Old 02-28-2007, 05:37 PM   #1
zamboni's Avatar
Classic MOHO Replacement Battery recommendations
Our RV batteries need replacement (not the chassis/engine starting battery). We have two located in the outside compartment just under the driver's seat. The two that I am replacing are group 78 automotive wet cell maintenance free batteries w/750 cca.
I would love to convert to deep cycle, AGM or Gel design for durability but due to the small tight space of their compartment and the original side post configuration, I'm not sure that this is an option. I've read some threads related to trailer battery replacements.
Anyone have any advise?
zamboni is offline   Reply With Quote
Old 02-28-2007, 05:39 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
See if you can get group 34 batteries in AGM or gel. 34 is the same height as the 78.
Old 03-01-2007, 04:37 PM   #3
zamboni, we just stopped at Wally world and bought the largest deep cycle batteries with the highest cca they had. The battery compartment on our 310 is rather large and there was room to spare.
I do like the size of the battery compartment on these motorhomes
Old 03-01-2007, 06:28 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
How Big.......
....................is your battery compartment? If you have the room, consider a pair (or even 4 for that matter) of 6 volt golf cart batteries. They are the best for deep draw-down situations like those found in house battery usage. Check out the dimensions at Lifeline Marine Batteries - AGM Marine Battery to see how many will fit your battery compartment.
Most major MOHO manufacturers now use the 6 volt golf cart style in their coaches. BTW, I managed to squeeze 2 of these AGM golf cart batteries into the box of my 19CCD. Far superior to the group 24 Interstates that it came with!!
Old 03-02-2007, 06:27 PM   #5
zamboni's Avatar
Our battery box opens to the outside like a glove box just under the driver's window. The battery cables come up from below in the center of the box with one battery on each side. The door opening is only about 8"H X 23"W. The group 78 batteries are 7.25"H X 10"W each, plus the 1" for the cables between each battery, gives me about .5" play on each side of the battery.
Did I mention I have GM side posts?
Old 03-02-2007, 06:28 PM   #6
zamboni's Avatar
I suppose I could rewire and relocate the "house" batteries to one of the basement storage compartments and the engine battery to the battery glove box.
Old 10-09-2007, 07:07 AM   #7
Zamboni- did you find a solution to your battery problem? I have the same with my 79 MH. Have not found a deep cycle that will fit in the box ( same as yours). Any help is appeciated. Thanks joe
joewinfield is offline   Reply With Quote
Old 10-10-2007, 11:07 AM   #8
Chuckles's Avatar
Iwerne Minster , Dorset. UK
By making up a bracket to take the starter battery underneath just behind the drivers seat I was able to squeeze in 4 off
6V 125 amp/hr deep cycle batteries.
Sorry the picture is not very large but it gives an idea
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 10-10-2007, 11:30 AM   #9
RIstream'n's Avatar
2008 27' Safari FB SE
Cumberland , RI
I've had Lifeline batteries in two motorhomes and I highly recommend them
RIstream'n is offline   Reply With Quote
Old 10-11-2007, 03:44 PM   #10
Thanks for the input. Lifelines seem great but a little over my budget. The problem is with the height. The battery box in my 79 is a little over 8 inches so the battery post (if one) must be shorter then 8 inches. joe
Old 10-30-2007, 06:28 PM   #11
2005 19' International CCD
San Diego , California
Lew,
I need to replace the factory batteries in my '05 19ft CCD and would like to use the same set up as you. Was it difficult to get the batteries to fit, did you need to modify the battery box and what is the part number for these batteries?
Miles
mkirby007 is offline   Reply With Quote
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Questions about new 2002 Classic Kistler 2001 - 2005 Classic 6 10-31-2002 10:19 PM
Battery condition chart FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-31-2002 05:44 PM
