Old 11-19-2015, 02:24 PM   #1
kjcurtis's Avatar
1982 31' Airstream 310
Grants Pass , Oregon
Chassis VIN Location
Hi All,
***EDIT*** Cannot delete this question. Husband found the plate under a wiring harness above the right side of the radiator on a small plate. We are good to go.***
1982 310 Limited
I've been tearing my hair out once again...good thing it is winter hat season
I got good advice from a member on where to find the Chassis VIN and mistook the Airstream Serial Number for my VIN and freaked out that the Title I have and the VIN (AS Serial No.) don't match up.
I have scoured that front pillar to the left of the radiator for the Chassis VIN and cannot find it! Here in Oregon, someone from the DMV has to personally verify the VIN...I can't show them the number if I can't find it.
Would it, could it, be anywhere else?
Thank you!!
KJ
There is a method to my madness,
and a little madness in my method.
kjcurtis is offline   Reply With Quote
Old 11-19-2015, 02:34 PM   #2
mayco's Avatar
champaign , Illinois
I am so sorry. My bad on chassis vin location. Look above your radiator cap and slightly to the right as in picture
Name:	ImageUploadedByAirstream Forums1447968878.585511.jpg
mayco is offline   Reply With Quote
Old 11-19-2015, 02:37 PM   #3
mayco's Avatar
I should not trust my memory any more.
Old 11-19-2015, 03:04 PM   #4
1982 28' Airstream 280
Redwood City , California
Yup, just as Mike has pointed out, the VIN number is up on the upper firewall panel...
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 11-19-2015, 05:16 PM   #5
kjcurtis's Avatar
The plastic tub with blue liquid
Dadstoy,
Looking at your beautiful engine compartment, what is the white tub in the middle on the left with the blue liquid? We don't have one of those.
Thanks!
KJ
Old 11-19-2015, 05:27 PM   #6
That's the windshield washer fluid. Its aftermarket. Stock is located on drivers side of firewall next to the battery isolater. The stock on was cracked and I installed the new one on the other side because I installed a new 300 AMP isolator and it is longer then the stock isolator.
The white tank under the washer tank is the radiator overflow...also an aftermarket tank...no way in the world was I going to pay the price for the "Airstream" replacement!
Decipher your VIN - charts for VIN and Weights GreatPumpkin Title, VIN & Registration 4 05-27-2015 03:33 AM
Location of Horn Relay on 1985 P30 chassis Orland Dewey Electrical - Systems, Generators, Batteries & Solar 0 12-14-2011 07:09 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
1986 345LE Chassis VIN verification MarkByron Classic Motorhomes 5 05-31-2006 09:59 PM
