Old 04-01-2015, 10:14 AM   #29
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Theres no sulking with Airstreams........only joy and sense of accomplishment, ya right..and tears and bloody knuckles and empty wallets and..........
mayco is offline   Reply With Quote
Old 04-01-2015, 11:16 AM   #30
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mike
Make sure you put some caulking around the rubber grommet that is a leak source. Don't ask how I know
The Empty wallet, Tears, and Bloody knuckles is the membership fee.
It is like my mahogany runabout, It is a hole in the water into which you pour money
shepherd57 is offline   Reply With Quote
Old 04-01-2015, 11:26 AM   #31
1982 28' Airstream 280
Redwood City , California
Glad to hear!
Originally Posted by mayco View Post
Got my lights yesterday afternoon. Woohoo. I really dont have much to compare them to but they are much heavier duty than the OEM lights for sure. Installing this morning. They are a breeze so far, my OEM lights are a single wire, grounded through the mounting screws. New lights are the same. Nice lights.
dadstoy is offline   Reply With Quote
Old 04-01-2015, 11:36 AM   #32
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Thanks for the tip. I picked mine up this morning. Fastenal got them to my local store overnight. I will store them for later installation......[ATTACH]
newas4mark is offline   Reply With Quote
Old 04-01-2015, 01:13 PM   #33
mayco's Avatar
Good tip on the caulk. I was kinda wondering about where exactly to caulk on the lights that mount to the castings. The 3 middle ones in the rear are pretty obvious since they mount right to the flat body surface. Got them all mounted, they do look so much better with the new lenses. I would like to continue on with other replacements to reduce the amp load on that lighting circuit. Its gotta be pulling a whole lot through that switch.
Old 04-01-2015, 01:19 PM   #34
mayco's Avatar
Love to see a pick of your runabout, love wooden boats.
Old 04-01-2015, 01:50 PM   #35
chriscraw's Avatar
1991 35' Airstream 350
Originally Posted by BambiTex View Post
Long run of small gauge wire?
mmm, don't think so as the wiring is original heavy gauge...seems to be that LED light are extremely voltage sensitive and must have a full 12V to operate but as no other Streamer has mentioned this problem, I'm concerned that there may be other issues?
Thanks for your reply though
chriscraw is offline   Reply With Quote
Old 04-01-2015, 05:17 PM   #36
shepherd57's Avatar
Lindsay , Ontario
Here you go 1957 24ft Shepherd, twin Chrysler Crowns 6 cly 135 hp apiece
Name:	shepherd Slides 040.jpg
Old 04-01-2015, 05:29 PM   #37
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Nice investment!
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 04-01-2015, 07:00 PM   #38
mayco's Avatar
Oh man! Link didnt work here so I just googled it, WOW thats cool.
Old 04-01-2015, 07:22 PM   #39
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
As far as 10 volts is present in the rear, I would check the factory harness around where they spliced for the trailer wiring, if not there keep working your way forward with your multimeter until you find battery voltage.
bobmiller1 is offline   Reply With Quote
Old 04-24-2015, 01:50 PM   #40
I installed two of the new LED clearance lights on the rear, working on other projects. They work great!
Old 04-27-2015, 10:20 PM   #41
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
I bought the five amber, and three red I need, and installed one of the amber ones as a test. When I went to remove the original amber lens to see what kind of lights I was dealing with (1 or 2 wire) the base of the clearance light (the white'ish abs) shattered. So I was commited to install one. I had the two wire system, and tested with multimeter to see if I could ground through the body. It worked on the multimeter with 20 VDC selected I showed a 13.1V. So I taped off the ground side, and spliced the hot side, and she fit like a dream. i then used VULKEM to completely surround the base. Will install the others when I have time. Until then they live in my project drawer inside the airstream.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 12-14-2015, 12:00 PM   #42
https://www.fastenal.com/web/products/details/5101824
$3.48
Applications: LED Truck Lights"; Notes: Energy-saving. Durable Long life time LED Double Bullseye Red Light. Energy-saving; Durable; Long Life. Catalog: Pdf ...
That was it!
Thanks Mayco!
Are they good? Multiple LED?
How do they look lit?
Mystery LEDs/Lights on side Minno Lights - Interior & Exterior 6 04-20-2009 05:49 PM
Replace POWER-HOG-HOT HALOGENs w/LEDs = Easy al66pine Lights - Interior & Exterior 4 11-01-2008 10:27 AM
LEDs for control panel? gparker Lights - Interior & Exterior 0 02-20-2007 10:27 AM
replace control panel with LEDs, Anyone?? jpsdo Electrical - Systems, Generators, Batteries & Solar 8 08-19-2006 08:54 AM
Bargman 99 & LEDs? walter1 Electrical - Systems, Generators, Batteries & Solar 27 03-10-2006 06:59 AM
