Old 09-01-2009, 03:01 PM   #1
maltnhops's Avatar
1989 34.5' Airstream 345
Strafford , New Hampshire
Send a message via AIM to maltnhops Send a message via MSN to maltnhops Send a message via Skype™ to maltnhops
Classic Motorhome Air Horns
I feel a little silly asking this, but...
How do I get the air horns on my '89 345 to work? To my knowledge, the horn button on the steering wheel is activating a "standard" horn that is mounted behind the front access door behind the grill. I have air horns on top, but I have no idea to activate them. Any help is appreciated.
Wally
'89 345LE Classic Motor Home
'55 Flying Cloud - sold
'61 Bambi - sold
'66 Caravel - sold
'64 Safari - sold
www.vintageairstreamer.com
www.classicairstreammotorhome.com
maltnhops is offline   Reply With Quote
Old 09-01-2009, 03:03 PM   #2
maltnhops's Avatar
Whoops... I guess I forgot to update my saved signature. No more Bambi.
Wally
'61 Bambi - sold
'66 Caravel - sold
'64 Safari - sold
Old 09-01-2009, 03:41 PM   #3
1986 34.5' Airstream 345
Tyler , Texas
air horns
On my 86 345 the horn button on the steering wheel activates the air horn look alikes on the roof. I do not have any horns behind the grill. I am thinking about adding a real set of air horns but it requires a compressor and tank.Pete
pjude is offline   Reply With Quote
Old 09-01-2009, 04:02 PM   #4
345bill's Avatar
Las Vegas , Nevada
On our 90 345 the roof air horns are activated with steering wheel button. There is a electrical horn relay under the dash to the right of steering column and a solenoid for the air lines mounted at the left kick panel.
I'm calling left & right as if you're sitting in driver seat.
A plunger, inside solenoid, stuck open one time and horns blew until air was depleated. It wasn't easy to find solenoid but it was easy to fix once I found it. Just had to dis-assemble, clean with very fine emory cloth & lubricate. Havn't had any problem since. Perhaps your's is stuck in closed position.
345bill is offline   Reply With Quote
Old 09-01-2009, 08:58 PM   #5
maltnhops's Avatar
Thanks for the replies, but now I may be more confused than ever. pjude says they're not even real air horns, but 345bill says they are. I will be looking under the "hood" again at what I think is a horn and I'll have someone else press the horn button so I can determine where I think the sound is coming from. I will also look for the horn relay and solenoid described by 345bill.
Someday, I would like to add some annoying musical air horns just for fun. But for now, I can think of plenty of better ways to spend $90 on the MH.
I just bought an expensive brass bathroom faucet on ebay for $37 because brass is definitely out of style by today's standards. But, it's perfect for 1989!
Thanks again for your replies.
Wally
'61 Bambi - sold
'66 Caravel - sold
'64 Safari - sold
Old 09-02-2009, 10:33 AM   #6
345bill's Avatar
Las Vegas , Nevada
[QUOTE=maltnhops;742733]Thanks for the replies, but now I may be more confused than ever.
maltnhops-one thing I've learned here on the forums is that there are many different items and locations of items even on the same year and model MH. You'll get two different people describing what's on their particular MH, each may or may not describe whats the same as yours.
What has worked for me is reading all posts I can find on a particular subject then use that to whatever circuit I'm presently trying to figure out on mine and usually come up with an answer. Might be because of so few MH's produced they never stuck to actual production line type assembly or might depend if original owner had certain options he wanted?? Also how many items have been added or removed through the years.
Everyone here has helped me out many, many times and it gets easier to understand the more familar you get with your own coach.
Old 09-15-2009, 10:34 PM   #7
maltnhops's Avatar
I had a friend listen outside as I blew the horn (from the steering wheel button). It definitely blew a horn "under the hood". It's mounted directly in front of the driver, about in line with the headlights, vertically speaking. There was a point when my buddy thought he heard some noise from the airhorns, too. I thought maybe it something to do with the compressor building up pressure to blow them. It sort of made sense to me that there would be a "normal" horn because there would be no air pressure to blow air horns if the motorhome was not running. Am I making any sense?
Wally
'61 Bambi - sold
'66 Caravel - sold
'64 Safari - sold
Old 09-15-2009, 10:49 PM   #8
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Hmmm - on Airtini, all I hear is a relay clicking - nothing else. I have seen the horns "under the hood" but have not touched anything else yet.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 09-16-2009, 01:34 PM   #9
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If they are for real,you may need to dis assemble and clean them. If they have been open (NO BELL COVERS) they get dirt and moisture and they do corrode inside. If they have ever been in a salt environment that definitely will add to the interior corrosion of the horns.
Depending on the OEM U may be able to get new gaskets for them. Most of the horn company's that make for big trucks are still in business.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 09-16-2009, 02:04 PM   #10
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Okay, I drove semis with real air horns for some time and they all had air lines running to them. When I look at the horns on the roof of my 345 all I see is an electrical wire running to them. I think they are electric.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 09-16-2009, 02:54 PM   #11
3 Dog Nite's Avatar
Cleveland , Tennessee
My 1989 345 has electric horns on the roof & a standard horn behind the grill. Both are activated by the steering wheel button. You can check the rooftop "airhorn" by unplugging the standard horn & pushing the steering wheel button. You can also look at the rooftop horn. Does it have electric wires or airlines going to it? I dream of putting those railroad engine airhorns on Laverne. Of course I'll need a 2nd reserve tank for this.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 09-16-2009, 10:35 PM   #12
Silverton , Colorado
Our 345 has the horn button on the steering wheel, and another set of horns under the 'hood' has a toggle switch on the dash, to the right of the steering wheel...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-18-2009, 11:48 AM   #13
They are not air horns.
The horns on top are not air horns just fakes. There is no air supply and there is a 12 volt wire going to them. They are not even as good as my Jeep. It pained me every time I had to blow the horn with no one believing it was the big beautiful Airstream Motor Home. The solution was purchasing a set of real air horns from Camping World that would fit in the front, lower section, of the Motor Home. I rewired the steering wheel switch to the new horns and now people took notice. I kept the fakes to keep the holes filled.
Howard Lefkowitz is offline   Reply With Quote
Old 10-18-2009, 02:37 PM   #14
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
Electric on roof and electric in grill.
Mine on top had stopped up with age and bugs, just clicked and hummed.
Found a good set of S/S at a marine supply
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
air horn, horn
horns on '89 motorhome 345LE Turtle One General Motorhome Topics 0 06-15-2009 09:54 PM
NOS Classic motorhome air compressor - eBay bkahler Classic Motorhomes 0 03-22-2008 12:25 PM
Air Horns aren't working kzener40 Airstream Motorhome Forums 21 06-12-2005 07:26 PM
motorhome air bag modification? bencbailey General Motorhome Topics 9 04-22-2005 09:12 PM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
