Originally Posted by Surprise
Update: finally got a couple hours to tinker. I've discovered the Diverter Valve is bad, it's stuck in the open position and applied vacuum doesn't close it. It's discontinued everywhere I've called so far. Plus, the TRC Solenoid Control Valve is broken and causing a vacuum leak. Also discontinued! I believe the diverter valve to be the main cause of the failing emissions.
To answer previous posts... The carb is rebuilt correctly, and I have used Phx carbs and Rods Carbs before. Both did good work.
Good that you are figuring this out!
If you had not seen it, there is an Emissions thread running over in the engines section that might help ya!
Here is how the smog pump, diverter and TRC valve should be set up.
FYI , my junkyard find smog pump diverter valve also is failed... applying vacuum does not do a thing..
I found that RockAuto lists one for a 1984 P30...
AIRTEX / WELLS Part # 7D1097, GM#17062646, or DV108 and list it at $151 or so.
The TRC valve I have works...
I apply
12v and it clicks and opens the valve, allowing vacuum to flow.
Let me know if you cannot find one, and I will see if I can find you a used one!
