Old 07-18-2013, 07:15 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Ceiling fan
I am looking for a ceiling fan blade and the little motor. If anyone has replaced their ceiling fan and still have the motor and fan I can give it a home.
shepherd57 is online now   Reply With Quote
Old 07-21-2013, 07:18 AM   #2
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
If you are referring to the fans in the bath and shower, they can be had at any good RV supplier. They are not AS specific.
raveson is offline   Reply With Quote
Old 07-21-2013, 10:22 AM   #3
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
One inexpensive consideration is to use a 12V computer fan for the bath/shower area. I haven’t done that, because I don’t need to—yet. Another idea is to use the 12V, 200mm or 230mm computer case fan for the overhead vent. My A/S has only one Fantastic Vent fan and was thinking of someday installing a 230mm fan, and adding a switch and then putting it in the other vent. Don’t know how it would fit, but cheaper than getting another Fantastic Vent fan.
JStanley is offline   Reply With Quote
Old 07-21-2013, 11:37 AM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
We need pictures of what you need. I have the two vent fans that I removed from my '82 but I don't know it they are what you need.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-21-2013, 11:56 AM   #5
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Was looking at RV Geek on You Tube and thought this would be a good post on how to clean your vent fans.
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 07-25-2013, 06:23 PM   #6
shepherd57's Avatar
Lindsay , Ontario
Hi Dan
I need the ceiling fan blade and motor, and the bathroom fan and motor and the trim pieces, The shower fan is the same it needs all of the trim and handle
ID:	191725   Click image for larger version
Old 07-25-2013, 06:48 PM   #7
John,
I'm pretty sure I have pieces and parts for the smaller round fan. I don't recall seeing the larger fan before in any of the motorhomes or trailers I've seen.
Old 07-25-2013, 07:25 PM   #8
I have to agree with Brad, I don't recall ever seeing a ceiling fan like that. The ones I took out had aluminum covers and fan blades. The small bathroom vent is available with a smoke colored lid from Vintage Trailer Supply. 12V Air-Powered Roof Vent
I think I have read that Airstream still has them available also.
Cheers, Dan
