Old 03-11-2018, 11:31 AM   #1037
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I still have this on my calendar.
Still need to take a couple more 'test' runs to make sure the Cummins/Allison well work. Get some fuel mileage history. Fix any other bugs in the system.
Got my new knee 12 days ago and doing good with it. Just need to see how long before I can get back to driving. The doctor said I can't drive for 6 weeks. That would be April 10. I'm thinking I'll be back in the drivers seat next week.
The trip would be a little over 1000 miles each way. That's 900 miles past my AAA towing radius. Maybe I need to upgrade to 'unlimited towing' before I go:<)
I plan to be there!!!!
choctawmel is offline   Reply With Quote
Old 03-11-2018, 06:57 PM   #1038
1995 36' Classic 36
Ludington , Michigan
Classic Motor home get together
Originally Posted by Grosspoluter View Post
Oops meant 5 hour
I saw they have cabins!
Worked some on the 345 today
I値l probably make plans or reservations this coming week
I just don稚 want to reserve a camp-sight only to cancel-out (ok chicken out)
I知 sure we値l have space. I do have a lot of space here on the farm along with a pretty complete shop for rescue work. Ludington is about 50 miles south of Mesic on the route north.
Kota is offline   Reply With Quote
Old 03-11-2018, 07:08 PM   #1039
1995 36' Classic 36
Ann had both knees done last year about 3 months apart. Know what you are going through. I used to build and rebuild airplanes. After a bunch of taxi testing there comes a time when you just have pucker tight, push the power up, and pull back on that stick.
Old 03-12-2018, 07:10 AM   #1040
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
Mel,
I am very excited to see your work and maybe have our own Cummins / Allison showcase. I was able to snatch a few hours yesterday, put the hub and axle Back together and got Sylvia back on the road, she still purrs like a kitten.
I cant wait to meet you.
Curt
SpiceStream is offline   Reply With Quote
Old 03-12-2018, 07:14 AM   #1041
I really really really REALLY want to go to this. BUT I知 just not comfortable with a 500 mile one-way trip in my airstream the way it is now. I致e said before my comfort zone is about 100 150 miles away from where I live in Chicago but I知 thinking maybe me or my wife and I might take a trip out there and our car to visit you guys
I would love to meet all of you
Really would like to see your rigs, pick your brains, get the insight, ideas, and opinions of other like minded people
CLKIESER if your going, I壇 still be willing to 田hase you up there
Grosspoluter,
We will be buzzing right through Chicago if you want to caravan, let me know.
Curt
Old 03-12-2018, 02:27 PM   #1042
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
What is your biggest concern right now in driving the rig up to MI? Just curious.
I was the same way when I first got my 310TD.
If we were headed straight up to the get together from Champaign I would have suggested that we meet up near Chicago and caravan the rest of the way. But we are going to meander a bit and probably make a stop or two on the way up.
Mike
mayco is offline   Reply With Quote
Old 03-13-2018, 06:51 AM   #1043
Mike
We would love to hook up with both of you and make a true spectacle of it.
Mike,
Do you know if you have any pictures of your rear shocks?
I did not look too close to see if I have any of the mounting apparatus, but I could always fabricate that.
I was under Sylvia over the weekend, and I have none.
Thanks again,
Curt
Old 03-13-2018, 07:30 AM   #1044
Grosspoluter's Avatar
Franklin Park , Illinois
Ok so my biggest concern...
2 years ago on a Wisconsin trip my 345 threw a belt and overheated and since then oil pressure isn稚 what it used to be (but still with in the 10psi per 1000rpm range) the tow bill was $1500, I was pretty much broke for the rest of the year
Never quite figured out why the belt failed, it was a new belt (I知 afraid maybe my belts / Pulleys are not perfectly lined up)
Concern 2: my tag axel wheels have a negative camber to them, it used to be WAY worse, about a 4ー negative camber and the top of the tire used to rub the frame rail I have since worked on them and got it down to a 1ー negative camber tires no longer rub and I feel I can still make it better if I work on it in the next few weeks
IF I were still interested in caravaning up there when are you guys going to be coming through Chicagoland?
Grosspoluter is offline   Reply With Quote
Old 03-13-2018, 09:55 AM   #1045
mayco's Avatar
We aren't real sure what our schedule or route is going to be going up. But I think we are going to make 2-3 stops along the way just messing around. Check out some new parks probably in Wisconsin.
Hey Curt, do you have any recommendations on state parks up your way?
Old 03-13-2018, 11:46 AM   #1046
1995 36' Classic 36
Don稚 know the price but there is a car ferry from Manitowoc to Ludington.
http://www.ssbadger.com/
Old 03-13-2018, 12:59 PM   #1047
Yeah, I知 not sure what the prices are but I actually looked into that
because the ferry docks at Ludington And Ludington is only about 50 miles from the campground
I believe it was six dollars a foot for RVs and they had some kind of special for passengers I think it was 110 for round-trip
Old 03-13-2018, 01:05 PM   #1048
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
That was a problem I had when I bought the 370LE, when they replaced the engine in Florida, they put the brackets that hold the air pumps and alternator on reversed ......explains why I blew an alternator belt off every 200 miles on the way back home when I bought it ! The negative camber issue is most likely due to a tow job where the front end was lifted higher than it should have been forcing to much weight in the tag axle...,,easy to remedy by a frame shop. Regards,Bob
bobmiller1 is offline   Reply With Quote
Old 03-13-2018, 07:44 PM   #1049
Churubusco , Indiana
We are interested in bringing the 310 up to this! Can't make the whole thing, but we should be able to drive up Friday afternoon, we're only a couple hours away. Would love to see some more rigs!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 03-14-2018, 03:36 AM   #1050
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
More like 75 miles.
The boat from Muskegon MI to Milwaukee is 2 hours faster.
LakeExpress.
Dingo Girl is offline   Reply With Quote
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
Texas vintage get together Pahaska The Rally Zone 33 11-21-2005 04:23 PM
Get together this weekend Tin Hut Forum Rallies & Meet Ups 0 08-16-2004 06:51 PM
Florida New Years non-rally get together thenewkid64 The Rally Zone 20 12-30-2003 10:47 PM
colorado fall get together paul k Our Community 1 09-01-2002 06:51 PM
