Old 03-30-2015, 05:49 AM   #15
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I sense a fly in the ointment !
bobmiller1 is offline   Reply With Quote
Old 03-30-2015, 05:53 AM   #16
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
We will see, I have yet to pull apart one of the oem lights to see whats what. Ill still risk the $45.
mayco is offline   Reply With Quote
Old 03-30-2015, 10:14 AM   #17
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mike
Here are the lights I got yesterday I think they are the same. They are single wire I have used theses before and they worked fine.
The ground is via the mounting screw The body of the coach is your ground this has always worked for me. You can see the recess in the back for the wire. It is only needed for the 3 rear red center lights because they have no casting they mount right against the body.
How do you like my tail light Conversion to led
I don't know why SebasSF had problems his coach body should have been ground ?
ID:	235193   Click image for larger version
shepherd57 is offline   Reply With Quote
Old 03-30-2015, 12:46 PM   #18
mayco's Avatar
That tail light is beautiful! Yes I dont foresee iny problems with the ground, one could always crimp a hoop connector on a pig tail and run you mounting screw through it. I wish they had pictures of the back of the running lights but I couldnt find them anywhere so, cross my fingers and I think I can make them work. No biggie if they dont, can always return and eat the shipping.
Now those tail lights are a bit more complicated is my understanding. There is even a relationship to the cruise control. I havent delved into that yet. Like I said, your retrofit is niiiiiice.
Old 03-30-2015, 06:08 PM   #19
1982 28' Airstream 280
Redwood City , California
I'm hoping that my only disappointment is going to be the state they were shipping out of today.
dadstoy is offline   Reply With Quote
Old 03-31-2015, 06:27 AM   #20
bobmiller1's Avatar
How about some more info on the taillight conversion...looks pretty cool to me, did you do away with the center back-up light in the taillight housing ?
Old 03-31-2015, 06:59 AM   #21
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
I just received these for the running lights
http://www.amazon.com/dp/B00877SL2M/...40_TE_3p_dp_1#
They work great but are polarity specific- didn't work one way flipped them over and perfect-
Also grabbed these while I was at it..
http://www.amazon.com/dp/B00LEBLI82/...541850_TE_item
What a difference they make - and the price was great...
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 03-31-2015, 12:16 PM   #22
shepherd57's Avatar
Lindsay , Ontario
Yes I am making all 6 work as Tail, Stop ,Signal.
In my coach I have the 4 inch scare lights in the body above the bumper that are also backup lights. They will also be LED
I bought 6 new lenses, And 6 LED lights they have 61 LEDs in them.
I had the centers cut out at a machine shop on a lathe to match the led lights, Then I bonded them together.
The new lights replace the original lenses and cans
Then I used a die grinder with a fine carbide bit to enlarge the openings in the taillight bezel.This is a trial and error so be careful this is a plastic bezel
I am in the process of changing all of the outside and inside lights to LED
I have to give HowieE credit for the taillight idea he did it on his trailer some time ago that is where, I got the idea from he has a post on it if you search his posts.
ID:	235279   Click image for larger version
ID:	235281   Click image for larger version
Old 03-31-2015, 12:40 PM   #23
Very nice!
Old 04-01-2015, 08:48 AM   #24
chriscraw's Avatar
1991 35' Airstream 350
An Led question. I recently bought a couple of LED number plate lights which worked fine when test connected to the 12V battery. At the rear of the 350LE though, they would not work when connected and I determined that I was only measuring 10.6 V at the coach rear connection ? Why the voltage drop..any ideas? Thanks
chriscraw is offline   Reply With Quote
Old 04-01-2015, 09:12 AM   #25
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Guess
Long run of small gauge wire?
BambiTex is offline   Reply With Quote
Old 04-01-2015, 09:58 AM   #26
mayco's Avatar
Got my lights yesterday afternoon. Woohoo. I really dont have much to compare them to but they are much heavier duty than the OEM lights for sure. Installing this morning. They are a breeze so far, my OEM lights are a single wire, grounded through the mounting screws. New lights are the same. Nice lights.
Old 04-01-2015, 10:02 AM   #27
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1427904113.976107.jpg
Old 04-01-2015, 10:04 AM   #28
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I'm 'sulking in the corner' as had all mine replaced a couple of months ago with full price units!
martin300662 is offline   Reply With Quote
Mystery LEDs/Lights on side Minno Lights - Interior & Exterior 6 04-20-2009 05:49 PM
Replace POWER-HOG-HOT HALOGENs w/LEDs = Easy al66pine Lights - Interior & Exterior 4 11-01-2008 10:27 AM
LEDs for control panel? gparker Lights - Interior & Exterior 0 02-20-2007 10:27 AM
replace control panel with LEDs, Anyone?? jpsdo Electrical - Systems, Generators, Batteries & Solar 8 08-19-2006 08:54 AM
Bargman 99 & LEDs? walter1 Electrical - Systems, Generators, Batteries & Solar 27 03-10-2006 06:59 AM
