Old 05-24-2010, 08:07 AM   #57
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
If you weigh your axles and look up the chart you will find you only need about 50 PSI in the duals and the tag axles on a 345. The 280 only about 45 PSI. The softer tire pressures at the rear really improves the ride and takes a lot of vibration out of the coach. Tire life will be better due to even tread wear.
The front tires need 70-85 in most coaches.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-24-2010, 05:31 PM   #58
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I thought I would provide an update on tire temperatures after I installed the Michelin XZE 225/70R19.5 Tires on the front and drives and 8R19.5 on the Tags.
Ambient temperature 85 degrees farenheit
Full tank of Gas, Full tank of water
Drove 30 miles.
All tires except for Tags 85 psi
Tags 75 psi
Temperature farenheit
Tire inside middle outside
left front 109 123 122
right front 105 117 105
Drive left outer 121 133 132
Drive left inner 127 129 132
Drive right outer 116 129 127
Drive right inner 124 131 130
Tags left 102 122 115
Tags right 101 114 120
I am awaiting for your comments/concerns especially since the Tags are larger tires than the drives.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 05-25-2010, 11:24 AM   #59
1989 34.5' Airstream 345
Silverton , Colorado
We put Michelin all around...I have noted that the tag axle tires leave scorch marks when doing a sharp turn in a parking lot...GVO makes about 1 mpg difference for us...not much, but I'll take it where it happens...I do like the sanity of a well-made tire, and I believe Michelin is up to that value...just one man's humble opinion...and 5-6 mpg is not a flattering statistic, but it DOES get me down the road...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-25-2010, 01:53 PM   #60
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Andrew T
I agree about the ride. When I ran mine that low, I lost about .5 MPG. So, as a compromise I run 70. The ride is still much softer after replacing Toyo and Bridgestone tires with Michelins.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-30-2010, 08:24 PM   #61
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
As a new member with a 325 Cumins/Allison/ GV unit, I'm trying to figure out what to do regarding carrying a spare. My rig didn't come with one, although it appears that there might have been some provision to carry one under the floor, just forward of the fuel tank. I've got 8r19.5 Michelin XVA's all around, except the tags (which are Coopers, same size).
Forgive me if I'm being dense, but are those of you with spares carrying mounted tires, or just the rubber? And if the tires are mounted, what wheel do you have the tire mounted on? It appears that the front wheel is quite different from the rears.
Many Thanks,
Charly.
streamquest is offline   Reply With Quote
Old 05-31-2010, 04:27 AM   #62
Jamestown , Kentucky
Images: 13
Hello streamquest, My 345 has a spare
a steel wheel complete and ready with rubber, I assume ? for the drive, tag axle
John H. is offline   Reply With Quote
Old 06-01-2010, 12:33 AM   #63
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks John.
Is it safe to assume then that a flat on the front will still leave you stranded since the rear wheels would not fit up front?
Charly.
Old 06-01-2010, 07:46 AM   #64
As a Noob here I also looked at the front and rear wheels and thought they were very different.
In fact on my 345 they steels, and are all the same... the offset of the wheel rim is mounted inside on the front, and the inner drive axle, and the outer drive axle and the tag they are mounted offset out... if that makes sense!
Old 06-01-2010, 09:08 AM   #65
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
On our 345 I annually replace the front tires with new and then rotate the front tires to the tag. All the wheels are the same bolt pattern and I can move tires where ever I want. The only steel wheels I have are the inside duals on the drivers.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-02-2010, 06:50 AM   #66
Images: 13
Originally Posted by streamquest View Post
Thanks John.
Charly.
No, You Just reverse the wheel, Inside out
where you in Florida this past winter streamquest ?
we visited with some nice airstreamer's from Mass.
down Saint Augustine way
Old 06-02-2010, 01:02 PM   #67
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Drove 30 miles.
Tags 75 psi
With consistant center of tire warmer I would reduce air pressure, to get the numbers more consistent.
What was the basis for the 85# if not a weight based number, I would reduce front to 80 recheck numbers and maybe even 75 and check.
I have found I get a difference on the sunny side of the vehicle if the right was sunny the front would be right but rear doesn't match.
Old 06-02-2010, 04:30 PM   #68
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks again John,
I was definitely not in Florida.
I just purchased my rig this past winter, and have spent most of the time since then tearing it apart. I'd like to think that I'm on the "comeback trail" at this point, but I still have a LOT of work to do.
As far as the tires go, I have Alcoa aluminum wheels on all six. Do you know if a spare mounted on a steel wheel would replace any/all of them in a pinch? I'm guessing "yes", but I'd like to be sure before I buy one.
Charly
Old 06-03-2010, 02:48 AM   #69
Images: 13
Thanks again John,
Charly
Yes Charly, that would work I believe
All Alcoa, You are Fortunate
Classic Motorhome Tires gunner Classic Motorhomes 12 10-08-2007 05:17 PM
What tires do you recommend for 310 motorhome? Alumatube Classic Motorhomes 17 06-10-2007 09:19 PM
Motorhome tires? where to buy in Atlanta Honkity Hank General Motorhome Topics 2 02-08-2006 05:13 PM
Motorhome tires and wheels RichardT Airstream Motorhome Forums 2 04-06-2004 05:35 AM
