Old 03-22-2015, 03:29 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Carrier bearing lube
I was going through the chassis today and greasing all the fittings that I could find. Got all the obvious places but was a little suprised that there was no visible means to grease the carrier bearings. Do the carrier bearings get lubrication somehow? Could someone clue me in on this. How or if one is supposed to apply grease to the carrier bearings?
Thanks again,
Mike
mayco is online now   Reply With Quote
Old 03-22-2015, 03:53 PM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
They are non serviceable
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 03-22-2015, 04:25 PM   #3
mayco's Avatar
Eh! Thats kinda what I was thinking. Well, no problems, just doing some preventative maintenance....good to know. Thank you Glenritas.
Old 03-22-2015, 05:07 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
As with all P30 parts they don't seem to be that expensive. The expensive one has a slinger option which keeps mud and muck from the bearing; just what you need for when you take your rig to the southern mud bog events with all the scantily clad women and guys whose first names start with Bo.
http://www.summitracing.com/int/sear.../model/p30-van
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-22-2015, 05:23 PM   #5
mayco's Avatar
Oh damn......Ill consider that for sure
Old 03-22-2015, 07:08 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Just a heads up if you do go mudd'n, I'm pretty sure it's pronounced...Oh Dang, not Oh Damn.
I'll keep an eye on some 8R19.5" mud boggers for ya'll.
Cheers
Tony
Old 03-22-2015, 08:35 PM   #7
mayco's Avatar
Dang it
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
wheel bearing lube 1989 excella murphy Wheels, Hubs & Bearings 1 06-21-2011 07:25 AM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
Carrier bearing help Waipio Rim Mechanics Corner - Engines, Transmission & More... 6 07-07-2010 01:50 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
