Old 08-28-2018, 10:55 AM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Classic Motorhome Vertical Window Gasket
I am in the process of replacing my window gaskets. I am having a issue getting the vertical piece to go into the groove, I have read on the site about how people have replaced it but is their a easier way to get the gasket into the groove without breaking a window. Also how do you change out the fuzzy strip that is mounted between the windows (anti rattle??) and who as it in stock. Any help will be appreciated.
cole3444 is offline   Reply With Quote
Old 08-28-2018, 12:12 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
If you take a look at the old vertical lip seal you will see how Airstream modified it to fit. The fuzzy strip is called “Fin” seal, you pull it out with a pair of pliers and install the new one with a pocket screwdriver. All material is available through Inland but be prepared to pay a SODOMY charge. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-28-2018, 12:24 PM   #3
1971 31' Sovereign
1972 31' Sovereign
bobmiller1
Thanks Bob I read thru about half of your post and decided to just ask, I appreciate the info will look at old gasket and appreciate the info on the Fin seal and the advanced notice on cost. Jim
Old 08-28-2018, 01:21 PM   #4
bobmiller1's Avatar
No problem, are you coming to the “Get-Together”?
Old 08-28-2018, 02:55 PM   #5
1971 31' Sovereign
1972 31' Sovereign
Not sure yet on the get together trying to get a few things fixed and trying to get tires put on, most tire stores around me don't mount on 19.5 rims. Trying to get the 8R 19.5 on rear and the 225/70 19.5 on front for better steering if I can find descent tires not 3-4 years old in the warehouse. We want to start using it for a while before any updates started. By the way yours is looking great.
Old 08-28-2018, 05:27 PM   #6
1971 31' Sovereign
1972 31' Sovereign
Well after a hour of sweating pushing and prying with a thin blade screwdriver I finally got the vertical gasket installed. The design is a little different. The driver window is done and the passenger side tomorrow morning when it is not 90+ outside. Pic shows the difference, got mine at VTS.
Old 08-29-2018, 11:27 AM   #7
1971 31' Sovereign
1972 31' Sovereign
Both windows are now complete with new gaskets, Fin seals and window channel seals will be next
Old 08-30-2018, 10:16 PM   #8
1979 28' Airstream Excella 28
PRESCOTT , Arizona
I'm having the same issue with the vertical lip. tried silicone spray no luck . wandering if the rubber is to old to flex ... even put it out in the Az sun to see if it would soften up.
nazguy is offline   Reply With Quote
Old 08-31-2018, 01:34 AM   #9
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Make sure the channel is clean and has no burs.
Warm the entire seal in hot water with a good dose of dish soap added before you slide it in. Of course the soap will also make it hard to grab the seal so have a good pair of pliers to help slide it in.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 08-31-2018, 11:21 PM   #10
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I’ve tried to install mine over my vacation in Italy. No joy. Did you get part of it in and then slide the rest in or did you have to prise it In over its entire length? Thanks
Boom Sounds is offline   Reply With Quote
Old 09-01-2018, 06:08 AM   #11
1971 31' Sovereign
1972 31' Sovereign
I had to use a narrow width flat screw driver to push the lip in all the way down. I tried heating it up with a heat gun, silicone and it would not slide in. When I started I made sure it was a nice fit at the start because my gasket would not slide once I started pushing it in. I took my time to keep from breaking my window. It looks great when finished.
Old 09-01-2018, 11:24 AM   #12
bobmiller1's Avatar
Well worth the effort, that’s why so many don’t do it ! Regards, Bob
Old 09-01-2018, 01:44 PM   #13
Thanks, will try that
Old 09-19-2018, 11:23 AM   #14
1971 31' Sovereign
1972 31' Sovereign
Classic Slider Window Removal
Is the vertical gasket on the side slider windows on my classic the same as the cockpit gaskets. Getting ready to order some parts and was needing to replace my slider gaskets. Will stationary windows come out when the small screws are removed or are their other items that need removing. Read some of bobmiller1 thread and was wanting to double check on the removal process.
Front Side Windows Classic - Vertical lip install noiva Classic Motorhomes 39 08-22-2018 05:17 PM
Vertical Shower Head Guide Bar - 2007 Classic 87MH General Interior Topics 0 07-23-2016 10:25 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Vertical Lip Seal Inland RV Center, In General Motorhome Topics 0 01-19-2004 02:09 PM
