Old 05-08-2010, 08:06 AM   #15
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by bkahler View Post
Guy, our 1984 310 is identical to your arrangement. Unfortunately ours works even less than yours does. The lock doesn't work from the outside and from the dash you can hear the motor try to operate but it seems to bind. We can use the lever from the inside by the door to lock the deadbolt but that's the only way we can get it to work.
This deadbolt has been on my "hit" list for quite some time but I just haven't been able to get to it.
Checking mine found PO changed amount of deadbolt slide by cutting or filing smaller.
I would guess an alignment problem caused original malfunction.
Doesn't sound like the original posting as his key spins which would mean the connection to the deadbolt has failed. Household locks use either a bolt or clip to hold in place. If it is a bolt it should be an easy fix after the hard part of getting to it.
Old 05-08-2010, 03:00 PM   #16
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
If you can figure out how to get into it without tearing out the fridge wall I'd like to hear about it.
Definitely keep us posted.
Good luck!
I think the following manual section is referring to the handle with the deadbolt. Sorry about the size, I didn't see how I could reduce it:
Name:   Service Manual Page B 14.bmp
Thanks, BTW, for providing the pdf of the manual. You'll notice that no mention of the deadbolt is here but I think this has got to be the handle with the lock in it. I will keep you posted.
I won't get to this for a few weeks since the MH is 200 miles away and I have to finish painting a house and doing home repairs before we can return to the MH.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-10-2010, 01:43 PM   #17
Guy,
I did see that reference in the manual back when I was trying to figure out what to do about the dead bolt. What I was concerned with at that time and still am is it still doesn't provide access to the lock motor unless that is done from the outside. I've been leary of drilling the two holes and taking the deadbolt off only to have the motor fall down inside the wall .
Needless to say I'm very interested in whatever you find out about these dead bolts and their motors!
PS, you're welcome on the pdf!
Old 05-10-2010, 02:06 PM   #18
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I had this happen to me in Death Valley - lucliky we left one window open a little. A screen is easier to replace than a window, if you know what I mean.
Anyway, I replaced the deadbolt tumbler and shaft with a brand new one and it works like a champ now. You don't need a locksmithh if you can get the same lock - I forget the brand deadbolt it is at the moment.
Take a look at Overlander '77 | Replace Deadbolt | Replace Deadbolt
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 05-21-2010, 07:29 PM   #19
Interesting thread...
My 345 has damage and a patch right behind the door... Now I know what happened... whatever it hit tore off the outside handle.
I have two locks on the main handle so It seem secure, but I would like to make it good..
Anyone found a suitable replacement for the handle and lock?
Old 05-23-2010, 11:26 AM   #20
Can someone post a good pic of the outside handle/lock so I can go hunting for a replacement?
On mine, the outside Handle is missing, and the inner thing... what is that and what does it do... Mine is hanging off... and only one wire that goes to the little tube that is spring clipped into the back of it. Is it a mercury switch? How should it work?
I have a rocker switch on the dash... That should throw the deadbolt?
Old 05-23-2010, 04:18 PM   #21
345bill's Avatar
Las Vegas , Nevada
Here's a couple pic's of what's on my 1990 345.
Yes, the rocker sw on the dash does lock / unlock the deadbolt.
Name:	345 entry door locks.jpg
345bill is offline   Reply With Quote
Old 05-23-2010, 08:11 PM   #22
Thanks Bill!
I need to find something that will work to replace mine...
Old 09-29-2010, 08:21 PM   #23
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
I'm having problems getting my lock to function with the switch on the dash... does this mean that I have A- an issue with the lock B- a door alignment issue C- issues with drivetrain balancing?
GREENovaters is offline   Reply With Quote
Deadbolt Installation??? GT1963 Doors & Locks 43 06-10-2010 05:57 PM
A deadbolt that couldn't wait! blaisew Doors & Locks 2 08-06-2007 11:53 AM
'85 345 deadbolt woes pbnjsellers Doors & Locks 2 06-15-2005 02:18 PM
Deadbolt...... aviontt Doors & Locks 1 11-24-2003 08:46 PM
Deadbolt Gunnyusmc Doors & Locks 2 09-12-2003 06:02 AM
