Old 07-25-2011, 02:07 PM   #1
woodja's Avatar
1982 31' Airstream 310
Dayton , Tennessee
Ceiling vent fan
When we bought our '82 310 last August, the ceiling fan in the galley area was working but noisy. After removing the fan motor to clean & lube etc. I bench tested & it ran great & quiet too. After reinstalling it wouldn't work at all & after checking, the wire leads are not hot. The only fuse panels I know of are the 12v panel under the dash & the small panel below the ice maker in front of the converter. If a fuse is blown under the dash I could easily overlook it or actually I can barely look at it. The fuses in the other panel appear to be OK. What am I missing? How are these wires routed & where does this fan get power from?
(This is the crank up vent in the ceiling center in front of the fridge not the exhaust fan over the range.)
Thanks for any help----- Pete
woodja is offline   Reply With Quote
Old 07-25-2011, 06:39 PM   #2
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
My light overhead same position is not working. I don't have an exhaust fan there but sounds like same problem. It worked at one time but now is not. I know this doesn't help you but I think I see a pattern.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 07-29-2011, 03:53 PM   #3
woodja's Avatar
Dayton , Tennessee
Myrtle lynn, Thanks for at least trying to help. 100 people have viewed this post so we must be the only moho to have this setup. Pete
Old 07-29-2011, 04:10 PM   #4
1985 31' Excella
Fresno , Texas
I believe there is a micro switch in the circuit
Wsmith is offline   Reply With Quote
Old 07-29-2011, 08:20 PM   #5
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Yep just ours.
Athens GA
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Knob for kitchen exhaust vent fan chrischarles General Repair Forum 0 05-08-2011 06:53 PM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
Vent fan motor/blade Rickman4 Roof Vents, Skylights & Fans 0 01-27-2011 09:44 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
