Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-17-2009, 05:05 AM   #1
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
Classic Motorhome Tires
Has anyone converted from their original size 8R19.5 to 225/70R19.5 Tires. I am particularly concerned with the clearance between the tag axle tire and the inner fender since it is minimal now with the original size tire. I believe there is sufficient clearance between the duals.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 05-17-2009, 10:44 PM   #2
1989 34.5' Airstream 345
Silverton , Colorado
Gunter,
Nope...I run Michelins...tires are more important than the engine, to me...can always find a 454, but replacing a 345 is getting harder to do.
mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-18-2009, 03:14 PM   #3
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
What I want to put on are Michelin XZE, but I am concerned about the clearance since these are 8.9 wide.
Gunter
Old 05-18-2009, 04:38 PM   #4
Not sure about the extra inch, if the front bonnet has ever been compromised(read hit something hard enough to bend it...we have 8.0 XZA 19.5>...since I don't do my tires on the MH, I don't know about clearance, but someone out there HAS to have thought about this before. I would want to know a couple or so things before I jumped...
Will the suspension be affected? Will this have any effect on the airbags(I know, part of the suspension, but maybe another can of worms)? What will the effect on the steering be?
I'm curious about your plan to go a little bigger on the tires...is there something you have heard, or is this a personal knowledge kinda thing?
m
Michael & Tracy
1989 345 Motorhome
Old 05-19-2009, 11:33 AM   #5
Gunter, I'm curious as to why you want to change from the 8R19.5 to the 225/70R19.5 tires. What are the advantages and disadvantages?
1975 24' Argosy Motor Home
Old 05-19-2009, 01:41 PM   #6
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
Hi Gunter
What we have been doing on Classic Motorhomes for the last 15 years or so is running the 225/70 19.5 tires on the front but staying with the 8.00 19.5's on the rear. The reason for this is the 225/70's have a more precise steering feel.
On the rear the 8.00's ride smoother and because of their larger diameter you don't increase the engine RPM.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-19-2009, 08:30 PM   #7
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
I have new Bridgestone 8R19.5 on the front, a friend of mine gave me 7 new Michelin 225/70R19.5 that I want to put on the rear and the spare when my current tires either wear out or the sidewalls start to deteriorate. The only concern I have is the tag axle tires due to the clearance to the inner fender.
Gunter
Old 05-20-2009, 06:21 AM   #8
Andrew T's Avatar
London , Ontario
Hi Gunter
If you use the 225/70's on the duals you will increase your engine RPM by 5% or 150 RPM at 60 MPH. I always felt the 454 was spinning plenty fast on the pre overdrive coaches.
As well the 225 has less sidwall roll and more traction so it will put more pressure on the tag axle bearings and the axle itself. The tag axle bearings do not have a lot of margin for additonal load.
The shorter sidewall also rides firmer so you will get more pounding through the duals into the body of the coach.
They may work ok but those are the reasons we only use them on the steering axle.
Andrew T
Andrew Thomson
London, Ontario
Old 05-20-2009, 08:51 AM   #9
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Stick with the 8R19.5, I've been running Goodyear G647 RSS tires for years and get great performance out of them.
Mike Leary is offline   Reply With Quote
Old 05-20-2009, 12:52 PM   #10
guy99's Avatar
Dunsmuir , California
Images: 16
Originally Posted by Andrew T View Post
Hi Gunter
Andrew T
I run Michelin 225's on the front and 8R's on the back. Thus I don't increase RPM but do get a wider stance in front. I carry an 8R spare.
So far, so good.
The Michelins made a huge difference in the ride.
Oops, Andrew I didn't see your earlier post on this same configuration, oh well, great minds etc.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-20-2009, 03:12 PM   #11
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
It is hard to turn down new tires at no charge.
Gunter
Old 05-20-2009, 09:02 PM   #12
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Tnstaafl
- there's no such thing as a free lunch!
I have 8r19.5 Dynatracs on my front wheels - last digits on the dot #'s are 02207 which I assume means manufactured in February, 2007?
However on the remaining 6 I have the Michelin 8r19.5's, but with dot #'s ending in 0300 and 0700!
I know they need replacing, but what with, Dynatracs or Michelins?
On size, the consensus appears to be, keep the 8r19.5's for the duals and tag and something with less diameter and more width up front like 225/70R19.5
elbundi is offline   Reply With Quote
Old 05-29-2009, 03:23 PM   #13
Chuckles's Avatar
Iwerne Minster , Dorset. UK
This is strange. I recently had a 345 in for UK preparation, and that had the larger tyres all round. After my 310 with the standard tyres the cornering was phenomenal, despite the front steering and suspension being totally shot away. I replaced the bell cranks, suspension arms and others, and the road holding was far superior to my 310.
I take the point that these bigger tyres do run the engine faster due to the smaller radius, hence my wishes to GV overdrive - OR even fit the 4 speed gear box. Has any one any thoughts on that?
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 09-13-2009, 08:23 AM   #14
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
I am asking for your input in regard to this possibility. Since I have limited clearance between the inner fender with the current 8R19.5 Tires on the Tag Axle, I am thinking of installing the 225/70R19.5 on the Front and the other four on the drive axle and leaving the 8R19.5 on the Tag. The difference in diameter between the two tires is 1" or between the center of the tire and bottom .5 inches. I would believe there is that much difference in road surface and this wouldn't be a issue. This way I would have the stability of wider tires on the front and drive axle and still maintain the original clearance between the inner fender and tire on the Tag axle. The only other alternative is to machine a .5" aluminum spacer between the wheel and drum to achieve additional clearance.
Gunter
Old 09-13-2009, 08:30 AM   #15
Mike Leary's Avatar
Ajo , Arizona
Maybe someone knows more, but my mechanic, who maintains the Fire Dept. rigs, told me the wider the tire, the better the possiblility of wheel bearing failure.
Old 09-13-2009, 09:34 AM   #16
richinny's Avatar
2011 34' Classic
if you decide to do that change i'd be curious to see weigh slips before and after. in theory, wouldn't the axle with the taller tires carry more of a load?
Ricky
Old 09-13-2009, 12:28 PM   #17
Gunter
gunner's Avatar
1966 24' Tradewind
Greenville , Ohio
I believe the Tag axle is more forgiving by that I mean that it moves up and down with less pressure than the drive wheel axle. I did have the concern that I wouldn't have as much of a down force on the drive wheels and could affect traction.
Gunter
Old 09-13-2009, 07:49 PM   #18
I have noticed that the tag axle tires leave rubber tread marks when executing a sharp turn in a parking lot...m
Michael & Tracy
1989 345 Motorhome
Old 09-14-2009, 10:34 PM   #19
silverback's Avatar
2006 28' Safari SE
Colorado Springs , Colorado
Mike,
I think the tread marks may be unique to your driving style...
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 09-15-2009, 05:24 PM   #20
elbundi's Avatar
Leesburg , Georgia
My tags leave a bunch of marks on sharp turns too, like exiting our drive way.
Could it be to do with age, or something else? It would be quite a site seeing one of our classics burning donuts in the car park!
Classic Motorhome Tires gunner Classic Motorhomes 12 10-08-2007 04:17 PM
What tires do you recommend for 310 motorhome? Alumatube Classic Motorhomes 17 06-10-2007 08:19 PM
Motorhome tires? where to buy in Atlanta Honkity Hank General Motorhome Topics 2 02-08-2006 04:13 PM
Motorhome tires and wheels RichardT Airstream Motorhome Forums 2 04-06-2004 04:35 AM
