Old 05-15-2010, 07:25 AM   #1
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
City Water Inlet Replacement
So for some time my city water inlet has been inop due to exterior disintegration. This past week I happened to be in Myrtle Beach and stopped in at CW and picked up what looks like a replacement.
At issue is the attachment seems to be a lock nut/jam nut on the existing setup and a threaded attachment point on the new unit that seems to be father back.
Has anyone done this who has memory of the job.
I note the pipe from the pressure regulator is the old gray abs and could be replaced with pex I think if I need to do a workaround.
Thoughts on this would be appreciated.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 05-16-2010, 06:44 PM   #2
Glen,
I replaced ours several years ago with something I got from the local RV place. If I remember right it was a direct replacement. I'll try and remember to look at ours tomorrow after work and see if its similar to what you described.
Old 05-16-2010, 07:45 PM   #3
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Thanks Brad, I've got very limited access unless I start removing the drive axle splash guards or the exhaust pipes.
I may just redo from the pressure regulator out but hope someone else may have done this and can shed some light on the job.
Old 05-18-2010, 08:19 PM   #4
Glen,
It just dawned on me that yours is a funeral coach which from your description of your water hookup is different than our 310.
Here are a couple of photos of our 310 city water hookup. Very accessable.
ID:	102864 Click image for larger version
Sorry I'm not much help with your problem.
Old 05-19-2010, 04:55 AM   #5
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Brad, it looks similar. The replacement I picked up has a threaded stock but the threaded area is not to the depth I would think matches what we have. I'll try to shoot a photo and post.
I'm jealous of the access you have as my tank is below one of my facing sofas and access is tight to say the least.
Old 05-24-2010, 08:16 PM   #6
If you're like me getting access to those tight places is getting harder and harder each year and I'm certainly not complaining about the great access we have on our 310 .
Old 05-25-2010, 10:39 AM   #7
1989 34.5' Airstream 345
Silverton , Colorado
Wait til you try to replace the toilet valve on ANY Airstream moho...we have a city water hookup above the fresh water tank...on the street side, and protected by a lock door...I would surmise that a hose-clamp connection would work, if access was feasible...???m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
city water inlet riverrose Fresh Water Systems 7 06-03-2009 11:13 AM
City water inlet Davis Fresh Water Systems 2 02-13-2008 07:41 PM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 03:25 PM
city water inlet urbanfood Fresh Water Systems 5 08-18-2007 08:56 PM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
