Old 12-14-2015, 12:32 PM   #43
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
10 LED per light, seem to be sealed well, certainly bright enough in my opinion, I dont think I have any pics of them lit. Nice easy project that is a good start at reducing the amps through the light switch.
mayco is offline   Reply With Quote
Old 12-15-2015, 06:27 AM   #44
Thanks for the heads up Mayco!
Ordered mine!
Old 12-19-2015, 08:50 PM   #45
Super fast shipping!
Old 12-21-2015, 05:16 AM   #46
mayco's Avatar
Ive had good luck with Fastenal throughout the years. We have a retail store just blocks from home.
Old 12-23-2015, 10:13 PM   #47
1987 34.5' Airstream 345
KC , Missouri
Originally Posted by shepherd57 View Post
Here you go 1957 24ft Shepherd, twin Chrysler Crowns 6 cly 135 hp apiece
Lovely. I used to have a 22' Shepherd Utility, single Chrysler. They really built those engines well, all geared accessories. Mine sank one unfortunate late November when I was out of town, Pump out the hull, drained and replaced oil and fuel and started right up. Then broke up the harbor ice, motored a mile in the snow at night to get it on the trailer... procrastination can bite
DHC1 is offline   Reply With Quote
Old 12-24-2015, 03:13 AM   #48
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
thanks bought mine I think I found a good video on how to install. Lets hope there are 2 wires.
KrisE MN is offline   Reply With Quote
Old 12-27-2015, 06:11 PM   #49
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
i bought my LED clearance lights from the local TA truck stop. They worked well. They were one wire and they worked great, I see no reason to go through the hassle of dealing with a ground wire (the entire aluminum skin is a ground). The red wire was in a slightly different location than the originals but, it was easy to make them work.
I think it is worth mentioning that the way they were originaly installed at the factory was to caulk them with Butyl caulk after they were installed. I removed the inner panels for access and caulked them the same way. If you are doing this task from the exterior only, be sure to carefully seal both the screws and the wire with Butyl caulk. The last thing in the world you want to do is cause a leak.
ID:	254703   Click image for larger version
Gregsch is offline   Reply With Quote
Old 12-27-2015, 07:24 PM   #50
Agreed.
When I reinstalled my castings, I bedded them down of Tempro, but made sure the weep hole was clear.
My front clearances have 2 wires... I plan to leave the ground unconnected... but the rears... some have 1 wire, and some have 2...
Old 12-28-2015, 04:59 AM   #51
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
All my clearance lights were 1 wire and I used stainless screws to install them. You may get a better ground of the body then of some old wire with a poor connection somewhere.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 12-29-2015, 04:01 PM   #52
Fronts are on!
Very happy!
Old 12-29-2015, 05:18 PM   #53
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Looking good Steve!!!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 12-29-2015, 05:33 PM   #54
Yes indeedy Dave!
Fronts are done, because I had none before. Rears are a ok with incandescent for now, but I do have an issue with the center one "Flaring" light onto the rear camera at night I noticed. I will have to build a little cap/shield.
Tomorrow, I hope to connect those sneaky stealthy LED white Daytime running, amber blinker lamps I put between the headlamps and grill!
Old 12-29-2015, 05:34 PM   #55
wxbuoy's Avatar
Dave and Felicia
Old 04-29-2016, 04:41 PM   #56
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
They are still on sale received a set for front and back this week.
RBonney is offline   Reply With Quote
Mystery LEDs/Lights on side Minno Lights - Interior & Exterior 6 04-20-2009 05:49 PM
Replace POWER-HOG-HOT HALOGENs w/LEDs = Easy al66pine Lights - Interior & Exterior 4 11-01-2008 10:27 AM
LEDs for control panel? gparker Lights - Interior & Exterior 0 02-20-2007 10:27 AM
replace control panel with LEDs, Anyone?? jpsdo Electrical - Systems, Generators, Batteries & Solar 8 08-19-2006 08:54 AM
Bargman 99 & LEDs? walter1 Electrical - Systems, Generators, Batteries & Solar 27 03-10-2006 06:59 AM
