from the added heat.
2004 Excursion 4x4
Old 11-10-2008, 09:04 AM   #4
Retired.
. , At Large
A couple of times I've run across a vehicle with all running lights out, and it turned out the bulbs were all blown. The culprit turned out to be a bad voltage regulator on one, and a bad chassis ground on the other.
Old 11-10-2008, 09:14 AM   #5
3 Dog Nite's Avatar
Cleveland , Tennessee
ICC Blink
The clearance lights run through the ICC Blink switch on the dash in my MH. There might be a separate fuse for this. Also check to see if a wire came off the switch. The switch itself may be bad.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-10-2008, 01:37 PM   #6
I checked all wires are actually in the switch, none have fallen out. I will check around the icc switch and see if i can find anything there. I have checked all fuses that are in the fuse panel. I doubt there would a fuse a lone somewhere for these?
1989 345LE
Old 11-10-2008, 02:05 PM   #7
HowieE's Avatar
Images: 12
On the chance that it might be a Chassis ground problem I would get a long wire and attach one end directly to the battery ground and the other to your test light. With this I would then work my way through the circuit starting with the feed side of the switch, the output side of the switch and so on. If you get to a point that you can not follow the wiring any further I would open one of the lights and test both sides of the fixture. If you have voltage there it is a chassis ground problem. If you do not have power there but did have it on the output side of the switch it is most likely a broken wire or open connector.
2004 Excursion 4x4
Old 11-11-2008, 01:40 PM   #8
Well I found the problem, I have power coming into the icc switch, but no power coming out. Can I simply wire my single brown wire(which runs to the lights) in with the 2 hot wires coming in?? I touched them for a second and had clearance lights. I don't see where that should be a problem since the icc switch is simply for convienence and doesnt actually have an electrical purpose correct?? Is this how everyone else fixed theirs?
1989 345LE
Old 11-11-2008, 02:07 PM   #9
HowieE's Avatar
Images: 12
If the load originally went through the ICC switch you know that the circuit feeding that switch is fused for this load. Given that I would wire a relay across the input circuit of the ICC switch and the wire you know feeds the lights. Then I would connect one side of the coil of the relay to the head light switch output and the other to ground. This would control your marker lights when ever the head lights are on. A 30 amp auto relay is about $7.00 a lot less that a new ICC switch.
If you wanted any other control over the markers you could add a toggle switch also powering the coil of the relay. This would give you manual control of the markers, as when parked with head lights off.
2004 Excursion 4x4
Old 11-11-2008, 02:32 PM   #10
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Clearance Lights
I had the same problem a couple of weeks ago, I took off the cover plate behind the goucho in front where the plug comes through the wall. Check the connections there as that was my problem.
james
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 11-11-2008, 02:47 PM   #11
87MH's Avatar
1978 31' Sovereign
Images: 292
Question
Originally Posted by swinginping View Post
My clearance lights stopped working on me while i had the mh out last time, I was wondering if anyone else has had this problem??...
There is a huge amount of amperage running through both the ignition switch and the light switch....either or both of these important switches could be the source of a variety of problems....
I think the ICC switch is somehow connected to the ignition switch (maybe via a solenoid?), but am not 100% for certain. Unfortunately, I do not know of ANY publication which documents the internal (Airstream supplied) 12 volt chassis wiring.
Welcome to the never ending world of chasing Vintage MoHo maintenance issues.
Are there only the two wires (in and out) across your ICC switch?
Since you indicate two hot wires coming in the "hot" side may be used as a junction terminal...then again...maybe not.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-11-2008, 03:53 PM   #12
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
Clearance lights
The power for the clearance lights comes from the parking light power wire at the headlight switch. Airstream used a little cheesy squeez tap to add their clearance light wire to the GM wire. The power then goes up to the ICC Blink switch. This switch is used to blink your clearance lights to say "thank you " to others on the road. The ICC Blink switch is just a normal on, momentary off interupter switch. You can get a new one at Radio Shack.
I had problems with the wire between the headlight switch and the cheesy tap overheating. I just replaced that section of wire (about 3") with a larger guage. I also replaced their tap with a good crimp connector.
Rob
Robfike is offline   Reply With Quote
Old 11-11-2008, 05:16 PM   #13
Thanks Rob, that is what I was thinking, the icc was just a normal toggle disruptor. As I drive a tractor trailer and all trucks come with one of these, rather than trying to modify the switch or any of that I simply added a 30amp in line fuse in place of the icc switch. I dont see why that shouldn't work??? Afterall a quick pull and release of the 4 way flashers is quite popular these days anyways.
1989 345LE
Old 12-29-2013, 05:59 PM   #14
crazeevw's Avatar
Saint Petersburg , Florida
Wondering if someone could tell me what is the safest way to remove front clearance lights and the housing that they are mounted to. Discovered a leak today up front, and figured I'd get at any possible areas for leaks, from front to back, before finishing up roofing paint.
Thanks, Derek
Old 12-29-2013, 10:02 PM   #15
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Hey Derek, the lights are just held on with two screws. They can be hard to get out, and one of mine broke. Good time to upgrade to LED's! I just did all mine, but I'm not happy with the result. I found a thread with the LED's that have two wires and a space under for connectors. The ones I got ground to the frame. I thought I did an ok job but now I have a short so I think ill do the whole job again. The LED lights are really nice...
SebasSF is offline   Reply With Quote
Clearance Lights, What Color? Aerowood Lights - Interior & Exterior 7 06-13-2008 08:40 PM
Clearance Lights For 76 Argosy Gkiesel Lights - Interior & Exterior 3 04-23-2007 03:55 PM
Front Clearance Lights Chaplain Kent Classic Motorhomes 2 07-13-2006 10:29 AM
clearance lights not sealed? Cruiser Lights - Interior & Exterior 3 11-03-2003 03:23 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
