Old 05-05-2010, 07:52 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Classic MH deadbolt woes
The other day I went to lock the deadbolt on our 84 310 MH. Inserted the key and turned ... and turned and turned. The deadbolt can still be operated from inside but cannot be locked or unlocked via the key. The key spins with very little resistance.
Any knowledge about what's needed to repair this?
How about taking it apart?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-05-2010, 08:35 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Is it the lower one? The upper would be a bearcat to fix, I've been told,if you could even get parts. The lower one is just as much a hassle, though I found a locksmith that dealt with RVs and had a old outside lockset in his stash that got me locked again.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-05-2010, 09:41 PM   #3
guy99's Avatar
Images: 16
My rig doesn't have the lower one. Alas its the top deadbolt which is electrically operated from the dash. On mine, everything on the inside (manual and electric) work fine. But when the key is inserted on the outside it just spins.
Old 05-05-2010, 10:01 PM   #4
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Pull the inside door panels off & look. You might just get lucky & find the rod that connects the cylinder to the lockset has fallen off.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 05-05-2010, 10:14 PM   #5
guy99's Avatar
Images: 16
Ricky
The lock in question is mounted in the wall, not the door. The wall panel extends behind the refer and pantry. Wouldn't be fun to pull it all out.
Old 05-05-2010, 10:29 PM   #6
3 Dog Nite's Avatar
The lock handle on the wall in my MH is only secured with 2 screws. It will then slide off a square pin. This pin connects to the cylinder. Use caution sliding it off as it will still have 2 electrical wires on the backside. You can look into the wall better & gain access for repairs by removing the step cutoff switch near the lock handle. You pop the switch out of the bezel with a butter knife at the top & bottom. Use caution as the wires leading to the switch may touch the inner aluminum panel & spark. Done it a couple of times already.
Ricky
Old 05-05-2010, 11:33 PM   #7
guy99's Avatar
Images: 16
Ricky
Sounds different from my rig. I'll try to post some pictures tomorrow.
Old 05-06-2010, 07:50 AM   #8
Silverton , Colorado
Ours sounds like yours...we lock the door lock, but the deadbolt 'hangs' from the outside...I can lock it from the outside, but have to use so much torque that I'm afraid the key will snap off. The inside is easier to handle, and is held in place by two rivets. Looking forward to the pics...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 05-06-2010, 05:26 PM   #9
guy99's Avatar
Images: 16
OK, here are some pictures, first the lock cylinder in the handle:
Name:	P5060011 (Small).JPG
Next a view of the bolt in the jam:
Name:	P5060012 (Small).JPG
And the inside:
Name:	P5060013 (Small).JPG
Old 05-06-2010, 06:20 PM   #10
Mike Leary's Avatar
Images: 11
What a difference a year makes, hard to believe AS would do that. Our upper lock, which only works from the inside, also, is a "Schlage", I see no markings on your lock,so, no clue. Like I said, you may be able to find some RV locksmith that can replace the tumblers, though my guy said the whole inside housing had to come out. Might as well tighten the door latch and 'loctite' them in at the same time. I do not envy the process.
ID:	101933   Click image for larger version
Old 05-06-2010, 06:46 PM   #11
3 Dog Nite's Avatar
Here's what my 1989 has. Photo 1 shows switch & lock handle. Photo 2 shows removal of switch for better viewing behind panel. Photo 3 shows square lock shaft. I didn't bother to cut the hole in the tin big, so you should get a better view. Hope this is of some help.
Ricky
ID:	101935   Click image for larger version
Old 05-07-2010, 10:31 AM   #12
guy99's Avatar
Images: 16
Well I don't have any switches in that wall but I guess I'll remove the lock handle and see if the shaft can be moved.
Old 05-07-2010, 11:38 AM   #13
3 Dog Nite's Avatar
A last resort might be to drive to a locksmith. They can pull the cylinder from the outside to get a better look. Please follow up with the results of your repair for all to learn.
Ricky
Old 05-08-2010, 06:28 AM   #14
Guy, our 1984 310 is identical to your arrangement. Unfortunately ours works even less than yours does. The lock doesn't work from the outside and from the dash you can hear the motor try to operate but it seems to bind. We can use the lever from the inside by the door to lock the deadbolt but that's the only way we can get it to work.
If you can figure out how to get into it without tearing out the fridge wall I'd like to hear about it.
This deadbolt has been on my "hit" list for quite some time but I just haven't been able to get to it.
Definitely keep us posted.
Good luck!
Deadbolt Installation??? 05ModPod Doors & Locks 43 06-10-2010 06:57 PM
A deadbolt that couldn't wait! blaisew Doors & Locks 2 08-06-2007 12:53 PM
'85 345 deadbolt woes pbnjsellers Doors & Locks 2 06-15-2005 03:18 PM
Deadbolt...... aviontt Doors & Locks 1 11-24-2003 09:46 PM
Deadbolt Gunnyusmc Doors & Locks 2 09-12-2003 07:02 AM
