Old 01-30-2016, 06:51 AM   #57
Gunter, have you checked the voltage on both circuits of the generator since you polished the armature?
bkahler is online now   Reply With Quote
Old 01-30-2016, 08:07 AM   #58
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Yes I have and it is the same on both circuits. I took voltage readings at both transfer relays to make sure.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 01-30-2016, 12:29 PM   #59
I'm assuming you still have your original regulator installed and are waiting for the new one to arrive.
The voltages you're reporting right now are really close to what I was experiencing with my Kohler generator before replacing the voltage regulator. I'm betting once you install the new voltage regulator the generator will produce the correct voltage on both legs like it's supposed to.
Old 02-04-2016, 02:09 PM   #60
Gunter
gunner's Avatar
Greenville , Ohio
Installed another Voltage Regulator today, the results are:
No Load Volts 122.3
1500 Watt Load Volts 116.8
3000 Watt Load Volts 113.3
I believe it is fixed unless someone has voltage readings that are higher under load.
Gunter
Old 02-04-2016, 06:17 PM   #61
No Load Volts 122.3
Gunter, those numbers are probably about as good as you're going to get. Obviously the regulator made a difference so I'd say you're good to go.
Edit: If you have a Kill-A-Watt you could check the frequency and that would tell you if the voltage is low because of engine RPM or if the regulator is just letting it drop slightly below 120vac.
Old 02-05-2016, 06:00 AM   #62
Gunter
gunner's Avatar
Greenville , Ohio
I do have a Kill-A-Watt, that is what I used to set my RPM to achieve 60HZ. Here are the results of the HZ at various loads:
No Load Volts 122.3 60.8 HZ
1500 Watt Load Volts 116.8 60.1HZ
3000 Watt Load Volts 113.3 59.1 HZ
Gunter
Old 02-05-2016, 02:27 PM   #63
Gunter, are you loading just one leg of the generator or both legs?
Unless you've been running your rear air conditioner during this testing then you've likely only been checking one leg. What I would suggest as a test is to run the generator, turn on the rear air so the condenser kicks in and then load the other leg with 1500 watts and then 3000 watts and then take readings.
This will tell you how well the generator handles a full load. You might also take a voltage reading of the leg running the rear air conditioner to see if it's any different than the other leg under load.
On the 310 the 2nd leg of the generator only runs the rear air. I'm assuming the 345 is the same but it might be that on the 345 the air conditioner on the 2nd generator leg might be the front AC unit. So be aware of that possible difference in my description above.
Old 02-05-2016, 02:46 PM   #64
Gunter
gunner's Avatar
Greenville , Ohio
I am only testing the one leg under load. Being in Ohio and being winter using the rear air conditioner is not feasible, condenser will not kick in. I did change the rear air conditioner to run either from the transfer switch or a separate electrical cord using 20 amp male and female connectors (hope it makes sense). I can plug into the female connector from the transfer switch that would normally power the rear air and apply a load on that leg of the generator to accomplish what you are suggesting.
Gunter
Old 02-05-2016, 04:21 PM   #65
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Yes, it makes sense. I call it the poor mans 50 amp service
Just have to make sure that rear AC is completely disconnected from the RV service to run it on the external 20 amp plug.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 02-06-2016, 05:41 AM   #66
Yep it makes sense. I did something similar to the 310 only I used a DPDT 250vac rated switch so all you have to do is flip the switch to select the 2nd shore power line or select the generator as the feed for the rear air.
Old 02-06-2016, 08:07 AM   #67
Gunter
gunner's Avatar
Greenville , Ohio
Did the test as you suggested; it appears my voltage is increasing from the last test.
Measurements taken at both the Main line and Rear Air conditioner line simultaneous.
Main Line No load 125.7 volts 60.5 Hz.
2846 watt load 114.3 volts 57.9 Hz
Rear Air line No load 123.1 volts 60 Hz
1546 watt load 122.0 volts 58.1 Hz
I may want to increase engine speed slightly to increase Hz under load.
I also like your idea of adding the DPDT switch to eliminate having to change the male and female plugs. What switch did you use a simple panel switch or something more heavy duty like a wall switch?
Gunter
Old 02-06-2016, 08:45 AM   #68
Gunter
gunner's Avatar
Greenville , Ohio
There is a benefit of having a female receptacle from the generator and a separate female receptacle from the separate 20 amp cord that power the rear air conditioner; it allows me to plug in a heater for the cool fall nights and have another heater that runs from the main 30 amp line. Since I have upgraded my air conditioners I no longer have the heat strips that were part of the Coleman air conditioners.
Gunter
Old 02-06-2016, 04:46 PM   #69
Gunter,
I used this Leviton 1286 20-Amp 120-Volt Toggle Double-Pole switch to swap between the generator (or main shore power) powering the rear air conditioner and the separate 20 amp power cord that is plugged in via the generator compartment.
This following pdf file contains all of the 120VAC wiring diagrams that I generated for my old 84 310 including all of the modifications I made to the 120VAC system. Page 4 is where I show the switch mentioned above.
310-ac-wiring-diagrams.PDF
Old 07-28-2016, 02:27 PM   #70
Gunter
gunner's Avatar
Greenville , Ohio
After using my Generator with the new Voltage Regulator for approximately 7 hours running my front Air Conditioner, while traveling, the Voltage Regulator failed. I reinstalled my original Voltage Regulator, the no load voltage is 115 and with the Air Conditioner Compressor on voltage dropped to 111 volts. I purchased a complete same Model Generator a couple days ago out of Michigan. I will use this for parts only since it is not in the best of shape (carburetor etc. needs rebuilt). I took the Voltage Regulator from that unit and installed it into the Generator in my Motorhome. The Voltage Regulator is the original style, the resulting voltages where 118.4 no load and 116.3 with Air Conditioner Compressor load. I hope this one will be the last one I need to purchase since they are no longer available. I did contact the company bkahler recommended for possibly repairing my Voltage Regulators, they asked for additional information which I provided but I haven't received a reply since they were shut down last week.
Gunter
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 03:38 PM
honda generator replacement in 345 str8strm General Motorhome Topics 6 11-03-2005 01:27 PM
generator in 1989 345? Curtis-79MH Mechanics Corner - Engines, Transmission & More... 12 05-26-2005 11:03 PM
Generator replacement in 345 Curtis-79MH Mechanics Corner - Engines, Transmission & More... 3 05-06-2005 10:02 AM
1986 AS 345 MH Onan generator Jim Tyrney Airstream Motorhome Forums 0 06-18-2004 10:58 PM
