05-05-2010, 06:52 PM
1984 31' Airstream310
Dunsmuir
Classic MH deadbolt woes
The other day I went to lock the deadbolt on our 84 310 MH. Inserted the key and turned ... and turned and turned. The deadbolt can still be operated from inside but cannot be locked or unlocked via the key. The key spins with very little resistance.
Any knowledge about what's needed to repair this?
How about taking it apart?
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion - The Dalai Lama
1984 310 Limited Motorhome
Courtesy Parking (W/S/E/Wi-Fi) on I-5 in Northern California, 70 miles from Oregon border
05-05-2010, 07:35 PM
Ajo
Is it the lower one? The upper would be a bearcat to fix, I've been told,if you could even get parts. The lower one is just as much a hassle, though I found a locksmith that dealt with RVs and had a old outside lockset in his stash that got me locked again.
05-05-2010, 08:41 PM
Dunsmuir
My rig doesn't have the lower one. Alas its the top deadbolt which is electrically operated from the dash. On mine, everything on the inside (manual and electric) work fine. But when the key is inserted on the outside it just spins.
05-05-2010, 09:01 PM
1989 34.5' Airstream 345
Cleveland
Pull the inside door panels off & look. You might just get lucky & find the rod that connects the cylinder to the lockset has fallen off.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
05-05-2010, 09:14 PM
Dunsmuir
Ricky
The lock in question is mounted in the wall, not the door. The wall panel extends behind the refer and pantry. Wouldn't be fun to pull it all out.
05-05-2010, 09:29 PM
Cleveland
The lock handle on the wall in my MH is only secured with 2 screws. It will then slide off a square pin. This pin connects to the cylinder. Use caution sliding it off as it will still have 2 electrical wires on the backside. You can look into the wall better & gain access for repairs by removing the step cutoff switch near the lock handle. You pop the switch out of the bezel with a butter knife at the top & bottom. Use caution as the wires leading to the switch may touch the inner aluminum panel & spark. Done it a couple of times already.
Ricky
05-05-2010, 10:33 PM
Dunsmuir
Ricky
Sounds different from my rig. I'll try to post some pictures tomorrow.
05-06-2010, 06:50 AM
Silverton
Ours sounds like yours...we lock the door lock, but the deadbolt 'hangs' from the outside...I can lock it from the outside, but have to use so much torque that I'm afraid the key will snap off. The inside is easier to handle, and is held in place by two rivets. Looking forward to the pics...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
05-06-2010, 04:26 PM
Dunsmuir
OK, here are some pictures, first the lock cylinder in the handle:
Next a view of the bolt in the jam:
And the inside:
05-06-2010, 05:20 PM
Ajo
What a difference a year makes, hard to believe AS would do that. Our upper lock, which only works from the inside, also, is a "Schlage", I see no markings on your lock,so, no clue. Like I said, you may be able to find some RV locksmith that can replace the tumblers, though my guy said the whole inside housing had to come out. Might as well tighten the door latch and 'loctite' them in at the same time. I do not envy the process.
05-06-2010, 05:46 PM
Cleveland
Here's what my 1989 has. Photo 1 shows switch & lock handle. Photo 2 shows removal of switch for better viewing behind panel. Photo 3 shows square lock shaft. I didn't bother to cut the hole in the tin big, so you should get a better view. Hope this is of some help.
Ricky
05-07-2010, 09:31 AM
Dunsmuir
Well I don't have any switches in that wall but I guess I'll remove the lock handle and see if the shaft can be moved.
05-07-2010, 10:38 AM
Cleveland
A last resort might be to drive to a locksmith. They can pull the cylinder from the outside to get a better look. Please follow up with the results of your repair for all to learn.
Ricky
05-08-2010, 05:28 AM
Richmond
, Kentucky
Guy, our 1984 310 is identical to your arrangement. Unfortunately ours works even less than yours does. The lock doesn't work from the outside and from the dash you can hear the motor try to operate but it seems to bind. We can use the lever from the inside by the door to lock the deadbolt but that's the only way we can get it to work.
If you can figure out how to get into it without tearing out the fridge wall I'd like to hear about it.
This deadbolt has been on my "hit" list for quite some time but I just haven't been able to get to it.
Definitely keep us posted.
Good luck!
1975 24' Argosy Motor Home
05-08-2010, 08:06 AM
2000 31' Land Yacht
Central
Checking mine found PO changed amount of deadbolt slide by cutting or filing smaller.
I would guess an alignment problem caused original malfunction.
Doesn't sound like the original posting as his key spins which would mean the connection to the deadbolt has failed. Household locks use either a bolt or clip to hold in place. If it is a bolt it should be an easy fix after the hard part of getting to it.
05-08-2010, 03:00 PM
Dunsmuir
Good luck!
I think the following manual section is referring to the handle with the deadbolt. Sorry about the size, I didn't see how I could reduce it:
Thanks, BTW, for providing the pdf of the manual. You'll notice that no mention of the deadbolt is here but I think this has got to be the handle with the lock in it. I will keep you posted.
I won't get to this for a few weeks since the MH is 200 miles away and I have to finish painting a house and doing home repairs before we can return to the MH.
05-10-2010, 01:43 PM
Richmond
, Kentucky
Guy,
I did see that reference in the manual back when I was trying to figure out what to do about the dead bolt. What I was concerned with at that time and still am is it still doesn't provide access to the lock motor unless that is done from the outside. I've been leary of drilling the two holes and taking the deadbolt off only to have the motor fall down inside the wall .
Needless to say I'm very interested in whatever you find out about these dead bolts and their motors!
PS, you're welcome on the pdf!
05-10-2010, 02:06 PM
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands
, Nevada
I had this happen to me in Death Valley - lucliky we left one window open a little. A screen is easier to replace than a window, if you know what I mean.
Anyway, I replaced the deadbolt tumbler and shaft with a brand new one and it works like a champ now. You don't need a locksmithh if you can get the same lock - I forget the brand deadbolt it is at the moment.
Take a look at Overlander '77 | Replace Deadbolt | Replace Deadbolt
05-21-2010, 07:29 PM
Foothill Ranch
Interesting thread...
My 345 has damage and a patch right behind the door... Now I know what happened... whatever it hit tore off the outside handle.
I have two locks on the main handle so It seem secure, but I would like to make it good..
Anyone found a suitable replacement for the handle and lock?
05-23-2010, 11:26 AM
Foothill Ranch
Can someone post a good pic of the outside handle/lock so I can go hunting for a replacement?
On mine, the outside Handle is missing, and the inner thing... what is that and what does it do... Mine is hanging off... and only one wire that goes to the little tube that is spring clipped into the back of it. Is it a mercury switch? How should it work?
I have a rocker switch on the dash... That should throw the deadbolt?
