Old 10-17-2015, 11:53 AM   #15
1982 28' Airstream 280
Redwood City , California
Originally Posted by dljosephson View Post
Airstream seems to have done some odd things to the GM factory fuse block, some extra goop on the firewall side
I always wondered if that was "factory" or not...not going to wonder about that one anymore!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-17-2015, 11:55 AM   #16
Just teasing ya!
Originally Posted by mayco View Post
Hehehehe, all joy Dean!!! Just reference to the risk of fire under the hood. (Im still trying to find the plug wires on the Isuzu)
Old 10-17-2015, 05:42 PM   #17
Tony,
The MH wiring can seem to be daunting, but I don't find it that difficult...it's just time consuming to troubleshoot. I wouldn't replace the wiring, but instead would take the time to fix the issues you have.
A few yrs back when I had the entire dash out for painting and ductwork replacement, I was amazed at the spaghetti wiring behind the gauges, but I was also amazed how the wiring was in such good condition. A few issues that I saw and dealt with were connections on the gauges and switches.
I agree with many here that the biggest issue with the wiring is broken, loose or corroded grounds. That is what most of my gremlins have been.
Old 10-17-2015, 05:52 PM   #18
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Thanks all for the replies.
It just that every time somebody fixes an electrical system on my rig they seem to find power from somewhere or something else, add a fuse and string new wire to the system without power. At some point I think I'm going to have to pull everything, grab a new bigger fuse block and start pulling wire myself. It will probably drive me to drink or a close relationship with Xanax but not doing something is an failure waiting to happen.......again and again. This year I lost an electrical system every trip, if not two.
It all started with the burn't out fuse that sent power to the infamous yellow wire. What was Airstream thinking that a 18 gauge wire run 30+ feet would be able to supply enough power to run an air compressor, in heat and not blow?
If I did do this I would probably start replacing wire and rewiring systems BEFORE ripping out the old wiring. As each system works, go on to the next.
It's depressing looking under the dash and seeing fuses just hanging in space, no labels or explanation of what they control.
Frustrated! Heck I'm even thinking of taking an automotive electrical course this winter........
Hey! great idea.....Maybe I should approach an automotive school and ask them if they would consider the project as a lesson for students?......First question out of the kids mouth is going to be....Sir, where's your OBD connection for my code reader?
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 10-17-2015, 11:08 PM   #19
Santa Cruz , California
Images: 12
I'm not sure grounds are 95% of the problem. In my experience, bad grounds and bad crimped connections are about equal. Oh and those blue 3M (originally) snap connectors, please tell me those didn't come from the factory...
I have a hunch that re-doing the dash wiring and removing everything that's piggybacked into the GM vehicle junction block will solve most of the flakiness. Just looking at the dash wiring drawing on page G-15 of the manual is scary, but it's easy to fix given some patience. Might replace some gauges in the process. And then, when you replace all the clearance, running and turn lights with LEDs, get rid of all the flaky connectors. That's the plan, anyway...
A very important part of the process is to use real crimp connectors and crimper. You want the terminals that have two concentric metal barrels and translucent nylon sleeves. They are made to military specification and cost 40 cents to about $1.25. The right AMP or T&B crimper costs about $200 (the military version is about $600) but there are good ones for about $40. Once you have used these you may throw the rest of the terminals you have in the trash.
dljosephson is offline   Reply With Quote
Old 10-18-2015, 06:30 AM   #20
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
I must say that I think well-crimped connections are fine, given dry and salt free conditions. But once moisture, and especially salt-laden moisture, gets at crimped connectors it migrates between the strands and soon you have a white/green mess. Soldered connectors are better under these conditions, but still corrosion happens. And corrosion will always happen under grounds.
Under my dash, everything looks completely chaotic, but in good shape. I would have said the quality of materials was excellent, although some things look a bit slap-dash in installation. This vehicle was not assembled by robots. I don't see any 3M snap connectors on what looks like original wiring, but a couple of later add-ons do have them.
We must always remind ourselves that none of our vehicles, even going back to the earliest Argosies, were designed to last anywhere near this long. I am sure they built them for the second or maybe third owner, with 15 years in mind max. My chassis is 27 years old and my coachwork a few months younger. I am now finding the shortcuts and design faults that the guy who paid $150,000 was never aware of.
1989 345LE
Punch is offline   Reply With Quote
Old 10-18-2015, 06:49 AM   #21
Rivet Loser
Punch's Avatar
I did a double take on that picture, Dadstoy. Very funny. I presume this is some executive jet. Makes you never want to fly again. Actually I already never wanted to fly again.
I don't know whether I find the guy looking through the book scarier, or the two guys who aren't looking through books.
1989 345LE
Old 10-18-2015, 06:58 AM   #22
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Amazon.com: Blue Snap On Connector Crimp Wire Electrical Cable ...
www.amazon.com › Home Improvement › Electrical › Cord Management
Item 9 - 20 - Amazon.com: Blue Snap On Connector Crimp Wire Electrical Cable Connectors Quick Splice Lock Wire Terminals Pack Of 100Pcs: Home ...
I didnt think you could still buy those connectors but...........
On my 310 they didnt use many of these behind the dash, mostly under the chassis on the lighting circuits and such. What bothers me the most about them is I cant actually SEE the wire connection when making the joint.
I found these on Amazon and have been using them on the inside of the rig. Bought all three sizes and they seem pretty good. Havent used them under the chassis, cant use shrink tube with them.
http://www.amazon.com/Crimp-closed-C.../dp/B00CPNBW5M
mayco is offline   Reply With Quote
Old 10-18-2015, 07:08 AM   #23
Rivet Loser
Punch's Avatar
I have used those, or expensive ones that look the same. The only problem for us up here is that at a few degrees below zero (F) the plastic tends to shatter if impacted or stressed. Not good.
1989 345LE
Old 10-18-2015, 07:56 AM   #24
lewster's Avatar
Naples, FL , Hood River, OR
Just noticed this thread. You would do well using non-insulated bare metal (tinned copper) butt and by-pass connectors properly crimped and then sealed with glue-filled heat shrink. No room for error there.
And if replacing wire, use ONLY cable with an ABYC marine rating (tinned and stranded) as the combination of the above will virtually eliminate corrosion.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-18-2015, 08:40 AM   #25
Rivet Loser
Punch's Avatar
Lew Farber
541-490-6357
Very interesting Lew, especially the connector technique you describe.
I assume the ABYC is a marine cable. A primary concern up here is freezing, and very few plastics remain flexible under very cold (-20 to -50C, -4 to -60F) conditions, and shatter easily. This makes electric cable dangerous. A few years ago I bought a small shop heater from a big Canadian hardware chain. A shop heater heats your shop, I believe. I turned it on when my shop was at about -20C (so -4F, not even very cold), then moved the heater a foot or so and heard buzzing and crackling.... the electric cable plastic insulation had shattered! So my worry about a marine cable is that I don't see why it would have to resist very low temperatures, whereas automotive rated cable always seems to remain flexible, and therefore is safe, in any temperature I've seen here. Do you know the low temperature rating of the ABYC cable?
1989 345LE
Old 10-18-2015, 11:40 AM   #26
lewster's Avatar
Interesting point. I'll have to check the wire specs. They usually rate for heat and not cold.
Lew Farber
541-490-6357
Old 10-18-2015, 01:42 PM   #27
Images: 12
That's the preferred approach for me too, but most people are unwilling to take that two-step process. There are non-insulated butt connectors made of seamless tin-plated copper tube, and provided you use the correct crimper, which is not the same as the one for insulated terminals, they work great and last forever in my experience.
I use military spec aircraft wire, because I have it. But yes, tinned and stranded exclusively. Lots of aircraft shops tossed out perfectly good last-generation wire, which has nylon jacket over PVC insulation, when the FAA decided that Tefzel would be required for new installations.
Old 10-18-2015, 03:38 PM   #28
1995 36' Classic 36
Ludington , Michigan
chassis electrical replacement
Crimp vs solder is often a highly debated topic. I've work as an electrical engineer in the aerospace industry for years. I'll just make a couple points. The transition between solid and stranded as in a solder connection are highly susceptible to metal fatigue and corrosion. More so than a proper mechanical crimp. Especially in high vibration environments. A proper mechanical crimp requires the correct good quality connector and the proper crimping tool. Strain relieve is also important. The strain relief material often provides protection from corrosion. There are some good products designed for marine applications.
These work quite well but use a heat gun, not a lighter.
Kota is offline   Reply With Quote
P30 chassis electrical gaiaenviro Classic Motorhomes 1 05-10-2015 05:00 PM
Retractable electrical power cord replacement Excella CM Electrical - Systems, Generators, Batteries & Solar 4 07-19-2013 11:30 AM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Airstream Chassis Replacement Dismayed Repairing/Replacing Floor &/or Frame 23 08-13-2009 01:21 PM
Complete floor replacement and chassis refurm photos Jonz Repairing/Replacing Floor &/or Frame 0 09-16-2007 06:37 AM
