Old 03-24-2011, 07:31 PM   #1
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Caution, for those running Gear Vendors Units
Service, every oil change, Service
as I was discussing with a forum member from Florida.
Very few service these great Units as recommended.
Quote, G.V. service bulletin , SPECIFICATIONS:
Net Weight 32-46 lbs depending on application hardware.
Ratio - .78:1 pr 1:1 (reciprocal 1:1.28
Mechanically direct, hydraulically overdriven DeNormanville design.
Long Life Epicyclic planetary.
Solenoid control valve 6-12 volt negative ground @ 2amps.
650-700psi relief valve shift circuit.
Low parasitic loss common vertex Raybestos clutch.
Gross Combined Weight Rating 30,000lbs recreation (25K commercial)
Pressurized lubrication circuit to planet pinion bearings, roller clutch, input shaft pilot, planet thrust surfaces, and ring gear.
Pressurized 2 stage permanent filter circuit.
High speed Dual Row caged needle planet bearings.
Efficient Single stroke/rev plunger pump with non-return valve.
Fluid capacity 28zo/flat sump or 48oz/deep sump.
Fluid type - GM#1052271 petroleum based or GM#12346190 synthetic.
18 Elements single row roller clutch rated to 4500lbs spike torque.
Horsepower limitations - 1200+ call GEAR VENDORS for applications above 1200hp.
Recommended service interval - change fluid every 5,000 miles depending on severity of duty.
John H. is offline   Reply With Quote
Old 05-07-2011, 12:42 PM   #2
Images: 13
I am Now running a Shaffer's Synthetic, Transmission fluid and will drain and change every 3 to 5,000 miles.
So far so very good
Old 05-07-2011, 01:22 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Back when I bought mine the service interval was every 10 K with ATF. Shortly after that they changed it to every 10k with the Syntor synthetic oil that is used in my Dodge transmission.
Now it looks like they halved that. I did change mine religiously but still had enough problems that I finally got rid of it.
Hopefully they are doing better now as a few years have past.
Looks like we are not too many miles apart.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-07-2011, 01:44 PM   #4
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Im using amsoil synthetic. I change it every oil service at 3-5k aswell.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 05-07-2011, 03:54 PM   #5
Images: 13
Yes, we get down your way quite often.
Byrdstown for lunch. dinner and music on Friday, Saturday on the square. the Dixie cafe
Sargent York Park, Mill on 127 and such.
Old 05-07-2011, 04:58 PM   #6
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Vinnie
That's almost overkill, but I like it! When you change to synthetic, is it as simple as just switching over, or should some kind of cleaning be done. Most guys I've met that run amsoil claim to not change it for 10k, or so. I've never believed them! What's the deal, they make it in multi-grade for the diesel and 90 weight for the o'drive and rear end? Transmission?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-07-2011, 05:08 PM   #7
Images: 13
Mike, I dropped the finned Pan, cleaned the filter and inside, outside with a parts cleaner.
re assembled and filled with fresh synthetic Transmission fluid. I used schaeffer's. what we use on the farm.
But any synthetic with specs the same as, or better than, and compatible with Dextron will work.
Schaeffer's ALL-Trans Supreme Transmission Fluid for Dexron ...
Schaeffer’s 0204 SAT ALL-TRANS® Supreme Automatic Transmission Fluid ... ALL-TRANS® Supreme is a full synthetic transmission fluid ...
www.schaefferoil.com/204_transmission_fluid.html - Cached
AMSOIL - Comparative Motor Oil Testing
Manufacturer of synthetic oil, premium synthetic lubricants, synthetic motor oil ... The size of the scar left as a result of the test determines the ...
www.amsoil.com/comparison/motor-oil.aspx -
Old 05-07-2011, 11:02 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Hi Mike,
My GV is a new unit with about 13k on it now. The first time I ran the GM fluid that GV specs for it. I let it go for about 7000 miles and it would disengage hard after that many miles. Now im running the amsoil and when coming to a stop it falls out like butter now and engages nicely too. I think I will only go as far as 5k. I bought a whole case of the amsoil and it was about $160.00 dollars. Its good for about 11 oil changes.
Vinnie
1978 Argosy Steering Gear Leak stereoeric Argosy Motorhomes 3 09-05-2011 11:38 PM
Gear Vendors pjude Classic Motorhomes 4 03-20-2011 11:32 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
Photos of running gear condition LawChick Buyer Guidelines 21 01-13-2011 03:25 AM
