Old 06-20-2009, 02:02 PM   #15
1989 34.5' Airstream 345
Silverton , Colorado
Airbags...?
Originally Posted by crashxx View Post
Yea I saw those, or whats left of them.
I can send you mine...How many pieces would you like?
You will regret buying your rig many times, but not as many as you will swell with pride of ownership
mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 06-20-2009, 10:54 PM   #16
crashxx's Avatar
1983 30' Airstream 300
Weatherford , Oklahoma
I need to get some gas detectors installed while everything is out. Any suggestions on which ones to get?
crashxx is offline   Reply With Quote
Old 06-21-2009, 09:44 AM   #17
these seem to work pretty good and do not need batteries.
Honkity Hank is offline   Reply With Quote
Old 06-21-2009, 11:01 AM   #18
crashxx's Avatar
Ha!
Old 06-22-2009, 12:32 PM   #19
Our original gas detector, located just inside the door to the left, is a "NewTec"...don't know if they're still in business, but it still works. At home, we use a Nighthawk(made by KIDDE Safety), which is a dual CO/Explosive gas detector...it has a 9V DC battery back-up, but plugs into a 120 AC.
Michael & Tracy
1989 345 Motorhome
Old 06-22-2009, 02:55 PM   #20
crashxx's Avatar
Is there a switch or something to run on the coach batteries? When I plug in to the wall, everything works. When I unplug, it doesn't . Not sure how to go to the batteries.
Old 06-22-2009, 10:26 PM   #21
swanky's Avatar
Grosse Pointe Park , Michigan
Overhead wood storage
The headliner is bad. I think I'll try heating it up and pushing it back. Its trash now so maybe I'll get lucky. I've seen some wood overhead bins in newer models, thought I'd explore having some built.
My PO put these cabinets in, I believe, and they are quite handy and blend well. It is possible they are original to the coach, but I don't think so as they are different from the rear. Anyone know if these could have come with the motorhome in 1982? The bedroom storage has the standard tambour type. The area over the cockpit really is nice, it makes use of otherwise wasted space and could solve your headliner issue at least in part. It also hides a lot of extra wiring for speakers and such. The PO also made the dashboard to match the wood cabinets. Sorry the pictures are not ideal, but if you are looking for ideas and want better pictures, just let me know.
ID:	82775   Click image for larger version
ID:	82780   Click image for larger version
ID:	82782   Click image for larger version
swanky is offline   Reply With Quote
Old 06-23-2009, 09:21 AM   #22
crashxx's Avatar
Could you send me pictrues of how these are attached to the wall from the inside? Thanks.
Old 06-23-2009, 08:42 PM   #23
The oak overhead cabinets were an option...we have them in ours...the closets, bathroom, and over-the-fridge are also oak.
mike
Michael & Tracy
1989 345 Motorhome
Old 06-24-2009, 09:19 PM   #24
swanky's Avatar
I will get some inside shots for you asap
I should be able to get some pictures tomorrow for you.
Old 06-24-2009, 10:18 PM   #25
Running 120 V AC requires a landline or an inverter...you would need extra coach batteries to make this viable...solar panels are a BIG plus, and can recharge your batteries during the day.
mike
Michael & Tracy
1989 345 Motorhome
Old 06-25-2009, 08:12 AM   #26
crashxx's Avatar
Yea, I know for the 120v I've got to have the onan running or be plugged in. How do I get the 12v lights & such to work off the two 6v batts wired in series located in the same compartment as the engine batt?
Old 06-25-2009, 09:45 AM   #27
power to the peephole...?
They should work...the drawback to 6V batteries, is if one fails(or is failing), the system goes down...you might consider 12V AGMs...?
Michael & Tracy
1989 345 Motorhome
Old 06-25-2009, 09:47 AM   #28
crashxx's Avatar
So they should be "on" all the time?
300 classic update. crashxx Classic Motorhomes 3 06-09-2009 09:13 PM
300 classic, How to tie down on a trailer advice. crashxx Classic Motorhomes 6 06-01-2009 08:49 PM
Dent removal on 300 classic. crashxx Classic Motorhomes 2 05-31-2009 02:07 PM
'79 classic MH needing water pump... DIY project??? djurgensen Mechanics Corner - Engines, Transmission & More... 55 01-30-2009 10:04 AM
1992 300 Classic spotted for sale davidz71 General Motorhome Topics 3 10-08-2007 08:11 PM
