Old 10-20-2015, 09:48 AM   #43
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
- What did the Idealist say to the Pragmatist?
- Nothing. No point.
1989 345LE
Punch is offline   Reply With Quote
Old 09-04-2016, 06:31 PM   #44
1979 28' Airstream Excella 28
Albuquerque , New Mexico
there is a group of wires in thin plastic that run directly over the top of the Isuzu engine. Is there a modern product to wrap these in to protect from heat?
kyote is offline   Reply With Quote
Old 09-05-2016, 01:20 AM   #45
Santa Cruz , California
Images: 12
The top of the engine (valve cover) isn't really all that hot, and anything you use will come to the same temperature inside as out within a few minutes. I chose to replace some wires with Tefzel aircraft wire where they had rested on places that got too hot. Then, keep them in a loom that has some air space so they don't rest on the metal. There is something like what you mentioned, it's made of orange silicone rubber with a soft fiberglass lining and called firesleeve. You can get it at Parker hose shops or aircraft supply places. It is not cheap. The fiberglass lining provides some heat insulation because it makes an air space.
dljosephson is offline   Reply With Quote
P30 chassis electrical gaiaenviro Classic Motorhomes 1 05-10-2015 06:00 PM
Retractable electrical power cord replacement Excella CM Electrical - Systems, Generators, Batteries & Solar 4 07-19-2013 12:30 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 08:24 PM
Airstream Chassis Replacement Dismayed Repairing/Replacing Floor &/or Frame 23 08-13-2009 02:21 PM
Complete floor replacement and chassis refurm photos Jonz Repairing/Replacing Floor &/or Frame 0 09-16-2007 07:37 AM
