Old 03-04-2016, 04:58 PM   #99
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Originally Posted by Waipio Rim View Post
For the select few, a diesel pusher Land Yacht being parted out in Austin:
http://austin.craigslist.org/rvs/5471636174.html
Wow ! A Cummings and all the other parts for a buck ? Sounds almost to good to be true !
bobmiller1 is offline   Reply With Quote
Old 09-09-2016, 12:40 AM   #100
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
Right Rear quarter panel and bumper?
Oops! Had a little fender bender.
I mashed in the bumper in the right rear side and crushed the right rear quarter panel. I thought I was in Park. I wasn't.
Does anyone have the parts? Or can someone reshape the bumper?
I know that Bkahler some time ago was parting out an old 345 which is what I have.
Thanks!
Jenniflow is offline   Reply With Quote
Old 09-09-2016, 02:14 AM   #101
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
The bumpers are the same from the '77 Argosy thru into the Classics but how badly is the bumper bent? Unfortunately they are no longer available (went out of stock quite recently)
http://airstreamsupply.com/Airstream...77-1993-100498
Equally the lower rear quarter (called a banana wrap) also is no longer availale.
http://airstreamsupply.com/Airstream...rb-side-200860
And if you have crunched the actual aluminum panel you are probably looking at a much more significant repair (there are support channels running in that panel will probably also been bent.
If you take a look at the repair Ernie is doing to Peanut in the thread you will get an idea (http://www.airforums.com/forums/f310...on-148273.html)
martin300662 is offline   Reply With Quote
Old 09-09-2016, 10:35 AM   #102
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I tweaked our rear bumper pretty well, snagged it on a post and bent an end out to about 90 degrees. A nephew who was in welding school was able to get it back in shape.
Waipio Rim is offline   Reply With Quote
Old 09-09-2016, 04:40 PM   #103
Jenniflow's Avatar
1982 34' Limited
Question Pics of the damage to rear bumper and rear quarter panel
So here's how it looks. My husband and I are busy dreaming up weird art solutions in cast we can't find the parts. But I'd like to find the parts!
Whattaya think?
Old 09-09-2016, 04:59 PM   #104
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yes it does say the part is out of stock, so contact them to find out when they will have new stock, also try Vintage Trailer supply and Inland RV, as they might have in stock.
As for the bumper I would take it off and give it a good aluminum body shop or a competent metal man should be able to heat and bend back to shape.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 09-09-2016, 07:22 PM   #105
Jenni, I agree with Tony. That bumper is definitely fixable.
If the lower plastic valance is all that you damaged then you're in better shape than I thought from your original description. Did you damage the aluminum corner at all or is it just the bumper and the plastic valance?
I don't have a replacement valance left from the 345. To bad it wasn't the left side that you damaged, I have one sitting here that Martin bought for Peanut that won't work due to the differences between the early Argosies and the later Classics.
How about posting some pictures showing the damaged area from the side?
Old 09-10-2016, 04:46 AM   #106
1999 35' Cutter Diesel Bus w/slide
Sacramento , California
There is a guy in Sacramento who can fix the plastic, I had him fix mine a few months ago and looked like new. You can even drive down the night before and he will start very early in the morning and be done by noon so you can drive home, depending on the amount of damage (hard to tell from these photos taken at night). Terrry at Sacramento Bumper, 916-386-9700
Ryker is offline   Reply With Quote
Old 09-10-2016, 12:31 PM   #107
Jenniflow's Avatar
1982 34' Limited
Thanks Ryker. On one of our trips we may stop in Sac.
And thanks Isuzusweet. I'll check.
Bkahler, here are some more pics:
We're thinking we'll get into the storage area under the bed and see if we can knock out the dent from inside? Or try suction cups?
I took a number of pics of the plastic and bumper. There are a couple of shards inhand and the big piece. You can see the ragged edges where it tore off the bumper.
And of course, you can see the bumper is pushed in on that right edge.
thoughts?
Old 09-10-2016, 01:02 PM   #108
Jenni,
The dent in the aluminum can definitely be fixed. However don't do anything to that dent until you've removed the rub rail. The rub rail is thicker and stiffer so any work you do on the dent is going to be resisted by the rub rail. So remove the rub rail and try using suction cups. Better yet, I'd suggest stopping by a body shop after you've removed the rub rail and ask them if they can try pulling the dent out. There is also a product called Super PDR that seems to work pretty well on dents. Martin bought a kit to use on Peanut and Ernie was able to get most of the dents looking pretty darn good.
Once the dent is straightened then straighten the rub rail and reinstall.
Salvage all of the plastic pieces for the valance and give them to whoever is going to do the repair work on the valance. If they piece it together properly it should be good enough to use.
Find a good fab shop and have them straighten the bumper.
Old 09-10-2016, 04:15 PM   #109
Jenniflow's Avatar
1982 34' Limited
Oh I'm so glad you caught us before we started to undent the dent. Will do! Thanks!
I think my my sweetie, Joe, may be joining the forum because he's now fully onboard with the motyho project. He's gotten in up to his eyeballs on some things already. Meaning he got water in his eyes when under the rear curbside bed trying to fix a leak.
Plenty for two to do around here!
Old 09-21-2016, 10:28 AM   #110
Anybody have or know where to get the spotlight? I have the controls in my 1995 Classic 36 but the spotlight is gone with a cap over the hole on the roof.
Old 09-21-2016, 12:22 PM   #111
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
West Marine
http://www.westmarine.com/buy/guest-...6?recordNum=19
Pricey but works great.
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 09-21-2016, 11:36 PM   #112
Thanks, Paula & Ed! Funny, I spoke to Sunny in Arkansas, and he told me it is a boat spotlight but that is all the information that he had.
What did a Classic Motorhome Cost New? Keyair Classic Motorhomes 42 08-12-2012 07:39 PM
West Poisonous Snake Encounters AND Avoidance Ray Eklund Boondocking 59 06-17-2012 01:36 PM
Replacing colored striping tape and words Stumpjumper Exterior Restoration Forum 5 04-12-2012 07:34 PM
Several ORIGINAL 1973 AIRSTREAM PARTS!!! refrigerator, oven, lights, more! eBay Watch Airstreams on eBay 1 03-20-2012 01:18 PM
Need some parts for a window clean up ND10CentCan Windows & Screens 43 03-19-2012 06:35 PM
